[GSoC 2020]: Need help in writing sed alternative in Python for RSB recipes
Tue Aug 25 02:07:38 UTC 2020
On 25/8/20 12:34 am, Heinz Junkes wrote:
> Thanks Chris for the explanation. It all makes sense.
My pleasure.
> I stumbled over the following point:
> I tested the rc-2 and followed the Quick Guide to Building.
> To build the tools for the ARM architecture:
> ../source-builder/sb-set-builder \
>   --prefix=$HOME/development/rtems/5.1-rc2 \
>   5/rtems-arm
> To build the tools, kernel and all packages for the Beagleboneblack:
>   5/bsps/beagleboneblack
> After that I tried to build EPICS and ran into the error of a missing header file.
> “librtemsNFS.h could not be found”
> This header file is in rtems-libbsd which I then had to reinstall and build for the target.
I could not find `librtemsNFS.h` but I found `librtemsNfs.h`? ...
$ find . -name librtems\*.h
./cpukit/libnetworking/librtemsNfs.h
> Then I thought about whether a recipe could/should consider this dependency.
The header should be there. I am more concerned about the contents of the that
header ... hmm.
What calls does EPICS use from this file? I suggest it gets reviewed. The
problem RTEMS has long term with the interface in `librtemsNfs.h` is it being
bespoke to the NFS implementation and we may not be able to maintain it in the
future, for example upgrading NFS to NFSv4.
In systems I work on for clients I encourage scripting of some form be used.
Commands hide the implementation details and this lets us (RTEMS) better
maintain compatibility. The scripting can be plain text files or `joel` scripts
or command sequences in another configuration format, for example YAML. You can
directly call shell commands.
To mount a remote disk use:
  mkdir /foobar
  mount -t nfs foo:/bar /foobar
