[GSoC 2020]: Need help in writing sed alternative in Python for RSB recipes
Heinz Junkes junkes at fhi-berlin.mpg.de
Tue Aug 25 12:48:12 UTC 2020
Hallo Chris,
yes it works as described. The header file (librtemsNfs.h) is also there.
I must have done something wrong the day before yesterday. Unfortunately
I can't reproduce it anymore. Sorry for the "false alarm”.
I no longer use librtemNfs.h when using the libbsd stack.
It is no longer necessary there.
For mounting I already use “mount_and_marget_target_path(). This call is ok?
If I still need it for the legacy stack I can't try it at the moment.
I will try it next week. But I guess that I don't need it at all anymore with RTEMS5.
It seems to be a RTEMS 4 remnant.
Viele Grüße
Heinz
> On 25. Aug 2020, at 04:07, Chris Johns <chrisj at rtems.org> wrote:
>> After that I tried to build EPICS and ran into the error of a missing header file.
>> “librtemsNFS.h could not be found”
>> This header file is in rtems-libbsd which I then had to reinstall and build for the target.
> I could not find `librtemsNFS.h` but I found `librtemsNfs.h`? ...
> $ find . -name librtems\*.h
> ./cpukit/libnetworking/librtemsNfs.h
>> Then I thought about whether a recipe could/should consider this dependency.
> The header should be there. I am more concerned about the contents of the that
> header ... hmm.
> What calls does EPICS use from this file? I suggest it gets reviewed. The
> problem RTEMS has long term with the interface in `librtemsNfs.h` is it being
> bespoke to the NFS implementation and we may not be able to maintain it in the
> future, for example upgrading NFS to NFSv4.
> In systems I work on for clients I encourage scripting of some form be used.
> Commands hide the implementation details and this lets us (RTEMS) better
> maintain compatibility. The scripting can be plain text files or `joel` scripts
> or command sequences in another configuration format, for example YAML. You can
> directly call shell commands.
> To mount a remote disk use:
>  mkdir /foobar
>  mount -t nfs foo:/bar /foobar
> Chris
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200825/0f69a259/attachment.bin>
