[PATCH] sb: Use shebang env python
    chrisj at rtems.org
    chrisj at rtems.org
    Tue Aug 25 11:24:25 UTC 2020
Closes #4037
 source-builder/pkg-config             | 236 +++++++++++++++++++++++---
 source-builder/sb-check               |  24 +--
 source-builder/sb-defaults            |  23 +--
 source-builder/sb-get-sources         |  23 +--
 source-builder/sb-reports             |  23 +--
 source-builder/sb-rtems-config        |  23 +--
 source-builder/sb-set-builder         |  22 +--
 source-builder/sb-track               |  22 +--
 source-builder/sb/build.py            |  22 +--
 source-builder/sb/check.py            |  16 +-
 source-builder/sb/cmd-check.py        |  29 ----
 source-builder/sb/cmd-defaults.py     |  29 ----
 source-builder/sb/cmd-get-sources.py  |  29 ----
 source-builder/sb/cmd-pkg-config.py   | 220 ------------------------
 source-builder/sb/cmd-reports.py      |  29 ----
 source-builder/sb/cmd-rtems-config.py |  29 ----
 source-builder/sb/cmd-set-builder.py  |  29 ----
 source-builder/sb/cmd-track.py        |  29 ----
 source-builder/sb/config.py           |  16 +-
 source-builder/sb/cvs.py              |  10 +-
 source-builder/sb/darwin.py           |   2 +-
 source-builder/sb/download.py         |  14 +-
 source-builder/sb/ereport.py          |   4 +-
 source-builder/sb/execute.py          |   4 +-
 source-builder/sb/freebsd.py          |   6 +-
 source-builder/sb/getsources.py       |  12 +-
 source-builder/sb/git.py              |  13 +-
 source-builder/sb/linux.py            |   4 +-
 source-builder/sb/log.py              |   2 +-
 source-builder/sb/macros.py           |   4 +-
 source-builder/sb/mailer.py           |   6 +-
 source-builder/sb/netbsd.py           |   4 +-
 source-builder/sb/options.py          |  44 +++--
 source-builder/sb/path.py             |   4 +-
 source-builder/sb/pkgconfig.py        |   9 +-
 source-builder/sb/python-wrapper.sh   |  39 -----
 source-builder/sb/reports.py          |  22 +--
 source-builder/sb/rtemsconfig.py      |  10 +-
 source-builder/sb/setbuilder.py       |  22 +--
 source-builder/sb/shell.py            |   8 +-
 source-builder/sb/simhost.py          |  36 ++--
 source-builder/sb/solaris.py          |   6 +-
 source-builder/sb/sources.py          |   2 +-
 source-builder/sb/track.py            |  14 +-
 source-builder/sb/version.py          |   6 +-
 source-builder/sb/windows.py          |   6 +-
 46 files changed, 471 insertions(+), 715 deletions(-)
 delete mode 100755 source-builder/sb/cmd-check.py
 delete mode 100755 source-builder/sb/cmd-defaults.py
 delete mode 100755 source-builder/sb/cmd-get-sources.py
 delete mode 100755 source-builder/sb/cmd-pkg-config.py
 delete mode 100755 source-builder/sb/cmd-reports.py
 delete mode 100755 source-builder/sb/cmd-rtems-config.py
 delete mode 100755 source-builder/sb/cmd-set-builder.py
 delete mode 100755 source-builder/sb/cmd-track.py
 delete mode 100644 source-builder/sb/python-wrapper.sh
diff --git a/source-builder/pkg-config b/source-builder/pkg-config
index 65ee307..10db546 100755
--- a/source-builder/pkg-config
+++ b/source-builder/pkg-config
@@ -1,27 +1,221 @@
-#! /bin/sh
+#! /usr/bin/env python
 # RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2018 Chris Johns (chrisj at rtems.org)
+# Copyright 2014-2016 Chris Johns (chrisj at rtems.org)
 # All rights reserved.
 # This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Permission to use, copy, modify, and/or distribute this software for any
-# purpose with or without fee is hereby granted, provided that the above
-# copyright notice and this permission notice appear in all copies.
-# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
-# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
-# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
-# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
-# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
-# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
-# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-pkg-config.py
-if test -f ${base}/sb/python-wrapper.sh; then
-  . ${base}/sb/python-wrapper.sh
-fi
-echo "error: python wrapper not found"
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+from __future__ import print_function
+import os
+import sys
+base = os.path.dirname(sys.argv[0])
+try:
+    import argparse
+except:
+    sys.path.insert(0, base + '/sb/imports')
+    try:
+        import argparse
+    except:
+        print("Incorrect Source Builder installation", file = sys.stderr)
+        sys.exit(1)
+import sb.pkgconfig
+# Make trace true to get a file of what happens and what is being asked.
+trace = False
+trace_stdout = False
+logfile = 'pkg-config.log'
+out = None
+srcfd = None
+# Write all the package source parsed to a single file.
+trace_src = False
+if trace_src:
+    srcfd = open('pkg-src.txt', 'w')
+def src(text):
+    if srcfd:
+        srcfd.writelines(text)
+def log(s, lf = True):
+    global trace, logfile, out
+    if trace:
+        if out is None:
+            if logfile:
+                out = open(logfile, 'a')
+            else:
+                out = sys.stdout
+        if lf:
+            if out != sys.stdout and trace_stdout:
+                print(s)
+            print(s, file = out)
+        else:
+                print(s, end = '')
+                sys.stdout.flush()
+            print(s, end = '', file = out)
+def run(argv):
+    class version_action(argparse.Action):
+        def __call__(self, parser, namespace, values, option_string = None):
+            parts = values[0].strip().split('.')
+            for p in parts:
+                if not p.isdigit():
+                    raise error('invalid version value: %s' % (values))
+            setattr(namespace, self.dest, '.'.join(parts))
+    ec = 0
+    opts = argparse.ArgumentParser(prog = 'pkg-config', description = 'Package Configuration.')
+    opts.add_argument('libraries', metavar='lib', type = str,  help = 'a library', nargs = '*')
+    opts.add_argument('--modversion', dest = 'modversion', action = 'store', default = None,
+                      help = 'Requests that the version information of the libraries.')
+    opts.add_argument('--print-errors', dest = 'print_errors', action = 'store_true',
+                      default = False,
+                      help = 'Print any errors.')
+    opts.add_argument('--short-errors', dest = 'short_errors', action = 'store_true',
+                      default = False,
+                      help = 'Make error messages short.')
+    opts.add_argument('--silence-errors', dest = 'silence_errors', action = 'store_true',
+                      default = False,
+                      help = 'Do not print any errors.')
+    opts.add_argument('--errors-to-stdout', dest = 'errors_to_stdout', action = 'store_true',
+                      default = False,
+                      help = 'Print errors to stdout rather than stderr.')
+    opts.add_argument('--cflags', dest = 'cflags', action = 'store_true',
+                      default = False,
+                      help = 'This prints pre-processor and compile flags required to' \
+                             ' compile the package(s)')
+    opts.add_argument('--libs', dest = 'libs', action = 'store_true',
+                      default = False,
+                      help = 'This option is identical to "--cflags", only it prints the' \
+                             ' link flags.')
+    opts.add_argument('--libs-only-L', dest = 'libs_only_L', action = 'store_true',
+                      default = False,
+                      help = 'This prints the -L/-R part of "--libs".')
+    opts.add_argument('--libs-only-l', dest = 'libs_only_l', action = 'store_true',
+                      default = False,
+                      help = 'This prints the -l part of "--libs".')
+    opts.add_argument('--variable', dest = 'variable', action = 'store',
+                      nargs = 1, default = None,
+                      help = 'This returns the value of a variable.')
+    opts.add_argument('--define-variable', dest = 'define_variable', action = 'store',
+                      help = 'This sets a global value for a variable')
+    opts.add_argument('--uninstalled', dest = 'uninstalled', action = 'store_true',
+                      default = False,
+                      help = 'Ignored')
+    opts.add_argument('--atleast-pkgconfig-version', dest = 'atleast_pkgconfig_version',
+                      action = 'store', nargs = 1, default = None,
+                      help = 'Check the version of package config. Always ok.')
+    opts.add_argument('--exists', dest = 'exists', action = 'store_true',
+                      default = False,
+                      help = 'Test if a library is present')
+    opts.add_argument('--atleast-version', dest = 'atleast_version',
+                      action = version_action, nargs = 1, default = None,
+                      help = 'The package is at least this version.')
+    opts.add_argument('--exact-version', dest = 'exact_version', action = version_action,
+                        help = 'The package is the exact version.')
+    opts.add_argument('--max-version', dest = 'max_version', action = version_action,
+                      help = 'The package is no later than this version.')
+    opts.add_argument('--msvc-syntax', dest = 'msvc_syntax', action = 'store_true',
+                      default = False,
+                      help = 'Ignored')
+    opts.add_argument('--dont-define-prefix', dest = 'dont_define_prefix', action = 'store_true',
+                      default = False,
+                      help = 'Ignored')
+    opts.add_argument('--prefix-variable', dest = 'prefix', action = 'store',
+                      nargs = 1, default = sb.pkgconfig.default_prefix(),
+                      help = 'Define the prefix.')
+    opts.add_argument('--static', dest = 'static', action = 'store_true',
+                      default = False,
+                      help = 'Output libraries suitable for static linking')
+    opts.add_argument('--dump', dest = 'dump', action = 'store_true',
+                      default = False,
+                      help = 'Dump the package if one is found.')
+    args = opts.parse_args(argv)
+    if (args.exists and (args.exact_version or args.max_version)) or \
+            (args.exact_version and (args.exists or args.max_version)) or \
+            (args.max_version and (args.exists or args.exact_version)):
+        raise error('only one of --exists, --exact-version, or --max-version')
+    if args.dont_define_prefix:
+        args.prefix = sb.pkgconfig.default_prefix(False)
+    exists = False
+    ec = 1
+    if args.atleast_pkgconfig_version:
+        ec = 0
+    else:
+        ec, pkg, flags = sb.pkgconfig.check_package(args.libraries, args, log, src)
+        if ec == 0:
+            if args.cflags:
+                if len(flags['cflags']):
+                    print(flags['cflags'])
+                    log('cflags: %s' % (flags['cflags']))
+                else:
+                    log('cflags: empty')
+            if args.libs:
+                if len(flags['libs']):
+                    print(flags['libs'])
+                    log('libs: %s' % (flags['libs']))
+                else:
+                    log('libs: empty')
+    #pkgconfig.package.dump_loaded()
+    return ec
+try:
+    log('-' * 40)
+    log('pkg-config', lf = False)
+    for a in sys.argv[2:]:
+        log(' "%s"' % (a), lf = False)
+    log('')
+    ec = run(sys.argv[1:])
+    log('ec = %d' % (ec))
+except ImportError:
+    print("incorrect package config installation", file = sys.stderr)
+    sys.exit(1)
+except sb.pkgconfig.error as e:
+    print('error: %s' % (e), file = sys.stderr)
+    sys.exit(1)
+sys.exit(ec)
diff --git a/source-builder/sb-check b/source-builder/sb-check
index b092697..b75767e 100755
--- a/source-builder/sb-check
+++ b/source-builder/sb-check
@@ -1,7 +1,7 @@
-#! /bin/sh
+# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
@@ -17,11 +17,15 @@
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-check.py
-fi
+import sb.check
+try:
+    import sb.check
+    sb.check.run()
+    import sys
+    sys.exit(1)
diff --git a/source-builder/sb-defaults b/source-builder/sb-defaults
index 25437ba..2fd2121 100755
--- a/source-builder/sb-defaults
+++ b/source-builder/sb-defaults
@@ -1,7 +1,7 @@
-#! /bin/sh
+# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
@@ -17,11 +17,14 @@
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-defaults.py
-fi
+import sys
+try:
+    import sb.options
+    sb.options.run(sys.argv)
+    sys.exit(1)
diff --git a/source-builder/sb-get-sources b/source-builder/sb-get-sources
index d9f03b7..97ee419 100755
--- a/source-builder/sb-get-sources
+++ b/source-builder/sb-get-sources
@@ -1,7 +1,7 @@
-#! /bin/sh
-# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2019 Chris Johns (chrisj at rtems.org)
@@ -17,11 +17,14 @@
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-get-sources.py
-fi
+try:
+    import sb.getsources
+    sb.getsources.run()
+    import sys
+    sys.exit(1)
diff --git a/source-builder/sb-reports b/source-builder/sb-reports
index 5fb02d1..194c4ab 100755
--- a/source-builder/sb-reports
+++ b/source-builder/sb-reports
@@ -1,7 +1,7 @@
-#! /bin/sh
@@ -17,11 +17,14 @@
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-reports.py
-fi
+import sys
+try:
+    import sb.reports
+    sb.reports.run(sys.argv)
+    sys.exit(1)
diff --git a/source-builder/sb-rtems-config b/source-builder/sb-rtems-config
index 66a95f7..a84b9c8 100755
--- a/source-builder/sb-rtems-config
+++ b/source-builder/sb-rtems-config
@@ -1,7 +1,7 @@
-#! /bin/sh
@@ -17,11 +17,14 @@
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-rtems-config.py
-fi
+import sys
+try:
+    import sb.rtemsconfig
+    sb.rtemsconfig.run(sys.argv)
+    sys.exit(1)
diff --git a/source-builder/sb-set-builder b/source-builder/sb-set-builder
index 6a196fe..96dd919 100755
--- a/source-builder/sb-set-builder
+++ b/source-builder/sb-set-builder
@@ -1,7 +1,7 @@
-#! /bin/sh
@@ -17,11 +17,13 @@
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-set-builder.py
-fi
+try:
+    import sb.setbuilder
+    sb.setbuilder.run()
+    import sys
+    sys.exit(1)
diff --git a/source-builder/sb-track b/source-builder/sb-track
index a739978..64daeb8 100755
--- a/source-builder/sb-track
+++ b/source-builder/sb-track
@@ -1,7 +1,7 @@
-#! /bin/sh
@@ -17,11 +17,13 @@
-set -e
-base=$(dirname $0)
-PYTHON_CMD=${base}/sb/cmd-track.py
-fi
+try:
+    import sb.track
+    sb.track.run()
+    import sys
+    sys.exit(1)
diff --git a/source-builder/sb/build.py b/source-builder/sb/build.py
index cfb7d8c..f3253dd 100644
--- a/source-builder/sb/build.py
+++ b/source-builder/sb/build.py
@@ -33,17 +33,17 @@ import stat
 import sys
 try:
-    import check
-    import config
-    import download
-    import error
-    import ereport
-    import execute
-    import log
-    import options
-    import path
-    import sources
-    import version
+    from . import check
+    from . import config
+    from . import download
+    from . import error
+    from . import ereport
+    from . import execute
+    from . import log
+    from . import options
+    from . import path
+    from . import sources
+    from . import version
 except KeyboardInterrupt:
     print('abort: user terminated')
     sys.exit(1)
diff --git a/source-builder/sb/check.py b/source-builder/sb/check.py
index be808ea..7e23223 100644
--- a/source-builder/sb/check.py
+++ b/source-builder/sb/check.py
@@ -23,16 +23,16 @@
-import os
-import error
-import execute
 import fnmatch
-import log
-import options
-import path
+import os
 import re
-import version
+from . import error
+from . import execute
+from . import log
+from . import options
+from . import path
+from . import version
 def _check_none(_opts, macro, value, constraint):
     return True
diff --git a/source-builder/sb/cmd-check.py b/source-builder/sb/cmd-check.py
deleted file mode 100755
index 4525dbb..0000000
--- a/source-builder/sb/cmd-check.py
+++ /dev/null
@@ -1,29 +0,0 @@
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-from __future__ import print_function
-import sys, os
-try:
-    import check
-    check.run()
-except ImportError:
-    print("Incorrect Source Builder installation", file = sys.stderr)
-    sys.exit(1)
diff --git a/source-builder/sb/cmd-defaults.py b/source-builder/sb/cmd-defaults.py
index 0b2b357..0000000
--- a/source-builder/sb/cmd-defaults.py
+++ /dev/null
@@ -1,29 +0,0 @@
-# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
-import sys, os
-try:
-    import options
-    options.run(sys.argv)
-    sys.exit(1)
diff --git a/source-builder/sb/cmd-get-sources.py b/source-builder/sb/cmd-get-sources.py
index 480e81d..0000000
--- a/source-builder/sb/cmd-get-sources.py
+++ /dev/null
@@ -1,29 +0,0 @@
-# Copyright 2010-2019 Chris Johns (chrisj at rtems.org)
-import sys, os
-try:
-    import getsources
-    getsources.run()
-    sys.exit(1)
diff --git a/source-builder/sb/cmd-pkg-config.py b/source-builder/sb/cmd-pkg-config.py
index 68c67cf..0000000
--- a/source-builder/sb/cmd-pkg-config.py
+++ /dev/null
@@ -1,220 +0,0 @@
-# Copyright 2014-2016 Chris Johns (chrisj at rtems.org)
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-import os
-import sys
-base = os.path.dirname(sys.argv[1])
-try:
-    import argparse
-except:
-    sys.path.insert(0, base + '/sb/imports')
-    try:
-        import argparse
-    except:
-        sys.exit(1)
-import pkgconfig
-# Make trace true to get a file of what happens and what is being asked.
-trace = False
-trace_stdout = False
-logfile = 'pkg-config.log'
-out = None
-srcfd = None
-# Write all the package source parsed to a single file.
-trace_src = False
-if trace_src:
-    srcfd = open('pkg-src.txt', 'w')
-def src(text):
-    if srcfd:
-        srcfd.writelines(text)
-def log(s, lf = True):
-    global trace, logfile, out
-    if trace:
-        if out is None:
-            if logfile:
-                out = open(logfile, 'a')
-            else:
-                out = sys.stdout
-        if lf:
-            if out != sys.stdout and trace_stdout:
-                print(s)
-            print(s, file = out)
-        else:
-                print(s, end = '')
-                sys.stdout.flush()
-            print(s, end = '', file = out)
-def run(argv):
-    class version_action(argparse.Action):
-        def __call__(self, parser, namespace, values, option_string = None):
-            parts = values[0].strip().split('.')
-            for p in parts:
-                if not p.isdigit():
-                    raise error('invalid version value: %s' % (values))
-            setattr(namespace, self.dest, '.'.join(parts))
-    ec = 0
-    opts = argparse.ArgumentParser(prog = 'pkg-config', description = 'Package Configuration.')
-    opts.add_argument('libraries', metavar='lib', type = str,  help = 'a library', nargs = '*')
-    opts.add_argument('--modversion', dest = 'modversion', action = 'store', default = None,
-                      help = 'Requests that the version information of the libraries.')
-    opts.add_argument('--print-errors', dest = 'print_errors', action = 'store_true',
-                      default = False,
-                      help = 'Print any errors.')
-    opts.add_argument('--short-errors', dest = 'short_errors', action = 'store_true',
-                      default = False,
-                      help = 'Make error messages short.')
-    opts.add_argument('--silence-errors', dest = 'silence_errors', action = 'store_true',
-                      default = False,
-                      help = 'Do not print any errors.')
-    opts.add_argument('--errors-to-stdout', dest = 'errors_to_stdout', action = 'store_true',
-                      default = False,
-                      help = 'Print errors to stdout rather than stderr.')
-    opts.add_argument('--cflags', dest = 'cflags', action = 'store_true',
-                      default = False,
-                      help = 'This prints pre-processor and compile flags required to' \
-                             ' compile the package(s)')
-    opts.add_argument('--libs', dest = 'libs', action = 'store_true',
-                      default = False,
-                      help = 'This option is identical to "--cflags", only it prints the' \
-                             ' link flags.')
-    opts.add_argument('--libs-only-L', dest = 'libs_only_L', action = 'store_true',
-                      default = False,
-                      help = 'This prints the -L/-R part of "--libs".')
-    opts.add_argument('--libs-only-l', dest = 'libs_only_l', action = 'store_true',
-                      default = False,
-                      help = 'This prints the -l part of "--libs".')
-    opts.add_argument('--variable', dest = 'variable', action = 'store',
-                      nargs = 1, default = None,
-                      help = 'This returns the value of a variable.')
-    opts.add_argument('--define-variable', dest = 'define_variable', action = 'store',
-                      help = 'This sets a global value for a variable')
-    opts.add_argument('--uninstalled', dest = 'uninstalled', action = 'store_true',
-                      default = False,
-                      help = 'Ignored')
-    opts.add_argument('--atleast-pkgconfig-version', dest = 'atleast_pkgconfig_version',
-                      action = 'store', nargs = 1, default = None,
-                      help = 'Check the version of package config. Always ok.')
-    opts.add_argument('--exists', dest = 'exists', action = 'store_true',
-                      default = False,
-                      help = 'Test if a library is present')
-    opts.add_argument('--atleast-version', dest = 'atleast_version',
-                      action = version_action, nargs = 1, default = None,
-                      help = 'The package is at least this version.')
-    opts.add_argument('--exact-version', dest = 'exact_version', action = version_action,
-                        help = 'The package is the exact version.')
-    opts.add_argument('--max-version', dest = 'max_version', action = version_action,
-                      help = 'The package is no later than this version.')
-    opts.add_argument('--msvc-syntax', dest = 'msvc_syntax', action = 'store_true',
-                      default = False,
-                      help = 'Ignored')
-    opts.add_argument('--dont-define-prefix', dest = 'dont_define_prefix', action = 'store_true',
-                      default = False,
-                      help = 'Ignored')
-    opts.add_argument('--prefix-variable', dest = 'prefix', action = 'store',
-                      nargs = 1, default = pkgconfig.default_prefix(),
-                      help = 'Define the prefix.')
-    opts.add_argument('--static', dest = 'static', action = 'store_true',
-                      default = False,
-                      help = 'Output libraries suitable for static linking')
-    opts.add_argument('--dump', dest = 'dump', action = 'store_true',
-                      default = False,
-                      help = 'Dump the package if one is found.')
-    args = opts.parse_args(argv[1:])
-    if (args.exists and (args.exact_version or args.max_version)) or \
-            (args.exact_version and (args.exists or args.max_version)) or \
-            (args.max_version and (args.exists or args.exact_version)):
-        raise error('only one of --exists, --exact-version, or --max-version')
-    if args.dont_define_prefix:
-        args.prefix = pkgconfig.default_prefix(False)
-    exists = False
-    ec = 1
-    if args.atleast_pkgconfig_version:
-        ec = 0
-    else:
-        ec, pkg, flags = pkgconfig.check_package(args.libraries, args, log, src)
-        if ec == 0:
-            if args.cflags:
-                if len(flags['cflags']):
-                    print(flags['cflags'])
-                    log('cflags: %s' % (flags['cflags']))
-                else:
-                    log('cflags: empty')
-            if args.libs:
-                if len(flags['libs']):
-                    print(flags['libs'])
-                    log('libs: %s' % (flags['libs']))
-                else:
-                    log('libs: empty')
-    #pkgconfig.package.dump_loaded()
-    return ec
-try:
-    log('-' * 40)
-    log('pkg-config', lf = False)
-    for a in sys.argv[2:]:
-        log(' "%s"' % (a), lf = False)
-    log('')
-    ec = run(sys.argv[1:])
-    log('ec = %d' % (ec))
-    print("incorrect package config installation", file = sys.stderr)
-    sys.exit(1)
-except pkgconfig.error as e:
-    print('error: %s' % (e), file = sys.stderr)
-    sys.exit(1)
-sys.exit(ec)
diff --git a/source-builder/sb/cmd-reports.py b/source-builder/sb/cmd-reports.py
index 4c41e33..0000000
--- a/source-builder/sb/cmd-reports.py
+++ /dev/null
@@ -1,29 +0,0 @@
-import sys, os
-try:
-    import reports
-    reports.run(sys.argv)
-    sys.exit(1)
diff --git a/source-builder/sb/cmd-rtems-config.py b/source-builder/sb/cmd-rtems-config.py
index f29ef04..0000000
--- a/source-builder/sb/cmd-rtems-config.py
+++ /dev/null
@@ -1,29 +0,0 @@
-import sys, os
-try:
-    import rtemsconfig
-    rtemsconfig.run(sys.argv)
-    sys.exit(1)
diff --git a/source-builder/sb/cmd-set-builder.py b/source-builder/sb/cmd-set-builder.py
index 56114cd..0000000
--- a/source-builder/sb/cmd-set-builder.py
+++ /dev/null
@@ -1,29 +0,0 @@
-import sys, os
-try:
-    import setbuilder
-    setbuilder.run()
-    sys.exit(1)
diff --git a/source-builder/sb/cmd-track.py b/source-builder/sb/cmd-track.py
index 82615a5..0000000
--- a/source-builder/sb/cmd-track.py
+++ /dev/null
@@ -1,29 +0,0 @@
-import sys, os
-try:
-    import track
-    track.run()
-    sys.exit(1)
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index f8854a5..db795b3 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -34,13 +34,13 @@ import re
 import sys
 try:
-    import error
-    import execute
-    import log
-    import options
-    import path
-    import pkgconfig
-    import sources
+    from . import log
+    from . import pkgconfig
     print('user terminated', file = sys.stderr)
     sys.exit(1)
@@ -500,6 +500,7 @@ class file:
             except pkgconfig.error as pe:
                 self._error('pkgconfig: check: %s' % (pe))
             except:
+                raise
                 raise error.internal('pkgconfig failure')
         if ok:
             return '1'
@@ -524,6 +525,7 @@ class file:
                 self._error('pkgconfig: %s:  %s' % (flags, pe))
             except:
+                raise
         if pkg_flags is None:
             pkg_flags = ''
diff --git a/source-builder/sb/cvs.py b/source-builder/sb/cvs.py
index 2ff7417..673488e 100644
--- a/source-builder/sb/cvs.py
+++ b/source-builder/sb/cvs.py
@@ -25,11 +25,10 @@ from __future__ import print_function
 import os
-import error
-import execute
-import log
-import options
-import path
+from . import log
+from . import path
 class repo:
     """An object to manage a cvs repo."""
@@ -147,6 +146,7 @@ class repo:
 if __name__ == '__main__':
     import sys
     opts = options.load(sys.argv, defaults = 'defaults.mc')
     ldir = 'cvs-test-rm-me'
     c = repo(ldir, opts)
diff --git a/source-builder/sb/darwin.py b/source-builder/sb/darwin.py
index a21a6bc..95a2a4e 100644
--- a/source-builder/sb/darwin.py
+++ b/source-builder/sb/darwin.py
@@ -24,7 +24,7 @@
 import os
-import execute
 def load():
     uname = os.uname()
diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
index 3aaa701..410edeb 100644
--- a/source-builder/sb/download.py
+++ b/source-builder/sb/download.py
@@ -37,13 +37,13 @@ except ImportError:
     import urllib2 as urllib_request
     import urlparse as urllib_parse
-import cvs
-import error
-import git
-import log
-import path
-import sources
-import version
+from . import cvs
+from . import git
+from . import log
+from . import path
+from . import sources
 def _do_download(opts):
     download = True
diff --git a/source-builder/sb/ereport.py b/source-builder/sb/ereport.py
index 475eff7..d8fb5f6 100755
--- a/source-builder/sb/ereport.py
+++ b/source-builder/sb/ereport.py
@@ -25,8 +25,8 @@ from __future__ import print_function
 import os
-import error
-import log
+from . import log
 def generate(name, opts, header = None, footer = None):
     label, result = opts.with_arg('error-report')
diff --git a/source-builder/sb/execute.py b/source-builder/sb/execute.py
index 06f9b7d..3db9abc 100755
--- a/source-builder/sb/execute.py
+++ b/source-builder/sb/execute.py
@@ -36,8 +36,8 @@ import threading
 import time
 import traceback
-import error
-import log
+from . import log
 # Trace exceptions
 trace_threads = False
diff --git a/source-builder/sb/freebsd.py b/source-builder/sb/freebsd.py
index 5497e75..472f670 100644
--- a/source-builder/sb/freebsd.py
+++ b/source-builder/sb/freebsd.py
@@ -27,9 +27,9 @@
 import pprint
 import os
-import check
-import error
-import execute
+from . import check
 def load():
     uname = os.uname()
diff --git a/source-builder/sb/getsources.py b/source-builder/sb/getsources.py
index 7d76038..0ccf257 100644
--- a/source-builder/sb/getsources.py
+++ b/source-builder/sb/getsources.py
@@ -31,11 +31,11 @@ import os
 import sys
 try:
-    import build
-    import error
-    import log
-    import simhost
-    import version
+    from . import build
+    from . import log
+    from . import simhost
     print('abort: user terminated', file = sys.stderr)
     sys.exit(1)
@@ -76,7 +76,7 @@ def run(args = sys.argv):
                            action = 'store_true')
         argsp.add_argument('bsets', nargs='*', help = 'Build sets.')
-        argopts = argsp.parse_args(args[2:])
+        argopts = argsp.parse_args(args[1:])
         simhost.load_log(argopts.log)
         log.notice('RTEMS Source Builder - Get Sources, %s' % (version.string()))
diff --git a/source-builder/sb/git.py b/source-builder/sb/git.py
index 52bcb83..237e690 100644
--- a/source-builder/sb/git.py
+++ b/source-builder/sb/git.py
 import os
-import error
-import execute
-import log
-import options
-import path
+from . import log
+from . import path
 class repo:
     """An object to manage a git repo."""
@@ -230,7 +229,9 @@ class repo:
     import os.path
     import sys
-    defaults = path.join(path.dirname(path.dirname(path.shell(sys.argv[0]))), 'defaults.mc')
+    defaults = path.join(path.dirname(path.dirname(path.shell(sys.argv[0]))),
+                         'defaults.mc')
     opts = options.load(sys.argv, defaults = defaults)
     g = repo('.', opts)
     print('g.git_version():', g.git_version())
diff --git a/source-builder/sb/linux.py b/source-builder/sb/linux.py
index 791bbd6..d773818 100644
--- a/source-builder/sb/linux.py
+++ b/source-builder/sb/linux.py
@@ -26,8 +26,8 @@ import multiprocessing
 import pprint
 import os
-import platform
-import path
+from . import platform
+from . import path
 def load():
     uname = os.uname()
diff --git a/source-builder/sb/log.py b/source-builder/sb/log.py
index 788160e..7ad4763 100755
--- a/source-builder/sb/log.py
+++ b/source-builder/sb/log.py
@@ -26,7 +26,7 @@ from __future__ import print_function
 import os
 import sys
-import error
 # A global log.
diff --git a/source-builder/sb/macros.py b/source-builder/sb/macros.py
index 5a639b8..6ca87ed 100644
--- a/source-builder/sb/macros.py
+++ b/source-builder/sb/macros.py
@@ -27,8 +27,8 @@ import re
 import os
 import string
-import error
-import path
+from . import path
 # Macro tables
diff --git a/source-builder/sb/mailer.py b/source-builder/sb/mailer.py
index 42b4fa6..ff25df5 100644
--- a/source-builder/sb/mailer.py
+++ b/source-builder/sb/mailer.py
@@ -27,9 +27,9 @@ import os
 import smtplib
 import socket
-import error
-import options
-import path
+from . import path
 def append_options(opts):
     opts['--mail'] = 'Send email report or results.'
diff --git a/source-builder/sb/netbsd.py b/source-builder/sb/netbsd.py
index c7420c3..3398290 100644
--- a/source-builder/sb/netbsd.py
+++ b/source-builder/sb/netbsd.py
@@ -27,8 +27,8 @@
 import pprint
 import os
-import check
-import execute
 def load():
     uname = os.uname()
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
index fe4182d..d6bffd0 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -29,18 +29,17 @@ import pprint
 import re
 import os
 import string
-import download
-import error
-import execute
-import git
-import log
-import macros
-import path
-import sources
 import sys
-import version
+from . import download
+from . import git
+from . import log
+from . import macros
+from . import path
 basepath = 'sb'
@@ -624,11 +623,6 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
     global host_windows
     global host_posix
-    # Adjust the args to remove the wrapper.
-    args = args[1:]
     # The path to this command.
@@ -649,7 +643,7 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
     overrides = None
     if os.name == 'nt':
         try:
-            import windows
+            from . import windows
             overrides = windows.load()
             host_windows = True
             host_posix = False
@@ -659,26 +653,26 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
         uname = os.uname()
         try:
             if uname[0].startswith('MINGW64_NT'):
-                import windows
                 host_windows = True
             elif uname[0].startswith('CYGWIN_NT'):
-                import windows
             elif uname[0] == 'Darwin':
-                import darwin
+                from . import darwin
                 overrides = darwin.load()
             elif uname[0] == 'FreeBSD':
-                import freebsd
+                from . import freebsd
                 overrides = freebsd.load()
             elif uname[0] == 'NetBSD':
-                import netbsd
+                from . import netbsd
                 overrides = netbsd.load()
             elif uname[0] == 'Linux':
-                import linux
+                from . import linux
                 overrides = linux.load()
             elif uname[0] == 'SunOS':
-                import solaris
+                from . import solaris
                 overrides = solaris.load()
         except error.general as ge:
             raise error.general('failed to load %s host support: %s' % (uname[0], ge))
@@ -721,7 +715,9 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
 def run(args):
     try:
-        _opts = load(args = args, defaults = 'defaults.mc')
+        dpath = path.dirname(args[0])
+        _opts = load(args = args,
+                     defaults = path.join(dpath, 'defaults.mc'))
         log.notice('RTEMS Source Builder - Defaults, %s' % (version.string()))
         _opts.log_info()
         log.notice('Options:')
diff --git a/source-builder/sb/path.py b/source-builder/sb/path.py
index 93852c8..b27cf14 100644
--- a/source-builder/sb/path.py
+++ b/source-builder/sb/path.py
@@ -25,14 +25,14 @@
-import log
 import os
 import shutil
 import stat
 import string
 import sys
-import error
+from . import log
 windows_posix = sys.platform == 'msys'
 windows = os.name == 'nt'
diff --git a/source-builder/sb/pkgconfig.py b/source-builder/sb/pkgconfig.py
index 99646f7..89b4d5c 100755
--- a/source-builder/sb/pkgconfig.py
+++ b/source-builder/sb/pkgconfig.py
@@ -43,7 +43,7 @@ import re
 import shlex
 import sys
-import path
+from . import path
 def default_prefix(common = True):
     paths = []
@@ -214,7 +214,12 @@ class package(object):
             prefix = default_prefix()
         if prefix:
             self._log('prefix: %s' % (prefix))
-            if type(prefix) is str or type(prefix) is unicode:
+            try:
+                if type(prefix) is unicode:
+                    prefix = prefix.decode("utf-8", "ignore")
+            except:
+                pass
+            if type(prefix) is str:
                 prefix = str(prefix)
                 self.prefix = []
                 for p in prefix.split(os.pathsep):
diff --git a/source-builder/sb/python-wrapper.sh b/source-builder/sb/python-wrapper.sh
deleted file mode 100644
index c736a66..0000000
--- a/source-builder/sb/python-wrapper.sh
+++ /dev/null
@@ -1,39 +0,0 @@
-set -e
-if test ! -f $PYTHON_CMD; then
-  echo "error: python command not found: $PYTHON_CMD"
-  exit 5
-fi
-for py in python2 python2.7 python3 python
-do
-  set +e
-  py_cmd=$(command -v $py)
-  set -e
-  if test -n "$RTEMS_PYTHON_OVERRIDE"; then
-    if test "$RTEMS_PYTHON_OVERRIDE" != "$py"; then
-      py_cmd=""
-    fi
-  fi
-  if test -n "$py_cmd"; then
-    exec $py_cmd $PYTHON_CMD $0 $*
-  fi
-done
-echo "error: no valid python found"
-exit 5
diff --git a/source-builder/sb/reports.py b/source-builder/sb/reports.py
index e7870c4..34474f3 100644
--- a/source-builder/sb/reports.py
+++ b/source-builder/sb/reports.py
@@ -34,17 +34,17 @@ import pprint
 pp = pprint.PrettyPrinter(indent = 2)
 try:
-    import build
-    import check
-    import config
-    import error
-    import git
-    import log
-    import options
-    import path
-    import setbuilder
-    import sources
-    import version
+    from . import git
+    from . import log
+    from . import setbuilder
     sys.exit(1)
diff --git a/source-builder/sb/rtemsconfig.py b/source-builder/sb/rtemsconfig.py
index 97ede7f..0ad6c5c 100644
--- a/source-builder/sb/rtemsconfig.py
+++ b/source-builder/sb/rtemsconfig.py
@@ -28,11 +28,11 @@ import sys
 import threading
 import time
-import error
-import log
-import options
-import path
-import version
+from . import log
+from . import path
 def _collect(path_, file):
     confs = []
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index a6efd75..02901d4 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -33,17 +33,17 @@ import sys
 import textwrap
 try:
-    import build
-    import check
-    import error
-    import log
-    import mailer
-    import options
-    import path
-    import reports
-    import shell
-    import sources
-    import version
+    from . import log
+    from . import mailer
+    from . import reports
+    from . import shell
     sys.exit(1)
diff --git a/source-builder/sb/shell.py b/source-builder/sb/shell.py
index bebbe8a..f1e669a 100644
--- a/source-builder/sb/shell.py
+++ b/source-builder/sb/shell.py
@@ -25,10 +25,10 @@
 try:
-    import error
-    import execute
-    import log
-    import options
+    from . import log
     sys.exit(1)
diff --git a/source-builder/sb/simhost.py b/source-builder/sb/simhost.py
index 13ab157..e3f759b 100644
--- a/source-builder/sb/simhost.py
+++ b/source-builder/sb/simhost.py
@@ -29,15 +29,15 @@ import datetime
 import os
 try:
-    import build
-    import check
-    import error
-    import git
-    import log
-    import macros
-    import path
-    import sources
-    import version
+    from . import git
+    from . import log
+    from . import macros
     sys.exit(1)
@@ -160,7 +160,7 @@ def find_bset_config(bset_config, macros):
 class options(object):
     def __init__(self, argv, argopts, defaults, extras):
-        command_path = path.dirname(path.abspath(argv[1]))
+        command_path = path.dirname(path.abspath(argv[0]))
         if len(command_path) == 0:
             command_path = '.'
         self.command_path = command_path
@@ -190,7 +190,7 @@ class options(object):
         overrides = None
         if os.name == 'nt':
             try:
-                import windows
                 host_windows = True
                 host_posix = False
@@ -200,26 +200,26 @@ class options(object):
             uname = os.uname()
             try:
-                    import windows
                     host_windows = True
-                    import windows
-                    import darwin
-                    import freebsd
-                    import netbsd
-                    import linux
-                    import solaris
diff --git a/source-builder/sb/solaris.py b/source-builder/sb/solaris.py
index 8d9498a..231fd34 100644
--- a/source-builder/sb/solaris.py
+++ b/source-builder/sb/solaris.py
@@ -25,9 +25,9 @@
 import pprint
 import os
-import check
-import error
-import execute
 def load():
     uname = os.uname()
diff --git a/source-builder/sb/sources.py b/source-builder/sb/sources.py
index a619778..1d62cb7 100644
--- a/source-builder/sb/sources.py
+++ b/source-builder/sb/sources.py
@@ -21,7 +21,7 @@
 # Manage sources and patches
-import log
+from . import log
 def _args(args):
     return [i for s in [ii.split() for ii in args] for i in s]
diff --git a/source-builder/sb/track.py b/source-builder/sb/track.py
index aef25b9..49344fe 100644
--- a/source-builder/sb/track.py
+++ b/source-builder/sb/track.py
@@ -31,12 +31,12 @@ import os
 import sys
 try:
-    import build
-    import error
-    import git
-    import log
-    import simhost
-    import version
+    from . import git
+    from . import log
     sys.exit(1)
@@ -138,7 +138,7 @@ def run(args = sys.argv):
         log.notice('RTEMS Source Builder - Track Dependencies, %s' % (version.string()))
diff --git a/source-builder/sb/version.py b/source-builder/sb/version.py
index 721c459..29d2dc5 100644
--- a/source-builder/sb/version.py
+++ b/source-builder/sb/version.py
@@ -76,9 +76,9 @@ from __future__ import print_function
 import os
 import sys
-import error
-import git
-import path
+from . import git
+from . import path
 # Default to an internal string.
diff --git a/source-builder/sb/windows.py b/source-builder/sb/windows.py
index 1eb51a0..ceca24f 100644
--- a/source-builder/sb/windows.py
+++ b/source-builder/sb/windows.py
@@ -24,9 +24,9 @@
 import os
 import sys
-import error
-import execute
-import path
+from . import path
 def load():
     # Default to the native Windows Python.
2.24.1
