[PATCH] sb: Use shebang env python
Wed Aug 26 15:10:09 UTC 2020
thanks, some of this is rewriting shell script to python, and fixing
up imports. I'd prefer to have these separated, but it's probably fine
I took a quick skim over all of it.
On Tue, Aug 25, 2020 at 5:24 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Closes #4037
>  source-builder/pkg-config             | 236 +++++++++++++++++++++++---
>  source-builder/sb-check               |  24 +--
>  source-builder/sb-defaults            |  23 +--
>  source-builder/sb-get-sources         |  23 +--
>  source-builder/sb-reports             |  23 +--
>  source-builder/sb-rtems-config        |  23 +--
>  source-builder/sb-set-builder         |  22 +--
>  source-builder/sb-track               |  22 +--
>  source-builder/sb/build.py            |  22 +--
>  source-builder/sb/check.py            |  16 +-
>  source-builder/sb/cmd-check.py        |  29 ----
>  source-builder/sb/cmd-defaults.py     |  29 ----
>  source-builder/sb/cmd-get-sources.py  |  29 ----
>  source-builder/sb/cmd-pkg-config.py   | 220 ------------------------
>  source-builder/sb/cmd-reports.py      |  29 ----
>  source-builder/sb/cmd-rtems-config.py |  29 ----
>  source-builder/sb/cmd-set-builder.py  |  29 ----
>  source-builder/sb/cmd-track.py        |  29 ----
>  source-builder/sb/config.py           |  16 +-
>  source-builder/sb/cvs.py              |  10 +-
>  source-builder/sb/darwin.py           |   2 +-
>  source-builder/sb/download.py         |  14 +-
>  source-builder/sb/ereport.py          |   4 +-
>  source-builder/sb/execute.py          |   4 +-
>  source-builder/sb/freebsd.py          |   6 +-
>  source-builder/sb/getsources.py       |  12 +-
>  source-builder/sb/git.py              |  13 +-
>  source-builder/sb/linux.py            |   4 +-
>  source-builder/sb/log.py              |   2 +-
>  source-builder/sb/macros.py           |   4 +-
>  source-builder/sb/mailer.py           |   6 +-
>  source-builder/sb/netbsd.py           |   4 +-
>  source-builder/sb/options.py          |  44 +++--
>  source-builder/sb/path.py             |   4 +-
>  source-builder/sb/pkgconfig.py        |   9 +-
>  source-builder/sb/python-wrapper.sh   |  39 -----
>  source-builder/sb/reports.py          |  22 +--
>  source-builder/sb/rtemsconfig.py      |  10 +-
>  source-builder/sb/setbuilder.py       |  22 +--
>  source-builder/sb/shell.py            |   8 +-
>  source-builder/sb/simhost.py          |  36 ++--
>  source-builder/sb/solaris.py          |   6 +-
>  source-builder/sb/sources.py          |   2 +-
>  source-builder/sb/track.py            |  14 +-
>  source-builder/sb/version.py          |   6 +-
>  source-builder/sb/windows.py          |   6 +-
>  46 files changed, 471 insertions(+), 715 deletions(-)
>  delete mode 100755 source-builder/sb/cmd-check.py
>  delete mode 100755 source-builder/sb/cmd-defaults.py
>  delete mode 100755 source-builder/sb/cmd-get-sources.py
>  delete mode 100755 source-builder/sb/cmd-pkg-config.py
>  delete mode 100755 source-builder/sb/cmd-reports.py
>  delete mode 100755 source-builder/sb/cmd-rtems-config.py
>  delete mode 100755 source-builder/sb/cmd-set-builder.py
>  delete mode 100755 source-builder/sb/cmd-track.py
>  delete mode 100644 source-builder/sb/python-wrapper.sh
> diff --git a/source-builder/pkg-config b/source-builder/pkg-config
> index 65ee307..10db546 100755
> --- a/source-builder/pkg-config
> +++ b/source-builder/pkg-config
> @@ -1,27 +1,221 @@
> -#! /bin/sh
> +#! /usr/bin/env python
>  # RTEMS Tools Project (http://www.rtems.org/)
> -# Copyright 2018 Chris Johns (chrisj at rtems.org)
> +# Copyright 2014-2016 Chris Johns (chrisj at rtems.org)
>  # All rights reserved.
>  # This file is part of the RTEMS Tools package in 'rtems-tools'.
> -# Permission to use, copy, modify, and/or distribute this software for any
> -# purpose with or without fee is hereby granted, provided that the above
> -# copyright notice and this permission notice appear in all copies.
> -# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
> -# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
> -# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
> -# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
> -# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
> -# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
> -# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-pkg-config.py
> -if test -f ${base}/sb/python-wrapper.sh; then
> -  . ${base}/sb/python-wrapper.sh
> -fi
> -echo "error: python wrapper not found"
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +from __future__ import print_function
> +import os
> +import sys
> +base = os.path.dirname(sys.argv[0])
> +try:
> +    import argparse
> +except:
> +    sys.path.insert(0, base + '/sb/imports')
> +    try:
> +        import argparse
> +    except:
> +        print("Incorrect Source Builder installation", file = sys.stderr)
> +        sys.exit(1)
> +import sb.pkgconfig
> +# Make trace true to get a file of what happens and what is being asked.
> +trace = False
> +trace_stdout = False
> +logfile = 'pkg-config.log'
> +out = None
> +srcfd = None
> +# Write all the package source parsed to a single file.
> +trace_src = False
> +if trace_src:
> +    srcfd = open('pkg-src.txt', 'w')
> +def src(text):
> +    if srcfd:
> +        srcfd.writelines(text)
> +def log(s, lf = True):
> +    global trace, logfile, out
> +    if trace:
> +        if out is None:
> +            if logfile:
> +                out = open(logfile, 'a')
> +            else:
> +                out = sys.stdout
> +        if lf:
> +            if out != sys.stdout and trace_stdout:
> +                print(s)
> +            print(s, file = out)
> +        else:
> +                print(s, end = '')
> +                sys.stdout.flush()
> +            print(s, end = '', file = out)
> +def run(argv):
> +    class version_action(argparse.Action):
> +        def __call__(self, parser, namespace, values, option_string = None):
> +            parts = values[0].strip().split('.')
> +            for p in parts:
> +                if not p.isdigit():
> +                    raise error('invalid version value: %s' % (values))
> +            setattr(namespace, self.dest, '.'.join(parts))
> +    ec = 0
> +    opts = argparse.ArgumentParser(prog = 'pkg-config', description = 'Package Configuration.')
> +    opts.add_argument('libraries', metavar='lib', type = str,  help = 'a library', nargs = '*')
> +    opts.add_argument('--modversion', dest = 'modversion', action = 'store', default = None,
> +                      help = 'Requests that the version information of the libraries.')
> +    opts.add_argument('--print-errors', dest = 'print_errors', action = 'store_true',
> +                      default = False,
> +                      help = 'Print any errors.')
> +    opts.add_argument('--short-errors', dest = 'short_errors', action = 'store_true',
> +                      default = False,
> +                      help = 'Make error messages short.')
> +    opts.add_argument('--silence-errors', dest = 'silence_errors', action = 'store_true',
> +                      default = False,
> +                      help = 'Do not print any errors.')
> +    opts.add_argument('--errors-to-stdout', dest = 'errors_to_stdout', action = 'store_true',
> +                      default = False,
> +                      help = 'Print errors to stdout rather than stderr.')
> +    opts.add_argument('--cflags', dest = 'cflags', action = 'store_true',
> +                      default = False,
> +                      help = 'This prints pre-processor and compile flags required to' \
> +                             ' compile the package(s)')
> +    opts.add_argument('--libs', dest = 'libs', action = 'store_true',
> +                      default = False,
> +                      help = 'This option is identical to "--cflags", only it prints the' \
> +                             ' link flags.')
> +    opts.add_argument('--libs-only-L', dest = 'libs_only_L', action = 'store_true',
> +                      default = False,
> +                      help = 'This prints the -L/-R part of "--libs".')
> +    opts.add_argument('--libs-only-l', dest = 'libs_only_l', action = 'store_true',
> +                      default = False,
> +                      help = 'This prints the -l part of "--libs".')
> +    opts.add_argument('--variable', dest = 'variable', action = 'store',
> +                      nargs = 1, default = None,
> +                      help = 'This returns the value of a variable.')
> +    opts.add_argument('--define-variable', dest = 'define_variable', action = 'store',
> +                      help = 'This sets a global value for a variable')
> +    opts.add_argument('--uninstalled', dest = 'uninstalled', action = 'store_true',
> +                      default = False,
> +                      help = 'Ignored')
> +    opts.add_argument('--atleast-pkgconfig-version', dest = 'atleast_pkgconfig_version',
> +                      action = 'store', nargs = 1, default = None,
> +                      help = 'Check the version of package config. Always ok.')
> +    opts.add_argument('--exists', dest = 'exists', action = 'store_true',
> +                      default = False,
> +                      help = 'Test if a library is present')
> +    opts.add_argument('--atleast-version', dest = 'atleast_version',
> +                      action = version_action, nargs = 1, default = None,
> +                      help = 'The package is at least this version.')
> +    opts.add_argument('--exact-version', dest = 'exact_version', action = version_action,
> +                        help = 'The package is the exact version.')
> +    opts.add_argument('--max-version', dest = 'max_version', action = version_action,
> +                      help = 'The package is no later than this version.')
> +    opts.add_argument('--msvc-syntax', dest = 'msvc_syntax', action = 'store_true',
> +                      default = False,
> +                      help = 'Ignored')
> +    opts.add_argument('--dont-define-prefix', dest = 'dont_define_prefix', action = 'store_true',
> +                      default = False,
> +                      help = 'Ignored')
> +    opts.add_argument('--prefix-variable', dest = 'prefix', action = 'store',
> +                      nargs = 1, default = sb.pkgconfig.default_prefix(),
> +                      help = 'Define the prefix.')
> +    opts.add_argument('--static', dest = 'static', action = 'store_true',
> +                      default = False,
> +                      help = 'Output libraries suitable for static linking')
> +    opts.add_argument('--dump', dest = 'dump', action = 'store_true',
> +                      default = False,
> +                      help = 'Dump the package if one is found.')
> +    args = opts.parse_args(argv)
> +    if (args.exists and (args.exact_version or args.max_version)) or \
> +            (args.exact_version and (args.exists or args.max_version)) or \
> +            (args.max_version and (args.exists or args.exact_version)):
> +        raise error('only one of --exists, --exact-version, or --max-version')
> +    if args.dont_define_prefix:
> +        args.prefix = sb.pkgconfig.default_prefix(False)
> +    exists = False
> +    ec = 1
> +    if args.atleast_pkgconfig_version:
> +        ec = 0
> +    else:
> +        ec, pkg, flags = sb.pkgconfig.check_package(args.libraries, args, log, src)
> +        if ec == 0:
> +            if args.cflags:
> +                if len(flags['cflags']):
> +                    print(flags['cflags'])
> +                    log('cflags: %s' % (flags['cflags']))
> +                else:
> +                    log('cflags: empty')
> +            if args.libs:
> +                if len(flags['libs']):
> +                    print(flags['libs'])
> +                    log('libs: %s' % (flags['libs']))
> +                else:
> +                    log('libs: empty')
> +    #pkgconfig.package.dump_loaded()
> +    return ec
> +try:
> +    log('-' * 40)
> +    log('pkg-config', lf = False)
> +    for a in sys.argv[2:]:
> +        log(' "%s"' % (a), lf = False)
> +    log('')
> +    ec = run(sys.argv[1:])
> +    log('ec = %d' % (ec))
> +except ImportError:
> +    print("incorrect package config installation", file = sys.stderr)
> +    sys.exit(1)
> +except sb.pkgconfig.error as e:
> +    print('error: %s' % (e), file = sys.stderr)
> +    sys.exit(1)
> +sys.exit(ec)
> diff --git a/source-builder/sb-check b/source-builder/sb-check
> index b092697..b75767e 100755
> --- a/source-builder/sb-check
> +++ b/source-builder/sb-check
> @@ -1,7 +1,7 @@
> -#! /bin/sh
> +# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
> @@ -17,11 +17,15 @@
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-check.py
> -fi
> +import sb.check
> +try:
> +    import sb.check
> +    sb.check.run()
> +    import sys
> +    sys.exit(1)
> diff --git a/source-builder/sb-defaults b/source-builder/sb-defaults
> index 25437ba..2fd2121 100755
> --- a/source-builder/sb-defaults
> +++ b/source-builder/sb-defaults
> @@ -1,7 +1,7 @@
> -#! /bin/sh
> +# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
> @@ -17,11 +17,14 @@
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-defaults.py
> -fi
> +import sys
> +try:
> +    import sb.options
> +    sb.options.run(sys.argv)
> +    sys.exit(1)
> diff --git a/source-builder/sb-get-sources b/source-builder/sb-get-sources
> index d9f03b7..97ee419 100755
> --- a/source-builder/sb-get-sources
> +++ b/source-builder/sb-get-sources
> @@ -1,7 +1,7 @@
> -#! /bin/sh
> -# Copyright 2019 Chris Johns (chrisj at rtems.org)
> +# Copyright 2010-2019 Chris Johns (chrisj at rtems.org)
> @@ -17,11 +17,14 @@
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-get-sources.py
> -fi
> +try:
> +    import sb.getsources
> +    sb.getsources.run()
> +    import sys
> +    sys.exit(1)
> diff --git a/source-builder/sb-reports b/source-builder/sb-reports
> index 5fb02d1..194c4ab 100755
> --- a/source-builder/sb-reports
> +++ b/source-builder/sb-reports
> @@ -1,7 +1,7 @@
> -#! /bin/sh
> @@ -17,11 +17,14 @@
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-reports.py
> -fi
> +import sys
> +try:
> +    import sb.reports
> +    sb.reports.run(sys.argv)
> +    sys.exit(1)
> diff --git a/source-builder/sb-rtems-config b/source-builder/sb-rtems-config
> index 66a95f7..a84b9c8 100755
> --- a/source-builder/sb-rtems-config
> +++ b/source-builder/sb-rtems-config
> @@ -1,7 +1,7 @@
> -#! /bin/sh
> @@ -17,11 +17,14 @@
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-rtems-config.py
> -fi
> +import sys
> +try:
> +    import sb.rtemsconfig
> +    sb.rtemsconfig.run(sys.argv)
> +    sys.exit(1)
> diff --git a/source-builder/sb-set-builder b/source-builder/sb-set-builder
> index 6a196fe..96dd919 100755
> --- a/source-builder/sb-set-builder
> +++ b/source-builder/sb-set-builder
> @@ -1,7 +1,7 @@
> -#! /bin/sh
> @@ -17,11 +17,13 @@
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-set-builder.py
> -fi
> +try:
> +    import sb.setbuilder
> +    sb.setbuilder.run()
> +    import sys
> +    sys.exit(1)
> diff --git a/source-builder/sb-track b/source-builder/sb-track
> index a739978..64daeb8 100755
> --- a/source-builder/sb-track
> +++ b/source-builder/sb-track
> @@ -1,7 +1,7 @@
> -#! /bin/sh
> @@ -17,11 +17,13 @@
> -set -e
> -base=$(dirname $0)
> -PYTHON_CMD=${base}/sb/cmd-track.py
> -fi
> +try:
> +    import sb.track
> +    sb.track.run()
> +    import sys
> +    sys.exit(1)
> diff --git a/source-builder/sb/build.py b/source-builder/sb/build.py
> index cfb7d8c..f3253dd 100644
> --- a/source-builder/sb/build.py
> +++ b/source-builder/sb/build.py
> @@ -33,17 +33,17 @@ import stat
>  import sys
>  try:
> -    import check
> -    import config
> -    import download
> -    import error
> -    import ereport
> -    import execute
> -    import log
> -    import options
> -    import path
> -    import sources
> -    import version
> +    from . import check
> +    from . import config
> +    from . import download
> +    from . import error
> +    from . import ereport
> +    from . import execute
> +    from . import log
> +    from . import options
> +    from . import path
> +    from . import sources
> +    from . import version
>  except KeyboardInterrupt:
>      print('abort: user terminated')
>      sys.exit(1)
> diff --git a/source-builder/sb/check.py b/source-builder/sb/check.py
> index be808ea..7e23223 100644
> --- a/source-builder/sb/check.py
> +++ b/source-builder/sb/check.py
> @@ -23,16 +23,16 @@
> -import os
> -import error
> -import execute
>  import fnmatch
> -import log
> -import options
> -import path
> +import os
>  import re
> -import version
> +from . import error
> +from . import execute
> +from . import log
> +from . import options
> +from . import path
> +from . import version
>  def _check_none(_opts, macro, value, constraint):
>      return True
> diff --git a/source-builder/sb/cmd-check.py b/source-builder/sb/cmd-check.py
> deleted file mode 100755
> index 4525dbb..0000000
> --- a/source-builder/sb/cmd-check.py
> +++ /dev/null
> @@ -1,29 +0,0 @@
> -# RTEMS Tools Project (http://www.rtems.org/)
> -# Copyright 2010-2012 Chris Johns (chrisj at rtems.org)
> -# All rights reserved.
> -# This file is part of the RTEMS Tools package in 'rtems-tools'.
> -from __future__ import print_function
> -import sys, os
> -try:
> -    import check
> -    check.run()
> -except ImportError:
> -    print("Incorrect Source Builder installation", file = sys.stderr)
> -    sys.exit(1)
> diff --git a/source-builder/sb/cmd-defaults.py b/source-builder/sb/cmd-defaults.py
> index 0b2b357..0000000
> --- a/source-builder/sb/cmd-defaults.py
> +++ /dev/null
> @@ -1,29 +0,0 @@
> -# Copyright 2010-2013 Chris Johns (chrisj at rtems.org)
> -import sys, os
> -try:
> -    import options
> -    options.run(sys.argv)
> -    sys.exit(1)
> diff --git a/source-builder/sb/cmd-get-sources.py b/source-builder/sb/cmd-get-sources.py
> index 480e81d..0000000
> --- a/source-builder/sb/cmd-get-sources.py
> +++ /dev/null
> @@ -1,29 +0,0 @@
> -# Copyright 2010-2019 Chris Johns (chrisj at rtems.org)
> -import sys, os
> -try:
> -    import getsources
> -    getsources.run()
> -    sys.exit(1)
> diff --git a/source-builder/sb/cmd-pkg-config.py b/source-builder/sb/cmd-pkg-config.py
> index 68c67cf..0000000
> --- a/source-builder/sb/cmd-pkg-config.py
> +++ /dev/null
> @@ -1,220 +0,0 @@
> -# Copyright 2014-2016 Chris Johns (chrisj at rtems.org)
> -# Redistribution and use in source and binary forms, with or without
> -# modification, are permitted provided that the following conditions are met:
> -# 1. Redistributions of source code must retain the above copyright notice,
> -# this list of conditions and the following disclaimer.
> -# 2. Redistributions in binary form must reproduce the above copyright notice,
> -# this list of conditions and the following disclaimer in the documentation
> -# and/or other materials provided with the distribution.
> -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> -# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> -# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> -# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> -# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> -# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> -# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> -# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> -# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> -# POSSIBILITY OF SUCH DAMAGE.
> -import os
> -import sys
> -base = os.path.dirname(sys.argv[1])
> -try:
> -    import argparse
> -except:
> -    sys.path.insert(0, base + '/sb/imports')
> -    try:
> -        import argparse
> -    except:
> -        sys.exit(1)
> -import pkgconfig
> -# Make trace true to get a file of what happens and what is being asked.
> -trace = False
> -trace_stdout = False
> -logfile = 'pkg-config.log'
> -out = None
> -srcfd = None
> -# Write all the package source parsed to a single file.
> -trace_src = False
> -if trace_src:
> -    srcfd = open('pkg-src.txt', 'w')
> -def src(text):
> -    if srcfd:
> -        srcfd.writelines(text)
> -def log(s, lf = True):
> -    global trace, logfile, out
> -    if trace:
> -        if out is None:
> -            if logfile:
> -                out = open(logfile, 'a')
> -            else:
> -                out = sys.stdout
> -        if lf:
> -            if out != sys.stdout and trace_stdout:
> -                print(s)
> -            print(s, file = out)
> -        else:
> -                print(s, end = '')
> -                sys.stdout.flush()
> -            print(s, end = '', file = out)
> -def run(argv):
> -    class version_action(argparse.Action):
> -        def __call__(self, parser, namespace, values, option_string = None):
> -            parts = values[0].strip().split('.')
> -            for p in parts:
> -                if not p.isdigit():
> -                    raise error('invalid version value: %s' % (values))
> -            setattr(namespace, self.dest, '.'.join(parts))
> -    ec = 0
> -    opts = argparse.ArgumentParser(prog = 'pkg-config', description = 'Package Configuration.')
> -    opts.add_argument('libraries', metavar='lib', type = str,  help = 'a library', nargs = '*')
> -    opts.add_argument('--modversion', dest = 'modversion', action = 'store', default = None,
> -                      help = 'Requests that the version information of the libraries.')
> -    opts.add_argument('--print-errors', dest = 'print_errors', action = 'store_true',
> -                      default = False,
> -                      help = 'Print any errors.')
> -    opts.add_argument('--short-errors', dest = 'short_errors', action = 'store_true',
> -                      default = False,
> -                      help = 'Make error messages short.')
> -    opts.add_argument('--silence-errors', dest = 'silence_errors', action = 'store_true',
> -                      default = False,
> -                      help = 'Do not print any errors.')
> -    opts.add_argument('--errors-to-stdout', dest = 'errors_to_stdout', action = 'store_true',
> -                      default = False,
> -                      help = 'Print errors to stdout rather than stderr.')
> -    opts.add_argument('--cflags', dest = 'cflags', action = 'store_true',
> -                      default = False,
> -                      help = 'This prints pre-processor and compile flags required to' \
> -                             ' compile the package(s)')
> -    opts.add_argument('--libs', dest = 'libs', action = 'store_true',
> -                      default = False,
> -                      help = 'This option is identical to "--cflags", only it prints the' \
> -                             ' link flags.')
> -    opts.add_argument('--libs-only-L', dest = 'libs_only_L', action = 'store_true',
> -                      default = False,
> -                      help = 'This prints the -L/-R part of "--libs".')
> -    opts.add_argument('--libs-only-l', dest = 'libs_only_l', action = 'store_true',
> -                      default = False,
> -                      help = 'This prints the -l part of "--libs".')
> -    opts.add_argument('--variable', dest = 'variable', action = 'store',
> -                      nargs = 1, default = None,
> -                      help = 'This returns the value of a variable.')
> -    opts.add_argument('--define-variable', dest = 'define_variable', action = 'store',
> -                      help = 'This sets a global value for a variable')
> -    opts.add_argument('--uninstalled', dest = 'uninstalled', action = 'store_true',
> -                      default = False,
> -                      help = 'Ignored')
> -    opts.add_argument('--atleast-pkgconfig-version', dest = 'atleast_pkgconfig_version',
> -                      action = 'store', nargs = 1, default = None,
> -                      help = 'Check the version of package config. Always ok.')
> -    opts.add_argument('--exists', dest = 'exists', action = 'store_true',
> -                      default = False,
> -                      help = 'Test if a library is present')
> -    opts.add_argument('--atleast-version', dest = 'atleast_version',
> -                      action = version_action, nargs = 1, default = None,
> -                      help = 'The package is at least this version.')
> -    opts.add_argument('--exact-version', dest = 'exact_version', action = version_action,
> -                        help = 'The package is the exact version.')
> -    opts.add_argument('--max-version', dest = 'max_version', action = version_action,
> -                      help = 'The package is no later than this version.')
> -    opts.add_argument('--msvc-syntax', dest = 'msvc_syntax', action = 'store_true',
> -                      default = False,
> -                      help = 'Ignored')
> -    opts.add_argument('--dont-define-prefix', dest = 'dont_define_prefix', action = 'store_true',
> -                      default = False,
> -                      help = 'Ignored')
> -    opts.add_argument('--prefix-variable', dest = 'prefix', action = 'store',
> -                      nargs = 1, default = pkgconfig.default_prefix(),
> -                      help = 'Define the prefix.')
> -    opts.add_argument('--static', dest = 'static', action = 'store_true',
> -                      default = False,
> -                      help = 'Output libraries suitable for static linking')
> -    opts.add_argument('--dump', dest = 'dump', action = 'store_true',
> -                      default = False,
> -                      help = 'Dump the package if one is found.')
> -    args = opts.parse_args(argv[1:])
> -    if (args.exists and (args.exact_version or args.max_version)) or \
> -            (args.exact_version and (args.exists or args.max_version)) or \
> -            (args.max_version and (args.exists or args.exact_version)):
> -        raise error('only one of --exists, --exact-version, or --max-version')
> -    if args.dont_define_prefix:
> -        args.prefix = pkgconfig.default_prefix(False)
> -    exists = False
> -    ec = 1
> -    if args.atleast_pkgconfig_version:
> -        ec = 0
> -    else:
> -        ec, pkg, flags = pkgconfig.check_package(args.libraries, args, log, src)
> -        if ec == 0:
> -            if args.cflags:
> -                if len(flags['cflags']):
> -                    print(flags['cflags'])
> -                    log('cflags: %s' % (flags['cflags']))
> -                else:
> -                    log('cflags: empty')
> -            if args.libs:
> -                if len(flags['libs']):
> -                    print(flags['libs'])
> -                    log('libs: %s' % (flags['libs']))
> -                else:
> -                    log('libs: empty')
> -    #pkgconfig.package.dump_loaded()
> -    return ec
> -try:
> -    log('-' * 40)
> -    log('pkg-config', lf = False)
> -    for a in sys.argv[2:]:
> -        log(' "%s"' % (a), lf = False)
> -    log('')
> -    ec = run(sys.argv[1:])
> -    log('ec = %d' % (ec))
> -    print("incorrect package config installation", file = sys.stderr)
> -    sys.exit(1)
> -except pkgconfig.error as e:
> -    print('error: %s' % (e), file = sys.stderr)
> -    sys.exit(1)
> -sys.exit(ec)
> diff --git a/source-builder/sb/cmd-reports.py b/source-builder/sb/cmd-reports.py
> index 4c41e33..0000000
> --- a/source-builder/sb/cmd-reports.py
> +++ /dev/null
> @@ -1,29 +0,0 @@
> -import sys, os
> -try:
> -    import reports
> -    reports.run(sys.argv)
> -    sys.exit(1)
> diff --git a/source-builder/sb/cmd-rtems-config.py b/source-builder/sb/cmd-rtems-config.py
> index f29ef04..0000000
> --- a/source-builder/sb/cmd-rtems-config.py
> +++ /dev/null
> @@ -1,29 +0,0 @@
> -import sys, os
> -try:
> -    import rtemsconfig
> -    rtemsconfig.run(sys.argv)
> -    sys.exit(1)
> diff --git a/source-builder/sb/cmd-set-builder.py b/source-builder/sb/cmd-set-builder.py
> index 56114cd..0000000
> --- a/source-builder/sb/cmd-set-builder.py
> +++ /dev/null
> @@ -1,29 +0,0 @@
> -import sys, os
> -try:
> -    import setbuilder
> -    setbuilder.run()
> -    sys.exit(1)
> diff --git a/source-builder/sb/cmd-track.py b/source-builder/sb/cmd-track.py
> index 82615a5..0000000
> --- a/source-builder/sb/cmd-track.py
> +++ /dev/null
> @@ -1,29 +0,0 @@
> -import sys, os
> -try:
> -    import track
> -    track.run()
> -    sys.exit(1)
> diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
> index f8854a5..db795b3 100644
> --- a/source-builder/sb/config.py
> +++ b/source-builder/sb/config.py
> @@ -34,13 +34,13 @@ import re
>  import sys
>  try:
> -    import error
> -    import execute
> -    import log
> -    import options
> -    import path
> -    import pkgconfig
> -    import sources
> +    from . import log
> +    from . import pkgconfig
>      print('user terminated', file = sys.stderr)
>      sys.exit(1)
> @@ -500,6 +500,7 @@ class file:
>              except pkgconfig.error as pe:
>                  self._error('pkgconfig: check: %s' % (pe))
>              except:
> +                raise
>                  raise error.internal('pkgconfig failure')
>          if ok:
>              return '1'
> @@ -524,6 +525,7 @@ class file:
>                  self._error('pkgconfig: %s:  %s' % (flags, pe))
>              except:
> +                raise
>          if pkg_flags is None:
>              pkg_flags = ''
> diff --git a/source-builder/sb/cvs.py b/source-builder/sb/cvs.py
> index 2ff7417..673488e 100644
> --- a/source-builder/sb/cvs.py
> +++ b/source-builder/sb/cvs.py
> @@ -25,11 +25,10 @@ from __future__ import print_function
>  import os
> -import error
> -import execute
> -import log
> -import options
> -import path
> +from . import log
> +from . import path
>  class repo:
>      """An object to manage a cvs repo."""
> @@ -147,6 +146,7 @@ class repo:
>  if __name__ == '__main__':
>      import sys
>      opts = options.load(sys.argv, defaults = 'defaults.mc')
>      ldir = 'cvs-test-rm-me'
>      c = repo(ldir, opts)
> diff --git a/source-builder/sb/darwin.py b/source-builder/sb/darwin.py
> index a21a6bc..95a2a4e 100644
> --- a/source-builder/sb/darwin.py
> +++ b/source-builder/sb/darwin.py
> @@ -24,7 +24,7 @@
>  import os
> -import execute
>  def load():
>      uname = os.uname()
> diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
> index 3aaa701..410edeb 100644
> --- a/source-builder/sb/download.py
> +++ b/source-builder/sb/download.py
> @@ -37,13 +37,13 @@ except ImportError:
>      import urllib2 as urllib_request
>      import urlparse as urllib_parse
> -import cvs
> -import error
> -import git
> -import log
> -import path
> -import sources
> -import version
> +from . import cvs
> +from . import git
> +from . import log
> +from . import path
> +from . import sources
>  def _do_download(opts):
>      download = True
> diff --git a/source-builder/sb/ereport.py b/source-builder/sb/ereport.py
> index 475eff7..d8fb5f6 100755
> --- a/source-builder/sb/ereport.py
> +++ b/source-builder/sb/ereport.py
> @@ -25,8 +25,8 @@ from __future__ import print_function
>  import os
> -import error
> -import log
> +from . import log
>  def generate(name, opts, header = None, footer = None):
>      label, result = opts.with_arg('error-report')
> diff --git a/source-builder/sb/execute.py b/source-builder/sb/execute.py
> index 06f9b7d..3db9abc 100755
> --- a/source-builder/sb/execute.py
> +++ b/source-builder/sb/execute.py
> @@ -36,8 +36,8 @@ import threading
>  import time
>  import traceback
> -import error
> -import log
> +from . import log
>  # Trace exceptions
>  trace_threads = False
> diff --git a/source-builder/sb/freebsd.py b/source-builder/sb/freebsd.py
> index 5497e75..472f670 100644
> --- a/source-builder/sb/freebsd.py
> +++ b/source-builder/sb/freebsd.py
> @@ -27,9 +27,9 @@
>  import pprint
>  import os
> -import check
> -import error
> -import execute
> +from . import check
>  def load():
>      uname = os.uname()
> diff --git a/source-builder/sb/getsources.py b/source-builder/sb/getsources.py
> index 7d76038..0ccf257 100644
> --- a/source-builder/sb/getsources.py
> +++ b/source-builder/sb/getsources.py
> @@ -31,11 +31,11 @@ import os
>  import sys
>  try:
> -    import build
> -    import error
> -    import log
> -    import simhost
> -    import version
> +    from . import build
> +    from . import log
> +    from . import simhost
>      print('abort: user terminated', file = sys.stderr)
>      sys.exit(1)
> @@ -76,7 +76,7 @@ def run(args = sys.argv):
>                             action = 'store_true')
>          argsp.add_argument('bsets', nargs='*', help = 'Build sets.')
> -        argopts = argsp.parse_args(args[2:])
> +        argopts = argsp.parse_args(args[1:])
>          simhost.load_log(argopts.log)
>          log.notice('RTEMS Source Builder - Get Sources, %s' % (version.string()))
> diff --git a/source-builder/sb/git.py b/source-builder/sb/git.py
> index 52bcb83..237e690 100644
> --- a/source-builder/sb/git.py
> +++ b/source-builder/sb/git.py
>  import os
> -import error
> -import execute
> -import log
> -import options
> -import path
> +from . import log
> +from . import path
>  class repo:
>      """An object to manage a git repo."""
> @@ -230,7 +229,9 @@ class repo:
>      import os.path
>      import sys
> -    defaults = path.join(path.dirname(path.dirname(path.shell(sys.argv[0]))), 'defaults.mc')
> +    defaults = path.join(path.dirname(path.dirname(path.shell(sys.argv[0]))),
> +                         'defaults.mc')
>      opts = options.load(sys.argv, defaults = defaults)
>      g = repo('.', opts)
>      print('g.git_version():', g.git_version())
> diff --git a/source-builder/sb/linux.py b/source-builder/sb/linux.py
> index 791bbd6..d773818 100644
> --- a/source-builder/sb/linux.py
> +++ b/source-builder/sb/linux.py
> @@ -26,8 +26,8 @@ import multiprocessing
>  import pprint
>  import os
> -import platform
> -import path
> +from . import platform
> +from . import path
>  def load():
>      uname = os.uname()
> diff --git a/source-builder/sb/log.py b/source-builder/sb/log.py
> index 788160e..7ad4763 100755
> --- a/source-builder/sb/log.py
> +++ b/source-builder/sb/log.py
> @@ -26,7 +26,7 @@ from __future__ import print_function
>  import os
>  import sys
> -import error
>  # A global log.
> diff --git a/source-builder/sb/macros.py b/source-builder/sb/macros.py
> index 5a639b8..6ca87ed 100644
> --- a/source-builder/sb/macros.py
> +++ b/source-builder/sb/macros.py
> @@ -27,8 +27,8 @@ import re
>  import os
>  import string
> -import error
> -import path
> +from . import path
>  # Macro tables
> diff --git a/source-builder/sb/mailer.py b/source-builder/sb/mailer.py
> index 42b4fa6..ff25df5 100644
> --- a/source-builder/sb/mailer.py
> +++ b/source-builder/sb/mailer.py
> @@ -27,9 +27,9 @@ import os
>  import smtplib
>  import socket
> -import error
> -import options
> -import path
> +from . import path
>  def append_options(opts):
>      opts['--mail'] = 'Send email report or results.'
> diff --git a/source-builder/sb/netbsd.py b/source-builder/sb/netbsd.py
> index c7420c3..3398290 100644
> --- a/source-builder/sb/netbsd.py
> +++ b/source-builder/sb/netbsd.py
> @@ -27,8 +27,8 @@
>  import pprint
>  import os
> -import check
> -import execute
>  def load():
>      uname = os.uname()
> diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> index fe4182d..d6bffd0 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -29,18 +29,17 @@ import pprint
>  import re
>  import os
>  import string
> -import download
> -import error
> -import execute
> -import git
> -import log
> -import macros
> -import path
> -import sources
>  import sys
> -import version
> +from . import download
> +from . import git
> +from . import log
> +from . import macros
> +from . import path
>  basepath = 'sb'
> @@ -624,11 +623,6 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
>      global host_windows
>      global host_posix
> -    # Adjust the args to remove the wrapper.
> -    args = args[1:]
>      # The path to this command.
> @@ -649,7 +643,7 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
>      overrides = None
>      if os.name == 'nt':
>          try:
> -            import windows
> +            from . import windows
>              overrides = windows.load()
>              host_windows = True
>              host_posix = False
> @@ -659,26 +653,26 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
>          uname = os.uname()
>          try:
>              if uname[0].startswith('MINGW64_NT'):
> -                import windows
>                  host_windows = True
>              elif uname[0].startswith('CYGWIN_NT'):
> -                import windows
>              elif uname[0] == 'Darwin':
> -                import darwin
> +                from . import darwin
>                  overrides = darwin.load()
>              elif uname[0] == 'FreeBSD':
> -                import freebsd
> +                from . import freebsd
>                  overrides = freebsd.load()
>              elif uname[0] == 'NetBSD':
> -                import netbsd
> +                from . import netbsd
>                  overrides = netbsd.load()
>              elif uname[0] == 'Linux':
> -                import linux
> +                from . import linux
>                  overrides = linux.load()
>              elif uname[0] == 'SunOS':
> -                import solaris
> +                from . import solaris
>                  overrides = solaris.load()
>          except error.general as ge:
>              raise error.general('failed to load %s host support: %s' % (uname[0], ge))
> @@ -721,7 +715,9 @@ def load(args, optargs = None, defaults = '%{_sbdir}/defaults.mc', logfile = Tru
>  def run(args):
>      try:
> -        _opts = load(args = args, defaults = 'defaults.mc')
> +        dpath = path.dirname(args[0])
> +        _opts = load(args = args,
> +                     defaults = path.join(dpath, 'defaults.mc'))
>          log.notice('RTEMS Source Builder - Defaults, %s' % (version.string()))
>          _opts.log_info()
>          log.notice('Options:')
> diff --git a/source-builder/sb/path.py b/source-builder/sb/path.py
> index 93852c8..b27cf14 100644
> --- a/source-builder/sb/path.py
> +++ b/source-builder/sb/path.py
> @@ -25,14 +25,14 @@
> -import log
>  import os
>  import shutil
>  import stat
>  import string
>  import sys
> -import error
> +from . import log
>  windows_posix = sys.platform == 'msys'
>  windows = os.name == 'nt'
> diff --git a/source-builder/sb/pkgconfig.py b/source-builder/sb/pkgconfig.py
> index 99646f7..89b4d5c 100755
> --- a/source-builder/sb/pkgconfig.py
> +++ b/source-builder/sb/pkgconfig.py
> @@ -43,7 +43,7 @@ import re
>  import shlex
>  import sys
> -import path
> +from . import path
>  def default_prefix(common = True):
>      paths = []
> @@ -214,7 +214,12 @@ class package(object):
>              prefix = default_prefix()
>          if prefix:
>              self._log('prefix: %s' % (prefix))
> -            if type(prefix) is str or type(prefix) is unicode:
> +            try:
> +                if type(prefix) is unicode:
> +                    prefix = prefix.decode("utf-8", "ignore")
> +            except:
> +                pass
> +            if type(prefix) is str:
>                  prefix = str(prefix)
>                  self.prefix = []
>                  for p in prefix.split(os.pathsep):
> diff --git a/source-builder/sb/python-wrapper.sh b/source-builder/sb/python-wrapper.sh
> deleted file mode 100644
> index c736a66..0000000
> --- a/source-builder/sb/python-wrapper.sh
> +++ /dev/null
> @@ -1,39 +0,0 @@
> -set -e
> -if test ! -f $PYTHON_CMD; then
> -  echo "error: python command not found: $PYTHON_CMD"
> -  exit 5
> -fi
> -for py in python2 python2.7 python3 python
> -do
> -  set +e
> -  py_cmd=$(command -v $py)
> -  set -e
> -  if test -n "$RTEMS_PYTHON_OVERRIDE"; then
> -    if test "$RTEMS_PYTHON_OVERRIDE" != "$py"; then
> -      py_cmd=""
> -    fi
> -  fi
> -  if test -n "$py_cmd"; then
> -    exec $py_cmd $PYTHON_CMD $0 $*
> -  fi
> -done
> -echo "error: no valid python found"
> -exit 5
> diff --git a/source-builder/sb/reports.py b/source-builder/sb/reports.py
> index e7870c4..34474f3 100644
> --- a/source-builder/sb/reports.py
> +++ b/source-builder/sb/reports.py
> @@ -34,17 +34,17 @@ import pprint
>  pp = pprint.PrettyPrinter(indent = 2)
>  try:
> -    import build
> -    import check
> -    import config
> -    import error
> -    import git
> -    import log
> -    import options
> -    import path
> -    import setbuilder
> -    import sources
> -    import version
> +    from . import git
> +    from . import log
> +    from . import setbuilder
>      sys.exit(1)
> diff --git a/source-builder/sb/rtemsconfig.py b/source-builder/sb/rtemsconfig.py
> index 97ede7f..0ad6c5c 100644
> --- a/source-builder/sb/rtemsconfig.py
> +++ b/source-builder/sb/rtemsconfig.py
> @@ -28,11 +28,11 @@ import sys
>  import threading
>  import time
> -import error
> -import log
> -import options
> -import path
> -import version
> +from . import log
> +from . import path
>  def _collect(path_, file):
>      confs = []
> diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> index a6efd75..02901d4 100644
> --- a/source-builder/sb/setbuilder.py
> +++ b/source-builder/sb/setbuilder.py
> @@ -33,17 +33,17 @@ import sys
>  import textwrap
>  try:
> -    import build
> -    import check
> -    import error
> -    import log
> -    import mailer
> -    import options
> -    import path
> -    import reports
> -    import shell
> -    import sources
> -    import version
> +    from . import log
> +    from . import mailer
> +    from . import reports
> +    from . import shell
>      sys.exit(1)
> diff --git a/source-builder/sb/shell.py b/source-builder/sb/shell.py
> index bebbe8a..f1e669a 100644
> --- a/source-builder/sb/shell.py
> +++ b/source-builder/sb/shell.py
> @@ -25,10 +25,10 @@
>  try:
> -    import error
> -    import execute
> -    import log
> -    import options
> +    from . import log
>      sys.exit(1)
> diff --git a/source-builder/sb/simhost.py b/source-builder/sb/simhost.py
> index 13ab157..e3f759b 100644
> --- a/source-builder/sb/simhost.py
> +++ b/source-builder/sb/simhost.py
> @@ -29,15 +29,15 @@ import datetime
>  import os
>  try:
> -    import build
> -    import check
> -    import error
> -    import git
> -    import log
> -    import macros
> -    import path
> -    import sources
> -    import version
> +    from . import git
> +    from . import log
> +    from . import macros
>      sys.exit(1)
> @@ -160,7 +160,7 @@ def find_bset_config(bset_config, macros):
>  class options(object):
>      def __init__(self, argv, argopts, defaults, extras):
> -        command_path = path.dirname(path.abspath(argv[1]))
> +        command_path = path.dirname(path.abspath(argv[0]))
>          if len(command_path) == 0:
>              command_path = '.'
>          self.command_path = command_path
> @@ -190,7 +190,7 @@ class options(object):
>          overrides = None
>          if os.name == 'nt':
>              try:
> -                import windows
>                  host_windows = True
>                  host_posix = False
> @@ -200,26 +200,26 @@ class options(object):
>              uname = os.uname()
>              try:
> -                    import windows
>                      host_windows = True
> -                    import windows
> -                    import darwin
> -                    import freebsd
> -                    import netbsd
> -                    import linux
> -                    import solaris
> diff --git a/source-builder/sb/solaris.py b/source-builder/sb/solaris.py
> index 8d9498a..231fd34 100644
> --- a/source-builder/sb/solaris.py
> +++ b/source-builder/sb/solaris.py
> @@ -25,9 +25,9 @@
>  import pprint
>  import os
> -import check
> -import error
> -import execute
>  def load():
>      uname = os.uname()
> diff --git a/source-builder/sb/sources.py b/source-builder/sb/sources.py
> index a619778..1d62cb7 100644
> --- a/source-builder/sb/sources.py
> +++ b/source-builder/sb/sources.py
> @@ -21,7 +21,7 @@
>  # Manage sources and patches
> -import log
> +from . import log
>  def _args(args):
>      return [i for s in [ii.split() for ii in args] for i in s]
> diff --git a/source-builder/sb/track.py b/source-builder/sb/track.py
> index aef25b9..49344fe 100644
> --- a/source-builder/sb/track.py
> +++ b/source-builder/sb/track.py
> @@ -31,12 +31,12 @@ import os
>  import sys
>  try:
> -    import build
> -    import error
> -    import git
> -    import log
> -    import simhost
> -    import version
> +    from . import git
> +    from . import log
>      sys.exit(1)
> @@ -138,7 +138,7 @@ def run(args = sys.argv):
>          log.notice('RTEMS Source Builder - Track Dependencies, %s' % (version.string()))
> diff --git a/source-builder/sb/version.py b/source-builder/sb/version.py
> index 721c459..29d2dc5 100644
> --- a/source-builder/sb/version.py
> +++ b/source-builder/sb/version.py
> @@ -76,9 +76,9 @@ from __future__ import print_function
>  import os
>  import sys
> -import error
> -import git
> -import path
> +from . import git
> +from . import path
>  # Default to an internal string.
> diff --git a/source-builder/sb/windows.py b/source-builder/sb/windows.py
> index 1eb51a0..ceca24f 100644
> --- a/source-builder/sb/windows.py
> +++ b/source-builder/sb/windows.py
> @@ -24,9 +24,9 @@
>  import os
>  import sys
> -import error
> -import execute
> -import path
> +from . import path
>  def load():
>      # Default to the native Windows Python.
> 2.24.1
> devel mailing list
> devel at rtems.org
