Error Building RSB (Master)
Wed Aug 26 16:39:18 UTC 2020
It must be an issue with how the imports got changed in the shebang patch.
On Wed, Aug 26, 2020 at 10:33 AM Joel Sherrill <joel at rtems.org> wrote:
> I got this also on the machine I use for automated testing. I backed up to this commit and it works:
> commit dc989037e430ceb24b9a7ffd6e514935319e0e45
> Author: Chris Johns <chrisj at rtems.org>
> Date:   Wed Aug 12 13:17:48 2020 +1000
>     sb/track: Only output unreferenced configs with the option
> That eliminated these two:
> commit 650c6f99333c7f163f81817d3f71f93d0ae17ee4
> Date:   Tue Aug 25 21:21:50 2020 +1000
>     sb: Use shebang env python
>     Closes #4037
> commit 40af487dfc26a583e7d20b7af9ca2058ed69e1ef
> Date:   Thu Aug 13 11:44:23 2020 +1000
>     Move 5 build sets to 6
>     - Move 5/bsps/* to bsps/*
>     - Update package build references from 5 to 6
>     - Remove 5 build sets.
>     Update #4048
> Not sure which one did it but the author to blame is a singleton. :)
> On Wed, Aug 26, 2020 at 10:31 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> Hello Dr Bloom,
>> its not detecting the import files
>> error :
>> ❯ ./source-builder/sb-check
>> Traceback (most recent call last):
>>   File "./source-builder/sb-check", line 23, in <module>
>>     import sb.check
>> ImportError: No module named sb.check
>> On Wed, Aug 26, 2020 at 8:59 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> try sb-check
>>> On Wed, Aug 26, 2020 at 8:52 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>>> > Hello everyone,
>>> > I tried building RSB for arm-rtems6 and received this error
>>> > ../source-builder/sb-set-builder --prefix=/home/eshan/development/rtems/6 6/rtems-arm
>>> > Incorrect Source Builder installation
>>> > Thanks
>>> > - Eshan
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
