[PATCH] Adding EPICS7 Package to RSB
Mritunjay Sharma mritunjaysharma394 at gmail.com
Wed Aug 26 21:34:18 UTC 2020
Thank you so much for taking time to review the PATCH.
On Wed, Aug 26, 2020 at 8:56 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Aug 25, 2020 at 4:36 PM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> > This patch add supports for EPICS7 Package to RTEMS RSB.
> > Signed-off-by: Mritunjay Sharma <mritunjaysharma394 at gmail.com>
> >  rtems/config/epics/epics-7-1.cfg    | 22 +++++++++++
> >  rtems/config/epics/epics-base.bset  | 26 +++++++++++++
> >  source-builder/config/epics-7-1.cfg | 57 +++++++++++++++++++++++++++++
> >  3 files changed, 105 insertions(+)
> >  create mode 100644 rtems/config/epics/epics-7-1.cfg
> >  create mode 100644 rtems/config/epics/epics-base.bset
> >  create mode 100644 source-builder/config/epics-7-1.cfg
> > diff --git a/rtems/config/epics/epics-7-1.cfg
> b/rtems/config/epics/epics-7-1.cfg
> > new file mode 100644
> > index 0000000..30ed9cb
> > --- /dev/null
> > +++ b/rtems/config/epics/epics-7-1.cfg
> should this file be epics-7.0-1.cfg?
> Yes, thanks for highlighting it. Fixed this.
> > @@ -0,0 +1,22 @@
> > +# EPICS 7
> EPICS 7.0?
> > +%if %{release} == %{nil}
> > + %define release 1
> > +%endif
> > +%include %{_configdir}/rtems-bsp.cfg
> > +# EPICS Version
> > +%define epics_version 7.0
> > +%hash sha512 epics-base-%{epics_version}.tar.gz
> 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
> Only one blank comment line.
> Fixed.
> > +# EPICS Build configuration
> > +%include %{_configdir}/epics-7-1.cfg
> > diff --git a/rtems/config/epics/epics-base.bset
> b/rtems/config/epics/epics-base.bset
> > index 0000000..e56fc6a
> > --- /dev/null
> > +++ b/rtems/config/epics/epics-base.bset
> > @@ -0,0 +1,26 @@
> > +# Build set for EPICS
> > +%define release 1
> > +# RTEMS Version
> > +%define rtems_version 5
> is this correct?
> Do you want to apply this to the 5 branch of rsb?
> I have removed this line.
> > +# The RTEMS URL paths.
> > +%include rtems-urls.bset
> > +# The RTEMS Package defines
> > +%include rtems-package.bset
> 1 blank line only
Fixed.
> > +# Build EPICS.
> > +epics/epics-7-1 .
> Stray . ?
If I was not using '.' and I was simply using, the build failed, in the
beginning, itself with the following error:
`Build Set: epics/epics-base
error: epics/epics-base:15: cannot find file: epics/epics-7.0-1.cf `
The command I am entering is: `/source-builder/sb-set-builder
--with-rtems-bsp="xilinx_zynq_a9_qemu" --log=log_epics epics/epics-base
 --trace --prefix=$HOME/development/rtems/5-arm --host=arm-rtems5`
> > \ No newline at end of file
> > diff --git a/source-builder/config/epics-7-1.cfg
> b/source-builder/config/epics-7-1.cfg
> > index 0000000..2a52ea5
> > --- /dev/null
> > +++ b/source-builder/config/epics-7-1.cfg
> > @@ -0,0 +1,57 @@
> > +# EPICS 7.x.x Version 1.
> > +# This configuration file configure's, make's and install's EPICS.
> > +%define release 1
> > +%endif
> > +Name:      epics-base-%{epics_version}-%{_host}-%{release}
> > +Summary:   EPICS v%{epics_version} for target %{_target} on host
> %{_host}
> > +Version:   %{epics_version}
> > +Release:   %{release}
> > +URL:     https://epics.mpg.de/
> This doesn't look like the right url.
I cross-checked and it seems to be working.
> > +# Source
> > +%source set epics-base
> https://gitlab.fhi.mpg.de/junkes/epics-base/-/archive/%{epics_version}/epics-base-%{epics_version}.tar.gz
> ditto
> where do official EPICS releases go?
I think we need Heinz intervention in this and I am ready to help him get
it done.
We have to use this repo for the time being.
> > +# Prepare the source code.
> > +%prep
> > +  build_top=$(pwd)
> > +  source_dir_epics="epics-base-%{epics_version}"
> > +  %source setup epics-base -q -n epics-base-%{epics_version}
> I'm curious, can you use the source_dir_epics variable here?
I didn't see any affect not using  `source_dir_epics variable `. This time
I used `cd epics-base-%{epics_version}`
and saw no changes as such. What do you suggest to use?
> > +  cd ${build_top}
> > +%build
> > +  build_top=$(pwd)
> > +  cd ${source_dir_epics}
> > +  %{build_build_flags}
> > +  # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION
> using --with-rtems-bsp
> > +  %{__make} RTEMS_BASE=%{_prefix} RTEMS_VERSION=%{rtems_version}
> CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
> Can you line break this to under 80 characters? might need to use
> backslashes \
Fixed.
> I guess EPICS is normally built from within its source tree? Just want
> to be sure. I haven't built it in awhile.
Yes, in order to build EPICS we have to inside epics-base-7.0 directory and
enter `make` there.
> > +  cd ${build_top}
> > +%install
> > +  build_top=$(pwd)
> > +  rm -rf $SB_BUILD_ROOT
> I think there is %{__rmdir} command available
Thanks. Changed it.
> > +  %{__make} DESTDIR=$SB_BUILD_ROOT RTEMS_BASE=%{_prefix}
> also line breaks
Fixed this. I will send the patch soon but I am still getting the `error:
copying tree (4):` error. Will start a new thread for it.
Thanks
Mritunjay
> > +  cd ${build_top}
> > 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200827/a3e6f262/attachment.html>
