[PATCH] Adding EPICS7 Package to RSB
Mritunjay Sharma mritunjaysharma394 at gmail.com
Wed Aug 26 21:50:39 UTC 2020
On Thu, Aug 27, 2020 at 3:04 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Thank you so much for taking time to review the PATCH.
> On Wed, Aug 26, 2020 at 8:56 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Aug 25, 2020 at 4:36 PM Mritunjay Sharma
>> <mritunjaysharma394 at gmail.com> wrote:
>> > This patch add supports for EPICS7 Package to RTEMS RSB.
>> > Signed-off-by: Mritunjay Sharma <mritunjaysharma394 at gmail.com>
>> >  rtems/config/epics/epics-7-1.cfg    | 22 +++++++++++
>> >  rtems/config/epics/epics-base.bset  | 26 +++++++++++++
>> >  source-builder/config/epics-7-1.cfg | 57 +++++++++++++++++++++++++++++
>> >  3 files changed, 105 insertions(+)
>> >  create mode 100644 rtems/config/epics/epics-7-1.cfg
>> >  create mode 100644 rtems/config/epics/epics-base.bset
>> >  create mode 100644 source-builder/config/epics-7-1.cfg
>> > diff --git a/rtems/config/epics/epics-7-1.cfg
>> b/rtems/config/epics/epics-7-1.cfg
>> > new file mode 100644
>> > index 0000000..30ed9cb
>> > --- /dev/null
>> > +++ b/rtems/config/epics/epics-7-1.cfg
>> should this file be epics-7.0-1.cfg?
>> Yes, thanks for highlighting it. Fixed this.
>> > @@ -0,0 +1,22 @@
>> > +# EPICS 7
>> EPICS 7.0?
>> > +%if %{release} == %{nil}
>> > + %define release 1
>> > +%endif
>> > +%include %{_configdir}/rtems-bsp.cfg
>> > +# EPICS Version
>> > +%define epics_version 7.0
>> > +%hash sha512 epics-base-%{epics_version}.tar.gz
>> 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
>> Only one blank comment line.
>> Fixed.
>> > +# EPICS Build configuration
>> > +%include %{_configdir}/epics-7-1.cfg
>> > diff --git a/rtems/config/epics/epics-base.bset
>> b/rtems/config/epics/epics-base.bset
>> > index 0000000..e56fc6a
>> > --- /dev/null
>> > +++ b/rtems/config/epics/epics-base.bset
>> > @@ -0,0 +1,26 @@
>> > +# Build set for EPICS
>> > +%define release 1
>> > +# RTEMS Version
>> > +%define rtems_version 5
>> is this correct?
>> Do you want to apply this to the 5 branch of rsb?
>> I have removed this line.
>> > +# The RTEMS URL paths.
>> > +%include rtems-urls.bset
>> > +# The RTEMS Package defines
>> > +%include rtems-package.bset
>> 1 blank line only
> Fixed.
>> > +# Build EPICS.
>> > +epics/epics-7-1 .
>> Stray . ?
> If I was not using '.' and I was simply using, the build failed, in the
> beginning, itself with the following error:
> `Build Set: epics/epics-base
> error: epics/epics-base:15: cannot find file: epics/epics-7.0-1.cf `
[UPDATE]: Removed the '.' The above error was due to missing space after
line 15. On adding space, it was resolved.
> The command I am entering is: `/source-builder/sb-set-builder
> --with-rtems-bsp="xilinx_zynq_a9_qemu" --log=log_epics epics/epics-base
>  --trace --prefix=$HOME/development/rtems/5-arm --host=arm-rtems5`
>> > \ No newline at end of file
>> > diff --git a/source-builder/config/epics-7-1.cfg
>> b/source-builder/config/epics-7-1.cfg
>> > index 0000000..2a52ea5
>> > --- /dev/null
>> > +++ b/source-builder/config/epics-7-1.cfg
>> > @@ -0,0 +1,57 @@
>> > +# EPICS 7.x.x Version 1.
>> > +# This configuration file configure's, make's and install's EPICS.
>> > +%define release 1
>> > +%endif
>> > +Name:      epics-base-%{epics_version}-%{_host}-%{release}
>> > +Summary:   EPICS v%{epics_version} for target %{_target} on host
>> %{_host}
>> > +Version:   %{epics_version}
>> > +Release:   %{release}
>> > +URL:     https://epics.mpg.de/
>> This doesn't look like the right url.
> I cross-checked and it seems to be working.
>> > +# Source
>> > +%source set epics-base
>> https://gitlab.fhi.mpg.de/junkes/epics-base/-/archive/%{epics_version}/epics-base-%{epics_version}.tar.gz
>> ditto
>> where do official EPICS releases go?
> I think we need Heinz intervention in this and I am ready to help him get
> it done.
> We have to use this repo for the time being.
>> > +# Prepare the source code.
>> > +%prep
>> > +  build_top=$(pwd)
>> > +  source_dir_epics="epics-base-%{epics_version}"
>> > +  %source setup epics-base -q -n epics-base-%{epics_version}
>> I'm curious, can you use the source_dir_epics variable here?
> I didn't see any affect not using  `source_dir_epics variable `. This time
> I used `cd epics-base-%{epics_version}`
> and saw no changes as such. What do you suggest to use?
>> > +  cd ${build_top}
>> > +%build
>> > +  build_top=$(pwd)
>> > +  cd ${source_dir_epics}
>> > +  %{build_build_flags}
>> > +  # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION
>> using --with-rtems-bsp
>> > +  %{__make} RTEMS_BASE=%{_prefix} RTEMS_VERSION=%{rtems_version}
>> CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
>> Can you line break this to under 80 characters? might need to use
>> backslashes \
> Fixed.
>> I guess EPICS is normally built from within its source tree? Just want
>> to be sure. I haven't built it in awhile.
> Yes, in order to build EPICS we have to inside epics-base-7.0 directory
> and enter `make` there.
>> > +  cd ${build_top}
>> > +%install
>> > +  build_top=$(pwd)
>> > +  rm -rf $SB_BUILD_ROOT
>> I think there is %{__rmdir} command available
> Thanks. Changed it.
>> > +  %{__make} DESTDIR=$SB_BUILD_ROOT RTEMS_BASE=%{_prefix}
>> also line breaks
> Fixed this. I will send the patch soon but I am still getting the `error:
> copying tree (4):` error. Will start a new thread for it.
> Thanks
> Mritunjay
>> > +  cd ${build_top}
>> > 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200827/114655ed/attachment-0001.html>
