[PATCH] sb: Fix the imports on Python2
chrisj at rtems.org
chrisj at rtems.org
Thu Aug 27 05:54:15 UTC 2020
Closes #4037
source-builder/sb-check | 2 --
source-builder/sb/__init__.py | 20 ++++++++++++++++++++
source-builder/sb/build.py | 3 +--
source-builder/sb/config.py | 3 +--
source-builder/sb/getsources.py | 3 +--
source-builder/sb/linux.py | 2 +-
source-builder/sb/reports.py | 9 +++------
source-builder/sb/setbuilder.py | 3 +--
source-builder/sb/shell.py | 3 +--
source-builder/sb/simhost.py | 3 +--
source-builder/sb/track.py | 3 +--
11 files changed, 31 insertions(+), 23 deletions(-)
create mode 100644 source-builder/sb/__init__.py
diff --git a/source-builder/sb-check b/source-builder/sb-check
index b75767e..8c60bf6 100755
--- a/source-builder/sb-check
+++ b/source-builder/sb-check
@@ -20,8 +20,6 @@
from __future__ import print_function
-import sb.check
try:
import sb.check
sb.check.run()
diff --git a/source-builder/sb/__init__.py b/source-builder/sb/__init__.py
new file mode 100644
index 0000000..c4275e2
--- /dev/null
+++ b/source-builder/sb/__init__.py
@@ -0,0 +1,20 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2020 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+from __future__ import print_function
diff --git a/source-builder/sb/build.py b/source-builder/sb/build.py
index f3253dd..16a495b 100644
--- a/source-builder/sb/build.py
+++ b/source-builder/sb/build.py
@@ -48,8 +48,7 @@ except KeyboardInterrupt:
print('abort: user terminated')
sys.exit(1)
except:
- print('error: unknown application load error')
- sys.exit(1)
+ raise
def humanize_number(num, suffix):
for unit in ['','K','M','G','T','P','E','Z']:
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index db795b3..cd0bf94 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -45,8 +45,7 @@ except KeyboardInterrupt:
print('user terminated', file = sys.stderr)
sys.exit(1)
except:
- print('error: unknown application load error', file = sys.stderr)
- sys.exit(1)
+ raise
def _check_bool(value):
istrue = None
diff --git a/source-builder/sb/getsources.py b/source-builder/sb/getsources.py
index 0ccf257..d348da4 100644
--- a/source-builder/sb/getsources.py
+++ b/source-builder/sb/getsources.py
@@ -40,8 +40,7 @@ except KeyboardInterrupt:
print('abort: user terminated', file = sys.stderr)
sys.exit(1)
except:
- sys.exit(1)
+ raise
def run(args = sys.argv):
ec = 0
diff --git a/source-builder/sb/linux.py b/source-builder/sb/linux.py
index d773818..d89377b 100644
--- a/source-builder/sb/linux.py
+++ b/source-builder/sb/linux.py
@@ -23,10 +23,10 @@
import multiprocessing
+import platform
import pprint
import os
-from . import platform
from . import path
def load():
diff --git a/source-builder/sb/reports.py b/source-builder/sb/reports.py
index 34474f3..a20b29e 100644
--- a/source-builder/sb/reports.py
+++ b/source-builder/sb/reports.py
@@ -30,9 +30,6 @@ import datetime
import os
import sys
-import pprint
-pp = pprint.PrettyPrinter(indent = 2)
try:
from . import build
from . import check
@@ -42,15 +39,13 @@ try:
from . import log
from . import options
from . import path
- from . import setbuilder
from . import sources
from . import version
sys.exit(1)
except:
- sys.exit(1)
+ raise
_line_len = 78
@@ -865,6 +860,7 @@ class report:
raise error.general('writing output file: %s: %s' % (name, err))
def generate(self, name, tree = None, opts = None, macros = None):
+ from . import setbuilder
self.buildset_start(name)
if tree is None:
tree = self.tree
@@ -899,6 +895,7 @@ class report:
def run(args):
try:
optargs = { '--list-bsets': 'List available build sets',
'--list-configs': 'List available configurations',
'--format': 'Output format (text, html, markdown, ini, xml)',
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index 02901d4..b0e2b23 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
sys.exit(1)
except:
- sys.exit(1)
+ raise
def macro_expand(macros, _str):
cstr = None
diff --git a/source-builder/sb/shell.py b/source-builder/sb/shell.py
index f1e669a..ecb8188 100644
--- a/source-builder/sb/shell.py
+++ b/source-builder/sb/shell.py
@@ -33,8 +33,7 @@ except KeyboardInterrupt:
sys.exit(1)
except:
- sys.exit(1)
+ raise
def expand(macros, line):
diff --git a/source-builder/sb/simhost.py b/source-builder/sb/simhost.py
index e3f759b..1ff98e8 100644
--- a/source-builder/sb/simhost.py
+++ b/source-builder/sb/simhost.py
@@ -42,8 +42,7 @@ except KeyboardInterrupt:
sys.exit(1)
except:
- sys.exit(1)
+ raise
# Define host profiles so it can simulated on another host.
diff --git a/source-builder/sb/track.py b/source-builder/sb/track.py
index 49344fe..cf33a00 100644
--- a/source-builder/sb/track.py
+++ b/source-builder/sb/track.py
@@ -41,8 +41,7 @@ except KeyboardInterrupt:
sys.exit(1)
except:
- sys.exit(1)
+ raise
def unique(l):
return sorted(list(set(l)))
2.17.1
