[PATCH] sb: Fix the imports on Python2
Gedare Bloom
gedare at rtems.org
Thu Aug 27 15:41:33 UTC 2020
On Wed, Aug 26, 2020 at 11:54 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Closes #4037
> source-builder/sb-check | 2 --
> source-builder/sb/__init__.py | 20 ++++++++++++++++++++
> source-builder/sb/build.py | 3 +--
> source-builder/sb/config.py | 3 +--
> source-builder/sb/getsources.py | 3 +--
> source-builder/sb/linux.py | 2 +-
> source-builder/sb/reports.py | 9 +++------
> source-builder/sb/setbuilder.py | 3 +--
> source-builder/sb/shell.py | 3 +--
> source-builder/sb/simhost.py | 3 +--
> source-builder/sb/track.py | 3 +--
> 11 files changed, 31 insertions(+), 23 deletions(-)
> create mode 100644 source-builder/sb/__init__.py
> diff --git a/source-builder/sb-check b/source-builder/sb-check
> index b75767e..8c60bf6 100755
> --- a/source-builder/sb-check
> +++ b/source-builder/sb-check
> @@ -20,8 +20,6 @@
> from __future__ import print_function
> -import sb.check
> try:
> import sb.check
> sb.check.run()
> diff --git a/source-builder/sb/__init__.py b/source-builder/sb/__init__.py
> new file mode 100644
> index 0000000..c4275e2
> --- /dev/null
> +++ b/source-builder/sb/__init__.py
> @@ -0,0 +1,20 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2020 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Permission to use, copy, modify, and/or distribute this software for any
> +# purpose with or without fee is hereby granted, provided that the above
> +# copyright notice and this permission notice appear in all copies.
> +# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
> +# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
> +# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
> +# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
> +# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
> +# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
> +# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
This doesn't follow the template. I guess probably it uses what is in
other rtems-tools files though.
https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#python-file-template
This is MIT license?
> +from __future__ import print_function
> diff --git a/source-builder/sb/build.py b/source-builder/sb/build.py
> index f3253dd..16a495b 100644
> --- a/source-builder/sb/build.py
> +++ b/source-builder/sb/build.py
> @@ -48,8 +48,7 @@ except KeyboardInterrupt:
> print('abort: user terminated')
> sys.exit(1)
> except:
> - print('error: unknown application load error')
> - sys.exit(1)
> + raise
> def humanize_number(num, suffix):
> for unit in ['','K','M','G','T','P','E','Z']:
> diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
> index db795b3..cd0bf94 100644
> --- a/source-builder/sb/config.py
> +++ b/source-builder/sb/config.py
> @@ -45,8 +45,7 @@ except KeyboardInterrupt:
> print('user terminated', file = sys.stderr)
> sys.exit(1)
> except:
> - print('error: unknown application load error', file = sys.stderr)
> - sys.exit(1)
> + raise
> def _check_bool(value):
> istrue = None
> diff --git a/source-builder/sb/getsources.py b/source-builder/sb/getsources.py
> index 0ccf257..d348da4 100644
> --- a/source-builder/sb/getsources.py
> +++ b/source-builder/sb/getsources.py
> @@ -40,8 +40,7 @@ except KeyboardInterrupt:
> print('abort: user terminated', file = sys.stderr)
> sys.exit(1)
> except:
> - sys.exit(1)
> + raise
> def run(args = sys.argv):
> ec = 0
> diff --git a/source-builder/sb/linux.py b/source-builder/sb/linux.py
> index d773818..d89377b 100644
> --- a/source-builder/sb/linux.py
> +++ b/source-builder/sb/linux.py
> @@ -23,10 +23,10 @@
> import multiprocessing
> +import platform
> import pprint
> import os
> -from . import platform
> from . import path
> def load():
> diff --git a/source-builder/sb/reports.py b/source-builder/sb/reports.py
> index 34474f3..a20b29e 100644
> --- a/source-builder/sb/reports.py
> +++ b/source-builder/sb/reports.py
> @@ -30,9 +30,6 @@ import datetime
> import os
> import sys
> -import pprint
> -pp = pprint.PrettyPrinter(indent = 2)
> try:
> from . import build
> from . import check
> @@ -42,15 +39,13 @@ try:
> from . import log
> from . import options
> from . import path
> - from . import setbuilder
> from . import sources
> from . import version
> sys.exit(1)
> except:
> - sys.exit(1)
> + raise
> _line_len = 78
> @@ -865,6 +860,7 @@ class report:
> raise error.general('writing output file: %s: %s' % (name, err))
> def generate(self, name, tree = None, opts = None, macros = None):
> + from . import setbuilder
> self.buildset_start(name)
> if tree is None:
> tree = self.tree
> @@ -899,6 +895,7 @@ class report:
> def run(args):
> try:
> optargs = { '--list-bsets': 'List available build sets',
> '--list-configs': 'List available configurations',
> '--format': 'Output format (text, html, markdown, ini, xml)',
> diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> index 02901d4..b0e2b23 100644
> --- a/source-builder/sb/setbuilder.py
> +++ b/source-builder/sb/setbuilder.py
> sys.exit(1)
> except:
> - sys.exit(1)
> + raise
> def macro_expand(macros, _str):
> cstr = None
> diff --git a/source-builder/sb/shell.py b/source-builder/sb/shell.py
> index f1e669a..ecb8188 100644
> --- a/source-builder/sb/shell.py
> +++ b/source-builder/sb/shell.py
> @@ -33,8 +33,7 @@ except KeyboardInterrupt:
> sys.exit(1)
> except:
> - sys.exit(1)
> + raise
> def expand(macros, line):
> diff --git a/source-builder/sb/simhost.py b/source-builder/sb/simhost.py
> index e3f759b..1ff98e8 100644
> --- a/source-builder/sb/simhost.py
> +++ b/source-builder/sb/simhost.py
> @@ -42,8 +42,7 @@ except KeyboardInterrupt:
> sys.exit(1)
> except:
> - sys.exit(1)
> + raise
> # Define host profiles so it can simulated on another host.
> diff --git a/source-builder/sb/track.py b/source-builder/sb/track.py
> index 49344fe..cf33a00 100644
> --- a/source-builder/sb/track.py
> +++ b/source-builder/sb/track.py
> @@ -41,8 +41,7 @@ except KeyboardInterrupt:
> sys.exit(1)
> except:
> - sys.exit(1)
> + raise
> def unique(l):
> return sorted(list(set(l)))
> 2.17.1
> devel mailing list
> devel at rtems.org
