[PATCH] sb: Use shebang env python
Gedare Bloom
gedare at rtems.org
Thu Aug 27 15:38:27 UTC 2020
On Wed, Aug 26, 2020 at 10:35 PM Chris Johns <chrisj at rtems.org> wrote:
> On 27/8/20 1:10 am, Gedare Bloom wrote:
> > thanks, some of this is rewriting shell script to python, and fixing
> > up imports. I'd prefer to have these separated, but it's probably fine
> > I took a quick skim over all of it.
> Changes to the imports are needed for the moved code to work. The code before I
> moved to the script wrapper used the system path to manage the loading however I
> always felt this was a hack and I was reluctant to use it again.
> I tested Python3 and Python2 and when commiting the changes I noticed the file
> `source-builder/sb/__init__.py` I had added when playing with options was empty
> so I removed. It was empty so what purpose did it serve? It turns out this file
> is needed on Python2. I failed to retest after removing the file. I am sorry for
> the disruption it has caused.
> I have made some other changes to the imports, one to break a circular reference
> between the setbulder and reports modules. This appeared as part of cleaning up
> how imports are handled. I will post a patch for testing soon.
Thanks. Yes, that empty __init__ is an annoying artifact.
> Chris
