[PATCH] tester: Change to a simpler TFTP server
Gedare Bloom
gedare at rtems.org
Thu Aug 27 15:44:53 UTC 2020
On Wed, Aug 26, 2020 at 10:56 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Add a simpler TFTP to allow parallel test hardware
> - Remove the imported tftpy server
> Closes #4063
> tester/rt/tftp.py | 37 +-
> tester/rt/tftpserver.py | 619 +++++++++++++++++++++++++++
> tester/rt/tftpy/COPYING | 21 -
> tester/rt/tftpy/README | 115 -----
> tester/rt/tftpy/TftpClient.py | 107 -----
> tester/rt/tftpy/TftpContexts.py | 429 -------------------
> tester/rt/tftpy/TftpPacketFactory.py | 47 --
> tester/rt/tftpy/TftpPacketTypes.py | 494 ---------------------
> tester/rt/tftpy/TftpServer.py | 271 ------------
> tester/rt/tftpy/TftpShared.py | 52 ---
> tester/rt/tftpy/TftpStates.py | 611 --------------------------
> tester/rt/tftpy/__init__.py | 27 --
> tester/rtems-tftp-server | 46 ++
> 13 files changed, 685 insertions(+), 2191 deletions(-)
> create mode 100644 tester/rt/tftpserver.py
> delete mode 100644 tester/rt/tftpy/COPYING
> delete mode 100644 tester/rt/tftpy/README
> delete mode 100644 tester/rt/tftpy/TftpClient.py
> delete mode 100644 tester/rt/tftpy/TftpContexts.py
> delete mode 100644 tester/rt/tftpy/TftpPacketFactory.py
> delete mode 100644 tester/rt/tftpy/TftpPacketTypes.py
> delete mode 100644 tester/rt/tftpy/TftpServer.py
> delete mode 100644 tester/rt/tftpy/TftpShared.py
> delete mode 100644 tester/rt/tftpy/TftpStates.py
> delete mode 100644 tester/rt/tftpy/__init__.py
> create mode 100755 tester/rtems-tftp-server
> diff --git a/tester/rt/tftp.py b/tester/rt/tftp.py
> index d518036..46a1d11 100644
> --- a/tester/rt/tftp.py
> +++ b/tester/rt/tftp.py
> @@ -43,7 +43,7 @@ import sys
> from rtemstoolkit import error
> from rtemstoolkit import reraise
> -import tftpy
> +import tftpserver
> class tftp(object):
> '''RTEMS Testing TFTP base.'''
> @@ -88,7 +88,7 @@ class tftp(object):
> def _stop(self):
> try:
> if self.server:
> - self.server.stop(now = True)
> + self.server.stop()
> except:
> pass
> @@ -101,6 +101,10 @@ class tftp(object):
> def _timeout(self):
> self._stop()
> + while self.running or not self.finished:
> + self._unlock('_timeout')
> + time.sleep(0.1)
> + self._lock('_timeout')
> if self.timeout is not None:
> self.timeout()
> @@ -119,22 +123,21 @@ class tftp(object):
> return None
> def _listener(self):
> - tftpy_log = logging.getLogger('tftpy')
> - tftpy_log.setLevel(100)
> + self._lock('_listener')
> + exe = self.exe
> + self.exe = None
> + self._unlock('_listener')
> + self.server = tftpserver.tftp_server(host = 'all',
> + port = self.port,
> + timeout = 1,
> + forced_file = exe,
> + sessions = 1)
> try:
> - self.server = tftpy.TftpServer(tftproot = '.',
> - dyn_file_func = self._exe_handle)
> - except tftpy.TftpException as te:
> - raise error.general('tftp: %s' % (str(te)))
> - if self.server is not None:
> - try:
> - self.server.listen('0.0.0.0', self.port, 0.5)
> - except IOError as ie:
> - if ie.errno == errno.EACCES:
> - raise error.general('tftp: permissions error: check tftp server port')
> - raise error.general('tftp: io error: %s' % (str(ie)))
> + self.server.start()
> + self.server.run()
> + except:
> + raise
> def _runner(self):
> self._lock('_runner')
> diff --git a/tester/rt/tftpserver.py b/tester/rt/tftpserver.py
> new file mode 100644
> index 0000000..b307bd2
> --- /dev/null
> +++ b/tester/rt/tftpserver.py
> @@ -0,0 +1,619 @@
> +# Copyright 2020 Chris Johns (chris at contemporary.software)
Nice email.
> +# All rights reserved.
> +# Permission to use, copy, modify, and/or distribute this software for any
> +# purpose with or without fee is hereby granted, provided that the above
> +# copyright notice and this permission notice appear in all copies.
> +# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
> +# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
> +# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
> +# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
> +# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
> +# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
> +# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
Not the preferred file block:
https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#python-file-template
But, we could add an MIT template.
I don't really have the context to check python code. Please do a pass
over the guidelines to see if you think you got to them.
> +# The TFTP Server handles a read only TFTP session.
> +from __future__ import print_function
> +import argparse
> +import os
> +import socket
> +import sys
> +import time
> +import threading
> +try:
> + import socketserver
> +except:
> + import SocketServer as socketserver
> +from rtemstoolkit import error
> +from rtemstoolkit import log
> +from rtemstoolkit import version
> +class tftp_session(object):
> + opcodes = ['nul', 'RRQ', 'WRQ', 'DATA', 'ACK', 'ERROR', 'OACK']
> + OP_RRQ = 1
> + OP_WRQ = 2
> + OP_DATA = 3
> + OP_ACK = 4
> + OP_ERROR = 5
> + OP_OACK = 6
> + E_NOT_DEFINED = 0
> + E_FILE_NOT_FOUND = 1
> + E_ACCESS_VIOLATION = 2
> + E_DISK_FULL = 3
> + E_ILLEGAL_TFTP_OP = 4
> + E_UKNOWN_TID = 5
> + E_FILE_ALREADY_EXISTS = 6
> + E_NO_SUCH_USER = 7
> + E_NO_ERROR = 10
> + def __init__(self, host, port, base, forced_file, reader = None):
> + self.host = host
> + self.port = port
> + self.base = base
> + self.forced_file = forced_file
> + if reader is None:
> + self.data_reader = self._file_reader
> + else:
> + self.data_reader = reader
> + self.filein = None
> + self.resends_limit = 5
> + self._reinit()
> + def __str__(self):
> + return os.linesep.join([self.decode(p[0], p[1], p[2]) for p in self.packets])
> + def _reinit(self):
> + if self.filein is not None:
> + self.filein.close()
> + self.block = 0
> + self.block_size = 512
> + self.timeout = 0
> + self.resends = 0
> + self.finished = False
> + def _file_reader(self, command, **kwargs):
> + '''The default file reader if the user does not provide one.
> + The call returns a two element tuple where the first element
> + is an error code, and the second element is data if the error
> + code is 0 else it is an error message.
> + if command == 'open':
> + if 'filename' not in kwargs:
> + raise error.general('tftp-reader: invalid open: no filename')
> + filename = kwargs['filename']
> + try:
> + self.filein = open(filename, 'rb')
> + filesize = os.stat(filename).st_size
> + except FileNotFoundError:
> + return self.E_FILE_NOT_FOUND, 'file not found (%s)' % (filename)
> + except PermissionError:
> + return self.E_ACCESS_VIOLATION, 'access violation'
> + except IOError as ie:
> + return self.E_NOT_DEFINED, str(ie)
> + return self.E_NO_ERROR, str(filesize)
> + elif command == 'read':
> + if self.filein is None:
> + raise error.general('tftp-reader: read when not open')
> + if 'blksize' not in kwargs:
> + raise error.general('tftp-reader: invalid read: no blksize')
> + try:
> + return self.E_NO_ERROR, self.filein.read(kwargs['blksize'])
> + except:
> + return self.E_NOT_DEFINED, 'unknown error'
> + elif command == 'close':
> + return self.E_NOT_DEFINED, 'invalid reader state'
> + def _pack_bytes(self, data = None):
> + bdata = bytearray()
> + if data is not None:
> + if not isinstance(data, list):
> + data = [data]
> + for d in data:
> + if isinstance(d, int):
> + bdata.append(d >> 8)
> + bdata.append(d & 0xff)
> + elif isinstance(d, str):
> + bdata.extend(d.encode())
> + bdata.append(0)
> + else:
> + bdata.extend(d)
> + return bdata
> + def _next_data(self, command):
> + if block == 1:
> + self.data_reader('open')
> + self.data = self.data_reader('read')
> + def _response(self, opcode, data):
> + code = self.opcodes.index(opcode)
> + if code == 0 or code >= len(self.opcodes):
> + raise error.general('invalid opcode: ' + opcode)
> + bdata = self._pack_bytes([code, data])
> + #print(''.join(format(x, '02x') for x in bdata))
> + return bytes(bdata)
> + def _error_response(self, code, message):
> + if log.tracing:
> + log.trace('tftp: error: %s:%d: %d: %s' % (self.host, self.port,
> + code, message))
> + self.finished = True;
> + return self._response('ERROR', self._pack_bytes([code, message, 0]))
> + def _data_response(self, block, data):
> + if len(data) < self.block_size:
> + return self._response('DATA', self._pack_bytes([block, data]))
> + def _oack_response(self, data):
> + self.resends += 1
> + if self.resends >= self.resends_limit:
> + return self._error_response(self.E_NOT_DEFINED, 'resend limit reached')
> + return self._response('OACK', self._pack_bytes(data))
> + def _next_block(self, block):
> + # has the current block been acknowledged?
> + if block == self.block:
> + self.resends = 0
> + self.block += 1
> + error, self.data = self.data_reader('read', blksize=self.block_size)
> + if error != self.E_NO_ERROR:
> + return self._error_response(error, data)
> + # close if the length of data is less than the block size
> + if len(self.data) < self.block_size:
> + self.data_reader('close')
> + else:
> + self.resends += 1
> + return self._data_response(self.block, self.data)
> + def process(self, host, port, data):
> + '''Process the incoming client data sending a response. If the session
> + has finished return None.
> + if host != self.host and port != self.port:
> + return self._error_response(self.E_UKNOWN_TID,
> + 'unkown transfer ID')
> + if self.finished:
> + return None
> + opcode = (data[0] << 8) | data[1]
> + if opcode == self.OP_RRQ:
> + # if the last block is not 0 something has gone wrong and
> + # TID match. Restart the session. It could be the client
> + # is a simple implementation that does not move the send
> + # port on each retry.
> + if self.block != 0:
> + self._reinit()
> + # Get the filename, mode and options
> + self.filename = self.get_option('filename', data)
> + if self.filename is None:
> + 'filename not found in request')
> + elif self.forced_file is not None:
> + self.filename = self.forced_file
> + # open the reader
> + error, message = self.data_reader('open', filename=self.filename)
> + return self._error_response(error, message)
> + # the no error on open message is the file size
> + try:
> + tsize = int(message)
> + except:
> + tsize = 0
> + self.mode = self.get_option('mode', data)
> + if self.mode is None:
> + 'mode not found in request')
> + self.oack_data = self._pack_bytes()
> + value = self.get_option('timeout', data)
> + if value is not None:
> + self.oack_data += self._pack_bytes(['timeout', value])
> + self.timeout = int(value)
> + value = self.get_option('blksize', data)
> + self.oack_data += self._pack_bytes(['blksize', value])
> + self.block_size = int(value)
> + else:
> + value = self.get_option('tsize', data)
> + if value is not None and tsize > 0:
> + self.oack_data += self._pack_bytes(['tsize', str(tsize)])
> + # Send the options ack
> + return self._oack_response(self.oack_data)
> + elif opcode == self.OP_WRQ or opcode == self.OP_DATA:
> + # WRQ is not supported
> + return self._error_response(self.E_ILLEGAL_TFTP_OP,
> + "writes not supported")
> + elif opcode == self.OP_ACK:
> + # send the next block of data
> + block = (data[2] << 8) | data[3]
> + return self._next_block(block)
> + "unknown or unsupported opcode")
> + def decode(self, host, port, data):
> + s = ''
> + dlen = len(data)
> + if dlen > 2:
> + if opcode > 0 and opcode < len(self.opcodes):
> + if opcode == self.OP_RRQ or opcode == self.OP_WRQ:
> + s += ' ' + self.opcodes[opcode] + ', '
> + i = 2
> + while data[i] != 0:
> + s += chr(data[i])
> + i += 1
> + while i < dlen - 1:
> + s += ', '
> + i += 1
> + s += chr(data[i])
> + i += 1
> + elif opcode == self.OP_DATA:
> + s += '#' + str(block) + ', '
> + if dlen > 4:
> + s += '%02x%02x..%02x%02x' % (data[4], data[5], data[-2], data[-1])
> + else:
> + s += '%02x%02x%02x%02x' % (data[4], data[5], data[6], data[6])
> + s += ',' + str(dlen - 4)
> + s += ' ' + self.opcodes[opcode] + ' ' + str(block)
> + elif opcode == self.OP_ERROR:
> + s += 'E ' + self.opcodes[opcode] + ', '
> + s += str((data[2] << 8) | (data[3]))
> + s += ': ' + str(data[4:].decode())
> + i = 2
> + s += chr(data[i])
> + i += 1
> + elif opcode == self.OP_OACK:
> + i = 1
> + s += ', '
> + i += 1
> + s += chr(data[i])
> + i += 1
> + else:
> + s += 'E INV(%d)' % (opcode)
> + else:
> + s += 'E INVALID LENGTH'
> + return s[:2] + '[%s:%d] (%d) ' % (host, port, len(data)) + s[2:]
> + def get_option(self, option, data):
> + dlen = len(data) - 1
> + next_option = False
> + if opcode == 1 or opcode == 2:
> + count = 0
> + i = 2
> + while i < dlen:
> + o = ''
> + o += chr(data[i])
> + i += 1
> + i += 1
> + if option == 'filename' and count == 0:
> + return o
> + elif option == 'mode' and count == 1:
> + return o
> + elif o == option and (count % 1) == 0:
> + next_option = True
> + elif next_option:
> + return o
> + count += 1
> + return None
> + def get_timeout(self, default_timeout, timeout_guard):
> + if self.timeout == 0:
> + return self.timeout + timeout_guard
> + return default_timeout
> + def get_block_size(self):
> + return self.block_size
> +class udp_handler(socketserver.BaseRequestHandler):
> + def _notice(self, text):
> + if self.server.tftp.notices:
> + log.notice(text)
> + else:
> + log.trace(text)
> + def handle_session(self, index):
> + client_ip = self.client_address[0]
> + client_port = self.client_address[1]
> + client = '%s:%i' % (client_ip, client_port)
> + self._notice('] tftp: %d: start: %s' % (index, client))
> + try:
> + session = tftp_session(client_ip, client_port,
> + self.server.tftp.base,
> + self.server.tftp.forced_file,
> + self.server.tftp.reader)
> + response = session.process(client_ip, client_port, self.request[0])
> + if response is not None:
> + if log.tracing and self.server.tftp.packet_trace:
> + log.trace(' > ' + session.decode(client_ip,
> + client_port,
> + self.request[0]))
> + timeout = session.get_timeout(self.server.tftp.timeout, 1)
> + sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
> + sock.bind(('', 0))
> + host_ip, host_port = sock.getsockname()
> + sock.settimeout(timeout)
> + while response is not None:
> + log.trace(' < ' + session.decode(client_ip,
> + client_port,
> + response))
> + sock.sendto(response, (client_ip, client_port))
> + if session.finished:
> + break
> + try:
> + data, address = sock.recvfrom(2 + 2 + session.get_block_size())
> + log.trace(' > ' + session.decode(address[0],
> + address[1],
> + data))
> + except socket.error as se:
> + if log.tracing:
> + log.trace('] tftp: %d: receive: %s: error: %s' \
> + % (index, client, se))
> + return
> + except socket.gaierror as se:
> + if log.tracing:
> + return
> + response = session.process(address[0], address[1], data)
> + except error.general as gerr:
> + self._notice('] tftp: %dd: error: %s' % (index, gerr))
> + except error.internal as ierr:
> + self._notice('] tftp: %d: error: %s' % (index, ierr))
> + except error.exit as eerr:
> + pass
> + except KeyboardInterrupt:
> + pass
> + except Exception as e:
> + self._notice('] tftp: %d: error: %s: %s' % (index, type(e), e))
> + self._notice('] tftp: %d: end: %s' % (index, client))
> + def handle(self):
> + if self.server.tftp.sessions is None \
> + or self.server.tftp.session < self.server.tftp.sessions:
> + self.handle_session(self.server.tftp.get_session())
> +class udp_server(socketserver.ThreadingMixIn, socketserver.UDPServer):
> + pass
> +class tftp_server(object):
> + def __init__(self, host, port, timeout = 10, base = None,
> + forced_file = None, sessions = None, reader = None):
> + self.lock = threading.Lock()
> + self.notices = False
> + self.packet_trace = False
> + self.timeout = timeout
> + self.host = host
> + self.port = port
> + self.server = None
> + if base is None:
> + base = os.getcwd()
> + self.base = base
> + if sessions is not None and not isinstance(sessions, int):
> + raise error.general('tftp session count is not a number')
> + self.sessions = sessions
> + self.session = 0
> + self.reader = reader
> + def __del__(self):
> + self.stop()
> + def _lock(self):
> + self.lock.acquire()
> + def _unlock(self):
> + self.lock.release()
> + def start(self):
> + if log.tracing:
> + log.trace('] tftp: server: %s:%i' % (self.host, self.port))
> + if self.host == 'all':
> + host = ''
> + else:
> + host = self.host
> + try:
> + self.server = udp_server((host, self.port), udp_handler)
> + raise error.general('tftp server create: %s' % (e))
> + self.server.tftp = self
> + self.server_thread = threading.Thread(target = self.server.serve_forever)
> + self.server_thread.daemon = True
> + self.server_thread.start()
> + def stop(self):
> + self._lock()
> + try:
> + if self.server is not None:
> + self.server.shutdown()
> + self.server.server_close()
> + finally:
> + self._unlock()
> + def run(self):
> + running = True
> + while running:
> + period = 1
> + self._lock()
> + if self.server is None:
> + running = False
> + period = 0
> + elif self.sessions is not None:
> + if self.sessions == 0:
> + running = False
> + period = 0
> + else:
> + period = 0.25
> + self._unlock()
> + if period > 0:
> + time.sleep(period)
> + self.stop()
> + def get_session(self):
> + count = 0
> + self._lock()
> + try:
> + self.session += 1
> + count = self.session
> + finally:
> + self._unlock()
> + return count
> + def enable_notices(self):
> + self._lock()
> + self.notices = True
> + self._unlock()
> + def trace_packets(self):
> + self._lock()
> + self.packet_trace = True
> + self._unlock()
> +def load_log(logfile):
> + if logfile is None:
> + log.default = log.log(streams = ['stdout'])
> + else:
> + log.default = log.log(streams = [logfile])
> +def run(args = sys.argv, command_path = None):
> + ec = 0
> + notice = None
> + server = None
> + try:
> + description = 'A TFTP Server that supports a read only TFTP session.'
> + nice_cwd = os.path.relpath(os.getcwd())
> + if len(nice_cwd) > len(os.path.abspath(nice_cwd)):
> + nice_cwd = os.path.abspath(nice_cwd)
> + argsp = argparse.ArgumentParser(prog = 'rtems-tftp-server',
> + description = description)
> + argsp.add_argument('-l', '--log',
> + help = 'log file.',
> + type = str, default = None)
> + argsp.add_argument('-v', '--trace',
> + help = 'enable trace logging for debugging.',
> + action = 'store_true', default = False)
> + argsp.add_argument('--trace-packets',
> + help = 'enable trace logging of packets.',
> + argsp.add_argument('-B', '--bind',
> + help = 'address to bind the server too (default: %(default)s).',
> + type = str, default = 'all')
> + argsp.add_argument('-P', '--port',
> + help = 'port to bind the server too (default: %(default)s).',
> + type = int, default = '69')
> + argsp.add_argument('-t', '--timeout',
> + help = 'timeout in seconds, client can override ' \
> + '(default: %(default)s).',
> + type = int, default = '10')
> + argsp.add_argument('-b', '--base',
> + help = 'base path, not checked (default: %(default)s).',
> + type = str, default = nice_cwd)
> + argsp.add_argument('-F', '--force-file',
> + help = 'force the file to be downloaded overriding the client.',
> + argsp.add_argument('-s', '--sessions',
> + help = 'number of TFTP sessions to run before exiting ' \
> + '(default: forever.',
> + type = int, default = None)
> + argopts = argsp.parse_args(args[1:])
> + load_log(argopts.log)
> + log.notice('RTEMS Tools - TFTP Server, %s' % (version.string()))
> + log.output(log.info(args))
> + log.tracing = argopts.trace
> + server = tftp_server(argopts.bind,
> + argopts.port,
> + argopts.timeout,
> + argopts.base,
> + argopts.force_file,
> + argopts.sessions)
> + server.enable_notices()
> + try:
> + server.start()
> + server.run()
> + except:
> + server.stop()
> + raise
> + notice = str(gerr)
> + ec = 1
> + notice = str(ierr)
> + ec = 1
> + pass
> + notice = 'abort: user terminated'
> + ec = 1
> + except:
> + raise
> + notice = 'abort: unknown error'
> + ec = 1
> + if server is not None:
> + del server
> + if notice is not None:
> + log.stderr(notice)
> + sys.exit(ec)
> +if __name__ == "__main__":
> + run()
> diff --git a/tester/rt/tftpy/COPYING b/tester/rt/tftpy/COPYING
> deleted file mode 100644
> index c9f2c9c..0000000
> --- a/tester/rt/tftpy/COPYING
> +++ /dev/null
> @@ -1,21 +0,0 @@
> -The MIT License
> -Copyright (c) 2009 Michael P. Soulier
> -Permission is hereby granted, free of charge, to any person obtaining a copy
> -of this software and associated documentation files (the "Software"), to deal
> -in the Software without restriction, including without limitation the rights
> -to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
> -copies of the Software, and to permit persons to whom the Software is
> -furnished to do so, subject to the following conditions:
> -The above copyright notice and this permission notice shall be included in
> -all copies or substantial portions of the Software.
> -THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
> -IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
> -FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
> -AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
> -LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
> -OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
> -THE SOFTWARE.
> diff --git a/tester/rt/tftpy/README b/tester/rt/tftpy/README
> index ad7a871..0000000
> --- a/tester/rt/tftpy/README
> +++ /dev/null
> @@ -1,115 +0,0 @@
> -Copyright, Michael P. Soulier, 2010.
> -About Release 0.6.2:
> -Maintenance release to fix a couple of reported issues.
> -About Release 0.6.1:
> -Maintenance release to fix several reported problems, including a rollover
> -at 2^16 blocks, and some contributed work on dynamic file objects.
> -About Release 0.6.0:
> -Maintenance update to fix several reported issues, including proper
> -retransmits on timeouts, and further expansion of unit tests.
> -About Release 0.5.1:
> -Maintenance update to fix a bug in the server, overhaul the documentation for
> -the website, fix a typo in the unit tests, fix a failure to set default
> -blocksize, and a divide by zero error in speed calculations for very short
> -transfers.
> -Also, this release adds support for input/output in client as stdin/stdout
> -About Release 0.5.0:
> -Complete rewrite of the state machine.
> -Now fully implements downloading and uploading.
> -About Release 0.4.6:
> -Feature release to add the tsize option.
> -Thanks to Kuba Kończyk for the patch.
> -About Release 0.4.5:
> -Bugfix release for compatability issues on Win32, among other small issues.
> -About Release 0.4.4:
> -Bugfix release for poor tolerance of unsupported options in the server.
> -About Release 0.4.3:
> -Bugfix release for an issue with the server's detection of the end of the file
> -during a download.
> -About Release 0.4.2:
> -Bugfix release for some small installation issues with earlier Python
> -releases.
> -About Release 0.4.1:
> -Bugfix release to fix the installation path, with some restructuring into a
> -tftpy package from the single module used previously.
> -About Release 0.4:
> -This release adds a TftpServer class with a sample implementation in bin.
> -The server uses a single thread with multiple handlers and a select() loop to
> -handle multiple clients simultaneously.
> -Only downloads are supported at this time.
> -About Release 0.3:
> -This release fixes a major RFC 1350 compliance problem with the remote TID.
> -About Release 0.2:
> -This release adds variable block sizes, and general option support,
> -implementing RFCs 2347 and 2348. This is accessible in the TftpClient class
> -via the options dict, or in the sample client via the --blocksize option.
> -About Release 0.1:
> -This is an initial release in the spirit of "release early, release often".
> -Currently the sample client works, supporting RFC 1350. The server is not yet
> -implemented, and RFC 2347 and 2348 support (variable block sizes) is underway,
> -planned for 0.2.
> -About Tftpy:
> -Purpose:
> -Tftpy is a TFTP library for the Python programming language. It includes
> -client and server classes, with sample implementations. Hooks are included for
> -easy inclusion in a UI for populating progress indicators. It supports RFCs
> -1350, 2347, 2348 and the tsize option from RFC 2349.
> -Dependencies:
> -Python 2.3+, hopefully. Let me know if it fails to work.
> -Trifles:
> -Home page: http://tftpy.sf.net/
> -Project page: http://sourceforge.net/projects/tftpy/
> -License is the MIT License
> -See COPYING in this distribution.
> -Limitations:
> -- Only 'octet' mode is supported.
> -- The only options supported are blksize and tsize.
> -Author:
> -Michael P. Soulier <msoulier at digitaltorque.ca>
> diff --git a/tester/rt/tftpy/TftpClient.py b/tester/rt/tftpy/TftpClient.py
> index eb82c05..0000000
> --- a/tester/rt/tftpy/TftpClient.py
> +++ /dev/null
> @@ -1,107 +0,0 @@
> -# vim: ts=4 sw=4 et ai:
> -# -*- coding: utf8 -*-
> -"""This module implements the TFTP Client functionality. Instantiate an
> -instance of the client, and then use its upload or download method. Logging is
> -performed via a standard logging object set in TftpShared."""
> -import types
> -import logging
> -from .TftpShared import *
> -from .TftpPacketTypes import *
> -from .TftpContexts import TftpContextClientDownload, TftpContextClientUpload
> -log = logging.getLogger('tftpy.TftpClient')
> -class TftpClient(TftpSession):
> - """This class is an implementation of a tftp client. Once instantiated, a
> - download can be initiated via the download() method, or an upload via the
> - upload() method."""
> - def __init__(self, host, port=69, options={}, localip = ""):
> - TftpSession.__init__(self)
> - self.context = None
> - self.host = host
> - self.iport = port
> - self.filename = None
> - self.options = options
> - self.localip = localip
> - if 'blksize' in self.options:
> - size = self.options['blksize']
> - tftpassert(int == type(size), "blksize must be an int")
> - if size < MIN_BLKSIZE or size > MAX_BLKSIZE:
> - raise TftpException("Invalid blksize: %d" % size)
> - def download(self, filename, output, packethook=None, timeout=SOCK_TIMEOUT):
> - """This method initiates a tftp download from the configured remote
> - host, requesting the filename passed. It writes the file to output,
> - which can be a file-like object or a path to a local file. If a
> - packethook is provided, it must be a function that takes a single
> - parameter, which will be a copy of each DAT packet received in the
> - form of a TftpPacketDAT object. The timeout parameter may be used to
> - override the default SOCK_TIMEOUT setting, which is the amount of time
> - that the client will wait for a receive packet to arrive.
> - Note: If output is a hyphen, stdout is used."""
> - # We're downloading.
> - log.debug("Creating download context with the following params:")
> - log.debug("host = %s, port = %s, filename = %s" % (self.host, self.iport, filename))
> - log.debug("options = %s, packethook = %s, timeout = %s" % (self.options, packethook, timeout))
> - self.context = TftpContextClientDownload(self.host,
> - self.iport,
> - filename,
> - output,
> - self.options,
> - packethook,
> - timeout,
> - localip = self.localip)
> - self.context.start()
> - # Download happens here
> - self.context.end()
> - metrics = self.context.metrics
> - log.info('')
> - log.info("Download complete.")
> - if metrics.duration == 0:
> - log.info("Duration too short, rate undetermined")
> - else:
> - log.info("Downloaded %.2f bytes in %.2f seconds" % (metrics.bytes, metrics.duration))
> - log.info("Average rate: %.2f kbps" % metrics.kbps)
> - log.info("%.2f bytes in resent data" % metrics.resent_bytes)
> - log.info("Received %d duplicate packets" % metrics.dupcount)
> - def upload(self, filename, input, packethook=None, timeout=SOCK_TIMEOUT):
> - """This method initiates a tftp upload to the configured remote host,
> - uploading the filename passed. It reads the file from input, which
> - can be a file-like object or a path to a local file. If a packethook
> - is provided, it must be a function that takes a single parameter,
> - which will be a copy of each DAT packet sent in the form of a
> - TftpPacketDAT object. The timeout parameter may be used to override
> - the default SOCK_TIMEOUT setting, which is the amount of time that
> - the client will wait for a DAT packet to be ACKd by the server.
> - Note: If input is a hyphen, stdin is used."""
> - self.context = TftpContextClientUpload(self.host,
> - self.iport,
> - filename,
> - input,
> - self.options,
> - packethook,
> - timeout,
> - # Upload happens here
> - log.info('')
> - log.info("Upload complete.")
> - else:
> - log.info("Uploaded %d bytes in %.2f seconds" % (metrics.bytes, metrics.duration))
> - log.info("Resent %d packets" % metrics.dupcount)
> diff --git a/tester/rt/tftpy/TftpContexts.py b/tester/rt/tftpy/TftpContexts.py
> index da85886..0000000
> --- a/tester/rt/tftpy/TftpContexts.py
> +++ /dev/null
> @@ -1,429 +0,0 @@
> -"""This module implements all contexts for state handling during uploads and
> -downloads, the main interface to which being the TftpContext base class.
> -The concept is simple. Each context object represents a single upload or
> -download, and the state object in the context object represents the current
> -state of that transfer. The state object has a handle() method that expects
> -the next packet in the transfer, and returns a state object until the transfer
> -is complete, at which point it returns None. That is, unless there is a fatal
> -error, in which case a TftpException is returned instead."""
> -from .TftpPacketFactory import TftpPacketFactory
> -from .TftpStates import *
> -import socket
> -import time
> -import sys
> -import os
> -import logging
> -log = logging.getLogger('tftpy.TftpContext')
> -# Utility classes
> -class TftpMetrics(object):
> - """A class representing metrics of the transfer."""
> - def __init__(self):
> - # Bytes transferred
> - self.bytes = 0
> - # Bytes re-sent
> - self.resent_bytes = 0
> - # Duplicate packets received
> - self.dups = {}
> - self.dupcount = 0
> - # Times
> - self.start_time = 0
> - self.end_time = 0
> - self.duration = 0
> - # Rates
> - self.bps = 0
> - self.kbps = 0
> - # Generic errors
> - self.errors = 0
> - def compute(self):
> - # Compute transfer time
> - self.duration = self.end_time - self.start_time
> - if self.duration == 0:
> - self.duration = 1
> - log.debug("TftpMetrics.compute: duration is %s", self.duration)
> - self.bps = (self.bytes * 8.0) / self.duration
> - self.kbps = self.bps / 1024.0
> - log.debug("TftpMetrics.compute: kbps is %s", self.kbps)
> - for key in self.dups:
> - self.dupcount += self.dups[key]
> - def add_dup(self, pkt):
> - """This method adds a dup for a packet to the metrics."""
> - log.debug("Recording a dup of %s", pkt)
> - s = str(pkt)
> - if s in self.dups:
> - self.dups[s] += 1
> - else:
> - self.dups[s] = 1
> - tftpassert(self.dups[s] < MAX_DUPS, "Max duplicates reached")
> -# Context classes
> -class TftpContext(object):
> - """The base class of the contexts."""
> - def __init__(self, host, port, timeout, localip = ""):
> - """Constructor for the base context, setting shared instance
> - variables."""
> - self.file_to_transfer = None
> - self.fileobj = None
> - self.options = None
> - self.packethook = None
> - self.sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
> - if localip != "":
> - self.sock.bind((localip, 0))
> - self.sock.settimeout(timeout)
> - self.timeout = timeout
> - self.state = None
> - self.next_block = 0
> - self.factory = TftpPacketFactory()
> - # Note, setting the host will also set self.address, as it's a property.
> - self.host = host
> - self.port = port
> - # The port associated with the TID
> - self.tidport = None
> - # Metrics
> - self.metrics = TftpMetrics()
> - # Fluag when the transfer is pending completion.
> - self.pending_complete = False
> - # Time when this context last received any traffic.
> - # FIXME: does this belong in metrics?
> - self.last_update = 0
> - # The last packet we sent, if applicable, to make resending easy.
> - self.last_pkt = None
> - # Count the number of retry attempts.
> - self.retry_count = 0
> - def getBlocksize(self):
> - """Fetch the current blocksize for this session."""
> - return int(self.options.get('blksize', 512))
> - def __del__(self):
> - """Simple destructor to try to call housekeeping in the end method if
> - not called explicitely. Leaking file descriptors is not a good
> - thing."""
> - self.end()
> - def checkTimeout(self, now):
> - """Compare current time with last_update time, and raise an exception
> - if we're over the timeout time."""
> - log.debug("checking for timeout on session %s", self)
> - if now - self.last_update > self.timeout:
> - raise TftpTimeout("Timeout waiting for traffic")
> - def start(self):
> - raise NotImplementedError("Abstract method")
> - def end(self, close_fileobj=True):
> - """Perform session cleanup, since the end method should always be
> - called explicitely by the calling code, this works better than the
> - destructor.
> - Set close_fileobj to False so fileobj can be returned open."""
> - log.debug("in TftpContext.end - closing socket")
> - self.sock.close()
> - if close_fileobj and self.fileobj is not None and not self.fileobj.closed:
> - log.debug("self.fileobj is open - closing")
> - self.fileobj.close()
> - def gethost(self):
> - "Simple getter method for use in a property."
> - return self.__host
> - def sethost(self, host):
> - """Setter method that also sets the address property as a result
> - of the host that is set."""
> - self.__host = host
> - self.address = socket.gethostbyname(host)
> - host = property(gethost, sethost)
> - def setNextBlock(self, block):
> - if block >= 2 ** 16:
> - log.debug("Block number rollover to 0 again")
> - block = 0
> - self.__eblock = block
> - def getNextBlock(self):
> - return self.__eblock
> - next_block = property(getNextBlock, setNextBlock)
> - def cycle(self):
> - """Here we wait for a response from the server after sending it
> - something, and dispatch appropriate action to that response."""
> - try:
> - (buffer, (raddress, rport)) = self.sock.recvfrom(MAX_BLKSIZE)
> - except socket.timeout:
> - log.warning("Timeout waiting for traffic, retrying...")
> - raise TftpTimeout("Timed-out waiting for traffic")
> - # Ok, we've received a packet. Log it.
> - log.debug("Received %d bytes from %s:%s",
> - len(buffer), raddress, rport)
> - # And update our last updated time.
> - self.last_update = time.time()
> - # Decode it.
> - recvpkt = self.factory.parse(buffer)
> - # Check for known "connection".
> - if raddress != self.address:
> - log.warning("Received traffic from %s, expected host %s. Discarding"
> - % (raddress, self.host))
> - if self.tidport and self.tidport != rport:
> - log.warning("Received traffic from %s:%s but we're "
> - "connected to %s:%s. Discarding."
> - % (raddress, rport,
> - self.host, self.tidport))
> - # If there is a packethook defined, call it. We unconditionally
> - # pass all packets, it's up to the client to screen out different
> - # kinds of packets. This way, the client is privy to things like
> - # negotiated options.
> - if self.packethook:
> - self.packethook(recvpkt)
> - # And handle it, possibly changing state.
> - self.state = self.state.handle(recvpkt, raddress, rport)
> - # If we didn't throw any exceptions here, reset the retry_count to
> - # zero.
> -class TftpContextServer(TftpContext):
> - """The context for the server."""
> - host,
> - port,
> - timeout,
> - root,
> - dyn_file_func=None,
> - upload_open=None):
> - TftpContext.__init__(self,
> - host,
> - port,
> - timeout,
> - # At this point we have no idea if this is a download or an upload. We
> - # need to let the start state determine that.
> - self.state = TftpStateServerStart(self)
> - self.root = root
> - self.dyn_file_func = dyn_file_func
> - self.upload_open = upload_open
> - def __str__(self):
> - return "%s:%s %s" % (self.host, self.port, self.state)
> - def start(self, buffer):
> - """Start the state cycle. Note that the server context receives an
> - initial packet in its start method. Also note that the server does not
> - loop on cycle(), as it expects the TftpServer object to manage
> - that."""
> - log.debug("In TftpContextServer.start")
> - self.metrics.start_time = time.time()
> - log.debug("Set metrics.start_time to %s", self.metrics.start_time)
> - pkt = self.factory.parse(buffer)
> - log.debug("TftpContextServer.start() - factory returned a %s", pkt)
> - # Call handle once with the initial packet. This should put us into
> - # the download or the upload state.
> - self.state = self.state.handle(pkt,
> - self.host,
> - self.port)
> - def end(self):
> - """Finish up the context."""
> - TftpContext.end(self)
> - self.metrics.end_time = time.time()
> - log.debug("Set metrics.end_time to %s", self.metrics.end_time)
> - self.metrics.compute()
> -class TftpContextClientUpload(TftpContext):
> - """The upload context for the client during an upload.
> - Note: If input is a hyphen, then we will use stdin."""
> - host,
> - port,
> - filename,
> - input,
> - options,
> - packethook,
> - timeout,
> - localip = ""):
> - host,
> - port,
> - timeout,
> - localip)
> - self.file_to_transfer = filename
> - self.packethook = packethook
> - # If the input object has a read() function,
> - # assume it is file-like.
> - if hasattr(input, 'read'):
> - self.fileobj = input
> - elif input == '-':
> - self.fileobj = sys.stdin
> - else:
> - self.fileobj = open(input, "rb")
> - log.debug("TftpContextClientUpload.__init__()")
> - log.debug("file_to_transfer = %s, options = %s" %
> - (self.file_to_transfer, self.options))
> - def start(self):
> - log.info("Sending tftp upload request to %s" % self.host)
> - log.info(" filename -> %s" % self.file_to_transfer)
> - log.info(" options -> %s" % self.options)
> - log.debug("Set metrics.start_time to %s" % self.metrics.start_time)
> - # FIXME: put this in a sendWRQ method?
> - pkt = TftpPacketWRQ()
> - pkt.filename = self.file_to_transfer
> - pkt.mode = "octet" # FIXME - shouldn't hardcode this
> - pkt.options = self.options
> - self.sock.sendto(pkt.encode().buffer, (self.host, self.port))
> - self.next_block = 1
> - self.last_pkt = pkt
> - # FIXME: should we centralize sendto operations so we can refactor all
> - # saving of the packet to the last_pkt field?
> - self.state = TftpStateSentWRQ(self)
> - while self.state:
> - try:
> - log.debug("State is %s" % self.state)
> - self.cycle()
> - except TftpTimeout as err:
> - log.error(str(err))
> - self.retry_count += 1
> - if self.retry_count >= TIMEOUT_RETRIES:
> - log.debug("hit max retries, giving up")
> - raise
> - else:
> - log.warning("resending last packet")
> - self.state.resendLast()
> - def end(self):
> - log.debug("Set metrics.end_time to %s" % self.metrics.end_time)
> -class TftpContextClientDownload(TftpContext):
> - """The download context for the client during a download.
> - Note: If output is a hyphen, then the output will be sent to stdout."""
> - host,
> - port,
> - filename,
> - output,
> - options,
> - packethook,
> - timeout,
> - localip = ""):
> - host,
> - port,
> - timeout,
> - localip)
> - # FIXME: should we refactor setting of these params?
> - self.filelike_fileobj = False
> - # If the output object has a write() function,
> - if hasattr(output, 'write'):
> - self.fileobj = output
> - self.filelike_fileobj = True
> - # If the output filename is -, then use stdout
> - elif output == '-':
> - self.fileobj = sys.stdout
> - else:
> - self.fileobj = open(output, "wb")
> - log.debug("TftpContextClientDownload.__init__()")
> - def start(self):
> - """Initiate the download."""
> - log.info("Sending tftp download request to %s" % self.host)
> - # FIXME: put this in a sendRRQ method?
> - pkt = TftpPacketRRQ()
> - self.state = TftpStateSentRRQ(self)
> - while self.state:
> - try:
> - self.cycle()
> - raise
> - else:
> - except TftpFileNotFoundError as err:
> - # If we received file not found, then we should not save the open
> - # output file or we'll be left with a size zero file. Delete it,
> - # if it exists.
> - log.error("Received File not found error")
> - if self.fileobj is not None and not self.filelike_fileobj:
> - if os.path.exists(self.fileobj.name):
> - log.debug("unlinking output file of %s", self.fileobj.name)
> - os.unlink(self.fileobj.name)
> - raise
> - def end(self):
> - TftpContext.end(self, not self.filelike_fileobj)
> diff --git a/tester/rt/tftpy/TftpPacketFactory.py b/tester/rt/tftpy/TftpPacketFactory.py
> index 41f39a9..0000000
> --- a/tester/rt/tftpy/TftpPacketFactory.py
> +++ /dev/null
> @@ -1,47 +0,0 @@
> -"""This module implements the TftpPacketFactory class, which can take a binary
> -buffer, and return the appropriate TftpPacket object to represent it, via the
> -parse() method."""
> -import logging
> -log = logging.getLogger('tftpy.TftpPacketFactory')
> -class TftpPacketFactory(object):
> - """This class generates TftpPacket objects. It is responsible for parsing
> - raw buffers off of the wire and returning objects representing them, via
> - the parse() method."""
> - self.classes = {
> - 1: TftpPacketRRQ,
> - 2: TftpPacketWRQ,
> - 3: TftpPacketDAT,
> - 4: TftpPacketACK,
> - 5: TftpPacketERR,
> - 6: TftpPacketOACK
> - def parse(self, buffer):
> - """This method is used to parse an existing datagram into its
> - corresponding TftpPacket object. The buffer is the raw bytes off of
> - the network."""
> - log.debug("parsing a %d byte packet" % len(buffer))
> - (opcode,) = struct.unpack(str("!H"), buffer[:2])
> - log.debug("opcode is %d" % opcode)
> - packet = self.__create(opcode)
> - packet.buffer = buffer
> - return packet.decode()
> - def __create(self, opcode):
> - """This method returns the appropriate class object corresponding to
> - the passed opcode."""
> - tftpassert(opcode in self.classes,
> - "Unsupported opcode: %d" % opcode)
> - packet = self.classes[opcode]()
> - return packet
> diff --git a/tester/rt/tftpy/TftpPacketTypes.py b/tester/rt/tftpy/TftpPacketTypes.py
> index 3d3bdf8..0000000
> --- a/tester/rt/tftpy/TftpPacketTypes.py
> +++ /dev/null
> @@ -1,494 +0,0 @@
> -"""This module implements the packet types of TFTP itself, and the
> -corresponding encode and decode methods for them."""
> -import struct
> -import sys
> -import logging
> -log = logging.getLogger('tftpy.TftpPacketTypes')
> -class TftpSession(object):
> - """This class is the base class for the tftp client and server. Any shared
> - code should be in this class."""
> - # FIXME: do we need this anymore?
> - pass
> -class TftpPacketWithOptions(object):
> - """This class exists to permit some TftpPacket subclasses to share code
> - regarding options handling. It does not inherit from TftpPacket, as the
> - goal is just to share code here, and not cause diamond inheritance."""
> - self.options = {}
> - # Always use unicode strings, except at the encode/decode barrier.
> - # Simpler to keep things clear.
> - def setoptions(self, options):
> - log.debug("in TftpPacketWithOptions.setoptions")
> - log.debug("options: %s", options)
> - myoptions = {}
> - for key in options:
> - newkey = key
> - if isinstance(key, bytes):
> - newkey = newkey.decode('ascii')
> - newval = options[key]
> - if isinstance(newval, bytes):
> - newval = newval.decode('ascii')
> - myoptions[newkey] = newval
> - log.debug("populated myoptions with %s = %s", newkey, myoptions[newkey])
> - log.debug("setting options hash to: %s", myoptions)
> - self._options = myoptions
> - def getoptions(self):
> - log.debug("in TftpPacketWithOptions.getoptions")
> - return self._options
> - # Set up getter and setter on options to ensure that they are the proper
> - # type. They should always be strings, but we don't need to force the
> - # client to necessarily enter strings if we can avoid it.
> - options = property(getoptions, setoptions)
> - def decode_options(self, buffer):
> - """This method decodes the section of the buffer that contains an
> - unknown number of options. It returns a dictionary of option names and
> - values."""
> - fmt = b"!"
> - options = {}
> - log.debug("decode_options: buffer is: %s", repr(buffer))
> - log.debug("size of buffer is %d bytes", len(buffer))
> - if len(buffer) == 0:
> - log.debug("size of buffer is zero, returning empty hash")
> - return {}
> - # Count the nulls in the buffer. Each one terminates a string.
> - log.debug("about to iterate options buffer counting nulls")
> - length = 0
> - for i in range(len(buffer)):
> - if ord(buffer[i:i+1]) == 0:
> - log.debug("found a null at length %d", length)
> - if length > 0:
> - fmt += b"%dsx" % length
> - length = -1
> - else:
> - raise TftpException("Invalid options in buffer")
> - length += 1
> - log.debug("about to unpack, fmt is: %s", fmt)
> - mystruct = struct.unpack(fmt, buffer)
> - tftpassert(len(mystruct) % 2 == 0,
> - "packet with odd number of option/value pairs")
> - for i in range(0, len(mystruct), 2):
> - key = mystruct[i].decode('ascii')
> - val = mystruct[i+1].decode('ascii')
> - log.debug("setting option %s to %s", key, val)
> - log.debug("types are %s and %s", type(key), type(val))
> - options[key] = val
> - return options
> -class TftpPacket(object):
> - """This class is the parent class of all tftp packet classes. It is an
> - abstract class, providing an interface, and should not be instantiated
> - directly."""
> - self.opcode = 0
> - self.buffer = None
> - def encode(self):
> - """The encode method of a TftpPacket takes keyword arguments specific
> - to the type of packet, and packs an appropriate buffer in network-byte
> - order suitable for sending over the wire.
> - This is an abstract method."""
> - def decode(self):
> - """The decode method of a TftpPacket takes a buffer off of the wire in
> - network-byte order, and decodes it, populating internal properties as
> - appropriate. This can only be done once the first 2-byte opcode has
> - already been decoded, but the data section does include the entire
> - datagram.
> -class TftpPacketInitial(TftpPacket, TftpPacketWithOptions):
> - """This class is a common parent class for the RRQ and WRQ packets, as
> - they share quite a bit of code."""
> - TftpPacket.__init__(self)
> - TftpPacketWithOptions.__init__(self)
> - self.mode = None
> - def encode(self):
> - """Encode the packet's buffer from the instance variables."""
> - tftpassert(self.filename, "filename required in initial packet")
> - tftpassert(self.mode, "mode required in initial packet")
> - # Make sure filename and mode are bytestrings.
> - filename = self.filename
> - mode = self.mode
> - if not isinstance(filename, bytes):
> - filename = filename.encode('ascii')
> - if not isinstance(self.mode, bytes):
> - mode = mode.encode('ascii')
> - ptype = None
> - if self.opcode == 1: ptype = "RRQ"
> - else: ptype = "WRQ"
> - log.debug("Encoding %s packet, filename = %s, mode = %s",
> - ptype, filename, mode)
> - for key in self.options:
> - log.debug(" Option %s = %s", key, self.options[key])
> - fmt = b"!H"
> - fmt += b"%dsx" % len(filename)
> - if mode == b"octet":
> - fmt += b"5sx"
> - else:
> - raise AssertionError("Unsupported mode: %s" % mode)
> - # Add options. Note that the options list must be bytes.
> - options_list = []
> - if len(list(self.options.keys())) > 0:
> - log.debug("there are options to encode")
> - # Populate the option name
> - name = key
> - if not isinstance(name, bytes):
> - name = name.encode('ascii')
> - options_list.append(name)
> - fmt += b"%dsx" % len(name)
> - # Populate the option value
> - value = self.options[key]
> - # Work with all strings.
> - if isinstance(value, int):
> - value = str(value)
> - if not isinstance(value, bytes):
> - value = value.encode('ascii')
> - options_list.append(value)
> - fmt += b"%dsx" % len(value)
> - log.debug("fmt is %s", fmt)
> - log.debug("options_list is %s", options_list)
> - log.debug("size of struct is %d", struct.calcsize(fmt))
> - self.buffer = struct.pack(fmt,
> - self.opcode,
> - filename,
> - mode,
> - *options_list)
> - log.debug("buffer is %s", repr(self.buffer))
> - return self
> - def decode(self):
> - tftpassert(self.buffer, "Can't decode, buffer is empty")
> - # FIXME - this shares a lot of code with decode_options
> - nulls = 0
> - fmt = b""
> - nulls = length = tlength = 0
> - log.debug("in decode: about to iterate buffer counting nulls")
> - subbuf = self.buffer[2:]
> - for i in range(len(subbuf)):
> - if ord(subbuf[i:i+1]) == 0:
> - nulls += 1
> - log.debug("found a null at length %d, now have %d", length, nulls)
> - length = -1
> - # At 2 nulls, we want to mark that position for decoding.
> - if nulls == 2:
> - break
> - length += 1
> - tlength += 1
> - log.debug("hopefully found end of mode at length %d", tlength)
> - # length should now be the end of the mode.
> - tftpassert(nulls == 2, "malformed packet")
> - shortbuf = subbuf[:tlength+1]
> - log.debug("about to unpack buffer with fmt: %s", fmt)
> - log.debug("unpacking buffer: %s", repr(shortbuf))
> - mystruct = struct.unpack(fmt, shortbuf)
> - tftpassert(len(mystruct) == 2, "malformed packet")
> - self.filename = mystruct[0].decode('ascii')
> - self.mode = mystruct[1].decode('ascii').lower() # force lc - bug 17
> - log.debug("set filename to %s", self.filename)
> - log.debug("set mode to %s", self.mode)
> - self.options = self.decode_options(subbuf[tlength+1:])
> - log.debug("options dict is now %s", self.options)
> - return self
> -class TftpPacketRRQ(TftpPacketInitial):
> - 2 bytes string 1 byte string 1 byte
> - RRQ/ | 01/02 | Filename | 0 | Mode | 0 |
> - WRQ -----------------------------------------------
> - TftpPacketInitial.__init__(self)
> - self.opcode = 1
> - s = 'RRQ packet: filename = %s' % self.filename
> - s += ' mode = %s' % self.mode
> - if self.options:
> - s += '\n options = %s' % self.options
> - return s
> -class TftpPacketWRQ(TftpPacketInitial):
> - self.opcode = 2
> - s = 'WRQ packet: filename = %s' % self.filename
> - if self.options:
> - return s
> -class TftpPacketDAT(TftpPacket):
> - 2 bytes 2 bytes n bytes
> - DATA | 03 | Block # | Data |
> - self.opcode = 3
> - self.blocknumber = 0
> - self.data = None
> - s = 'DAT packet: block %s' % self.blocknumber
> - if self.data:
> - s += '\n data: %d bytes' % len(self.data)
> - return s
> - def encode(self):
> - """Encode the DAT packet. This method populates self.buffer, and
> - returns self for easy method chaining."""
> - if len(self.data) == 0:
> - log.debug("Encoding an empty DAT packet")
> - data = self.data
> - if not isinstance(self.data, bytes):
> - data = self.data.encode('ascii')
> - fmt = b"!HH%ds" % len(data)
> - self.opcode,
> - self.blocknumber,
> - data)
> - return self
> - def decode(self):
> - """Decode self.buffer into instance variables. It returns self for
> - easy method chaining."""
> - # We know the first 2 bytes are the opcode. The second two are the
> - # block number.
> - (self.blocknumber,) = struct.unpack(str("!H"), self.buffer[2:4])
> - log.debug("decoding DAT packet, block number %d", self.blocknumber)
> - log.debug("should be %d bytes in the packet total", len(self.buffer))
> - # Everything else is data.
> - self.data = self.buffer[4:]
> - log.debug("found %d bytes of data", len(self.data))
> - return self
> -class TftpPacketACK(TftpPacket):
> - 2 bytes 2 bytes
> - ACK | 04 | Block # |
> - self.opcode = 4
> - return 'ACK packet: block %d' % self.blocknumber
> - def encode(self):
> - log.debug("encoding ACK: opcode = %d, block = %d",
> - self.opcode, self.blocknumber)
> - self.buffer = struct.pack(str("!HH"), self.opcode, self.blocknumber)
> - return self
> - def decode(self):
> - if len(self.buffer) > 4:
> - log.debug("detected TFTP ACK but request is too large, will truncate")
> - log.debug("buffer was: %s", repr(self.buffer))
> - self.buffer = self.buffer[0:4]
> - self.opcode, self.blocknumber = struct.unpack(str("!HH"), self.buffer)
> - log.debug("decoded ACK packet: opcode = %d, block = %d",
> - return self
> -class TftpPacketERR(TftpPacket):
> - 2 bytes 2 bytes string 1 byte
> - ERROR | 05 | ErrorCode | ErrMsg | 0 |
> - Error Codes
> - Value Meaning
> - 0 Not defined, see error message (if any).
> - 1 File not found.
> - 2 Access violation.
> - 3 Disk full or allocation exceeded.
> - 4 Illegal TFTP operation.
> - 5 Unknown transfer ID.
> - 6 File already exists.
> - 7 No such user.
> - 8 Failed to negotiate options
> - self.opcode = 5
> - self.errorcode = 0
> - # FIXME: We don't encode the errmsg...
> - self.errmsg = None
> - # FIXME - integrate in TftpErrors references?
> - self.errmsgs = {
> - 1: b"File not found",
> - 2: b"Access violation",
> - 3: b"Disk full or allocation exceeded",
> - 4: b"Illegal TFTP operation",
> - 5: b"Unknown transfer ID",
> - 6: b"File already exists",
> - 7: b"No such user",
> - 8: b"Failed to negotiate options"
> - s = 'ERR packet: errorcode = %d' % self.errorcode
> - s += '\n msg = %s' % self.errmsgs.get(self.errorcode, '')
> - return s
> - def encode(self):
> - """Encode the DAT packet based on instance variables, populating
> - self.buffer, returning self."""
> - fmt = b"!HH%dsx" % len(self.errmsgs[self.errorcode])
> - log.debug("encoding ERR packet with fmt %s", fmt)
> - self.opcode,
> - self.errorcode,
> - self.errmsgs[self.errorcode])
> - return self
> - def decode(self):
> - "Decode self.buffer, populating instance variables and return self."
> - buflen = len(self.buffer)
> - tftpassert(buflen >= 4, "malformed ERR packet, too short")
> - log.debug("Decoding ERR packet, length %s bytes", buflen)
> - if buflen == 4:
> - log.debug("Allowing this affront to the RFC of a 4-byte packet")
> - fmt = b"!HH"
> - log.debug("Decoding ERR packet with fmt: %s", fmt)
> - self.opcode, self.errorcode = struct.unpack(fmt,
> - self.buffer)
> - else:
> - log.debug("Good ERR packet > 4 bytes")
> - fmt = b"!HH%dsx" % (len(self.buffer) - 5)
> - self.opcode, self.errorcode, self.errmsg = struct.unpack(fmt,
> - self.buffer)
> - log.error("ERR packet - errorcode: %d, message: %s"
> - % (self.errorcode, self.errmsg))
> - return self
> -class TftpPacketOACK(TftpPacket, TftpPacketWithOptions):
> - | opc | opt1 | 0 | value1 | 0 | optN | 0 | valueN | 0 |
> - self.opcode = 6
> - return 'OACK packet:\n options = %s' % self.options
> - def encode(self):
> - fmt = b"!H" # opcode
> - options_list = []
> - log.debug("in TftpPacketOACK.encode")
> - if not isinstance(key, bytes):
> - key = key.encode('ascii')
> - log.debug("looping on option key %s", key)
> - log.debug("value is %s", value)
> - fmt += b"%dsx" % len(key)
> - options_list.append(key)
> - self.buffer = struct.pack(fmt, self.opcode, *options_list)
> - return self
> - def decode(self):
> - self.options = self.decode_options(self.buffer[2:])
> - return self
> - def match_options(self, options):
> - """This method takes a set of options, and tries to match them with
> - its own. It can accept some changes in those options from the server as
> - part of a negotiation. Changed or unchanged, it will return a dict of
> - the options so that the session can update itself to the negotiated
> - options."""
> - for name in self.options:
> - if name in options:
> - if name == 'blksize':
> - # We can accept anything between the min and max values.
> - size = int(self.options[name])
> - if size >= MIN_BLKSIZE and size <= MAX_BLKSIZE:
> - log.debug("negotiated blksize of %d bytes", size)
> - options['blksize'] = size
> - else:
> - raise TftpException("blksize %s option outside allowed range" % size)
> - elif name == 'tsize':
> - if size < 0:
> - raise TftpException("Negative file sizes not supported")
> - else:
> - raise TftpException("Unsupported option: %s" % name)
> - return True
> diff --git a/tester/rt/tftpy/TftpServer.py b/tester/rt/tftpy/TftpServer.py
> index 2789322..0000000
> --- a/tester/rt/tftpy/TftpServer.py
> +++ /dev/null
> @@ -1,271 +0,0 @@
> -"""This module implements the TFTP Server functionality. Instantiate an
> -instance of the server, and then run the listen() method to listen for client
> -requests. Logging is performed via a standard logging object set in
> -TftpShared."""
> -import socket, os, time
> -import select
> -import threading
> -import logging
> -from errno import EINTR
> -from .TftpContexts import TftpContextServer
> -log = logging.getLogger('tftpy.TftpServer')
> -class TftpServer(TftpSession):
> - """This class implements a tftp server object. Run the listen() method to
> - listen for client requests.
> - tftproot is the path to the tftproot directory to serve files from and/or
> - write them to.
> - dyn_file_func is a callable that takes a requested download
> - path that is not present on the file system and must return either a
> - file-like object to read from or None if the path should appear as not
> - found. This permits the serving of dynamic content.
> - upload_open is a callable that is triggered on every upload with the
> - requested destination path and server context. It must either return a
> - file-like object ready for writing or None if the path is invalid."""
> - tftproot='/tftpboot',
> - self.listenip = None
> - self.listenport = None
> - self.sock = None
> - # FIXME: What about multiple roots?
> - self.root = os.path.abspath(tftproot)
> - # A dict of sessions, where each session is keyed by a string like
> - # ip:tid for the remote end.
> - self.sessions = {}
> - # A threading event to help threads synchronize with the server
> - # is_running state.
> - self.is_running = threading.Event()
> - self.shutdown_gracefully = False
> - self.shutdown_immediately = False
> - for name in 'dyn_file_func', 'upload_open':
> - attr = getattr(self, name)
> - if attr and not callable(attr):
> - raise TftpException("{} supplied, but it is not callable.".format(name))
> - if os.path.exists(self.root):
> - log.debug("tftproot %s does exist", self.root)
> - if not os.path.isdir(self.root):
> - raise TftpException("The tftproot must be a directory.")
> - else:
> - log.debug("tftproot %s is a directory" % self.root)
> - if os.access(self.root, os.R_OK):
> - log.debug("tftproot %s is readable" % self.root)
> - else:
> - raise TftpException("The tftproot must be readable")
> - if os.access(self.root, os.W_OK):
> - log.debug("tftproot %s is writable" % self.root)
> - else:
> - log.warning("The tftproot %s is not writable" % self.root)
> - else:
> - raise TftpException("The tftproot does not exist.")
> - if self.sock is not None:
> - try:
> - self.sock.close()
> - except:
> - pass
> - def listen(self, listenip="", listenport=DEF_TFTP_PORT,
> - timeout=SOCK_TIMEOUT):
> - """Start a server listening on the supplied interface and port. This
> - defaults to INADDR_ANY (all interfaces) and UDP port 69. You can also
> - supply a different socket timeout value, if desired."""
> - tftp_factory = TftpPacketFactory()
> - # Don't use new 2.5 ternary operator yet
> - # listenip = listenip if listenip else '0.0.0.0'
> - if not listenip: listenip = '0.0.0.0'
> - log.info("Server requested on ip %s, port %s" % (listenip, listenport))
> - try:
> - # FIXME - sockets should be non-blocking
> - self.sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
> - self.sock.bind((listenip, listenport))
> - _, self.listenport = self.sock.getsockname()
> - except socket.error as err:
> - # Reraise it for now.
> - raise err
> - self.is_running.set()
> - log.info("Starting receive loop...")
> - while True:
> - log.debug("shutdown_immediately is %s" % self.shutdown_immediately)
> - log.debug("shutdown_gracefully is %s" % self.shutdown_gracefully)
> - if self.shutdown_immediately:
> - log.warning("Shutting down now. Session count: %d" %
> - len(self.sessions))
> - self.sock.close()
> - for key in self.sessions:
> - self.sessions[key].end()
> - self.sessions = []
> - break
> - elif self.shutdown_gracefully:
> - if not self.sessions:
> - log.warning("In graceful shutdown mode and all "
> - "sessions complete.")
> - self.sock.close()
> - break
> - # Build the inputlist array of sockets to select() on.
> - inputlist = []
> - inputlist.append(self.sock)
> - inputlist.append(self.sessions[key].sock)
> - # Block until some socket has input on it.
> - log.debug("Performing select on this inputlist: %s", inputlist)
> - try:
> - readyinput, readyoutput, readyspecial = \
> - select.select(inputlist, [], [], SOCK_TIMEOUT)
> - except select.error as err:
> - if err[0] == EINTR:
> - # Interrupted system call
> - log.debug("Interrupted syscall, retrying")
> - continue
> - else:
> - raise
> - deletion_list = []
> - # Handle the available data, if any. Maybe we timed-out.
> - for readysock in readyinput:
> - # Is the traffic on the main server socket? ie. new session?
> - if readysock == self.sock:
> - log.debug("Data ready on our main socket")
> - buffer, (raddress, rport) = self.sock.recvfrom(MAX_BLKSIZE)
> - log.debug("Read %d bytes", len(buffer))
> - if self.shutdown_gracefully:
> - log.warning("Discarding data on main port, "
> - "in graceful shutdown mode")
> - continue
> - # Forge a session key based on the client's IP and port,
> - # which should safely work through NAT.
> - key = "%s:%s" % (raddress, rport)
> - if not key in self.sessions:
> - log.debug("Creating new server context for "
> - "session key = %s" % key)
> - try:
> - self.sessions[key] = TftpContextServer(raddress,
> - rport,
> - timeout,
> - self.root,
> - self.dyn_file_func,
> - self.upload_open)
> - self.sessions[key].start(buffer)
> - except TftpException as err:
> - deletion_list.append(key)
> - log.error("Fatal exception thrown from "
> - "session %s: %s" % (key, str(err)))
> - except KeyboardInterrupt:
> - pass
> - except:
> - else:
> - log.warning("received traffic on main socket for "
> - "existing session??")
> - log.info("Currently handling these sessions:")
> - for session_key, session in list(self.sessions.items()):
> - log.info(" %s" % session)
> - else:
> - # Must find the owner of this traffic.
> - if readysock == self.sessions[key].sock:
> - log.debug("Matched input to session key %s"
> - % key)
> - try:
> - self.sessions[key].cycle()
> - if self.sessions[key].state == None:
> - log.info("Successful transfer.")
> - "session %s: %s"
> - % (key, str(err)))
> - # Break out of for loop since we found the correct
> - # session.
> - break
> - else:
> - log.error("Can't find the owner for this packet. "
> - "Discarding.")
> - log.debug("Looping on all sessions to check for timeouts")
> - now = time.time()
> - try:
> - self.sessions[key].checkTimeout(now)
> - self.sessions[key].retry_count += 1
> - if self.sessions[key].retry_count >= TIMEOUT_RETRIES:
> - log.debug("hit max retries on %s, giving up" %
> - self.sessions[key])
> - else:
> - log.debug("resending on session %s" % self.sessions[key])
> - self.sessions[key].state.resendLast()
> - log.debug("Iterating deletion list.")
> - for key in deletion_list:
> - log.info('')
> - log.info("Session %s complete" % key)
> - if key in self.sessions:
> - log.debug("Gathering up metrics from session before deleting")
> - metrics = self.sessions[key].metrics
> - else:
> - log.info("Transferred %d bytes in %.2f seconds"
> - % (metrics.bytes, metrics.duration))
> - log.info("%d duplicate packets" % metrics.dupcount)
> - log.debug("Deleting session %s" % key)
> - del self.sessions[key]
> - log.debug("Session list is now %s" % self.sessions)
> - else:
> - log.warning(
> - "Strange, session %s is not on the deletion list" % key)
> - self.is_running.clear()
> - log.debug("server returning from while loop")
> - self.shutdown_gracefully = self.shutdown_immediately = False
> - def stop(self, now=False):
> - """Stop the server gracefully. Do not take any new transfers,
> - but complete the existing ones. If force is True, drop everything
> - and stop. Note, immediately will not interrupt the select loop, it
> - will happen when the server returns on ready data, or a timeout.
> - ie. SOCK_TIMEOUT"""
> - if now:
> - self.shutdown_immediately = True
> - else:
> - self.shutdown_gracefully = True
> diff --git a/tester/rt/tftpy/TftpShared.py b/tester/rt/tftpy/TftpShared.py
> index 88530c3..0000000
> --- a/tester/rt/tftpy/TftpShared.py
> +++ /dev/null
> @@ -1,52 +0,0 @@
> -"""This module holds all objects shared by all other modules in tftpy."""
> -MIN_BLKSIZE = 8
> -DEF_BLKSIZE = 512
> -MAX_BLKSIZE = 65536
> -SOCK_TIMEOUT = 5
> -MAX_DUPS = 20
> -TIMEOUT_RETRIES = 5
> -DEF_TFTP_PORT = 69
> -# A hook for deliberately introducing delay in testing.
> -DELAY_BLOCK = 0
> -def tftpassert(condition, msg):
> - """This function is a simple utility that will check the condition
> - passed for a false state. If it finds one, it throws a TftpException
> - with the message passed. This just makes the code throughout cleaner
> - by refactoring."""
> - if not condition:
> - raise TftpException(msg)
> -class TftpErrors(object):
> - """This class is a convenience for defining the common tftp error codes,
> - and making them more readable in the code."""
> - NotDefined = 0
> - FileNotFound = 1
> - AccessViolation = 2
> - DiskFull = 3
> - IllegalTftpOp = 4
> - UnknownTID = 5
> - FileAlreadyExists = 6
> - NoSuchUser = 7
> - FailedNegotiation = 8
> -class TftpException(Exception):
> - """This class is the parent class of all exceptions regarding the handling
> - of the TFTP protocol."""
> - pass
> -class TftpTimeout(TftpException):
> - """This class represents a timeout error waiting for a response from the
> - other end."""
> - pass
> -class TftpFileNotFoundError(TftpException):
> - """This class represents an error condition where we received a file
> - not found error."""
> - pass
> diff --git a/tester/rt/tftpy/TftpStates.py b/tester/rt/tftpy/TftpStates.py
> index 42bac1d..0000000
> --- a/tester/rt/tftpy/TftpStates.py
> +++ /dev/null
> @@ -1,611 +0,0 @@
> -"""This module implements all state handling during uploads and downloads, the
> -main interface to which being the TftpState base class.
> -import os
> -import logging
> -log = logging.getLogger('tftpy.TftpStates')
> -# State classes
> -class TftpState(object):
> - """The base class for the states."""
> - def __init__(self, context):
> - """Constructor for setting up common instance variables. The involved
> - file object is required, since in tftp there's always a file
> - involved."""
> - self.context = context
> - def handle(self, pkt, raddress, rport):
> - """An abstract method for handling a packet. It is expected to return
> - a TftpState object, either itself or a new state."""
> - def handleOACK(self, pkt):
> - """This method handles an OACK from the server, syncing any accepted
> - options."""
> - if len(pkt.options.keys()) > 0:
> - if pkt.match_options(self.context.options):
> - log.info("Successful negotiation of options")
> - # Set options to OACK options
> - self.context.options = pkt.options
> - for key in self.context.options:
> - log.info(" %s = %s" % (key, self.context.options[key]))
> - else:
> - log.error("Failed to negotiate options")
> - raise TftpException("Failed to negotiate options")
> - else:
> - raise TftpException("No options found in OACK")
> - def returnSupportedOptions(self, options):
> - """This method takes a requested options list from a client, and
> - returns the ones that are supported."""
> - # We support the options blksize and tsize right now.
> - # FIXME - put this somewhere else?
> - accepted_options = {}
> - for option in options:
> - if option == 'blksize':
> - # Make sure it's valid.
> - if int(options[option]) > MAX_BLKSIZE:
> - log.info("Client requested blksize greater than %d "
> - "setting to maximum" % MAX_BLKSIZE)
> - accepted_options[option] = MAX_BLKSIZE
> - elif int(options[option]) < MIN_BLKSIZE:
> - log.info("Client requested blksize less than %d "
> - "setting to minimum" % MIN_BLKSIZE)
> - accepted_options[option] = MIN_BLKSIZE
> - else:
> - accepted_options[option] = options[option]
> - elif option == 'tsize':
> - log.debug("tsize option is set")
> - accepted_options['tsize'] = 0
> - else:
> - log.info("Dropping unsupported option '%s'" % option)
> - log.debug("Returning these accepted options: %s", accepted_options)
> - return accepted_options
> - def sendDAT(self):
> - """This method sends the next DAT packet based on the data in the
> - context. It returns a boolean indicating whether the transfer is
> - finished."""
> - finished = False
> - blocknumber = self.context.next_block
> - # Test hook
> - if DELAY_BLOCK and DELAY_BLOCK == blocknumber:
> - import time
> - log.debug("Deliberately delaying 10 seconds...")
> - time.sleep(10)
> - dat = None
> - blksize = self.context.getBlocksize()
> - buffer = self.context.fileobj.read(blksize)
> - log.debug("Read %d bytes into buffer", len(buffer))
> - if len(buffer) < blksize:
> - log.info("Reached EOF on file %s"
> - % self.context.file_to_transfer)
> - finished = True
> - dat = TftpPacketDAT()
> - dat.data = buffer
> - dat.blocknumber = blocknumber
> - self.context.metrics.bytes += len(dat.data)
> - log.debug("Sending DAT packet %d", dat.blocknumber)
> - self.context.sock.sendto(dat.encode().buffer,
> - (self.context.host, self.context.tidport))
> - if self.context.packethook:
> - self.context.packethook(dat)
> - self.context.last_pkt = dat
> - return finished
> - def sendACK(self, blocknumber=None):
> - """This method sends an ack packet to the block number specified. If
> - none is specified, it defaults to the next_block property in the
> - parent context."""
> - log.debug("In sendACK, passed blocknumber is %s", blocknumber)
> - if blocknumber is None:
> - log.info("Sending ack to block %d" % blocknumber)
> - ackpkt = TftpPacketACK()
> - ackpkt.blocknumber = blocknumber
> - self.context.sock.sendto(ackpkt.encode().buffer,
> - self.context.tidport))
> - self.context.last_pkt = ackpkt
> - def sendError(self, errorcode):
> - """This method uses the socket passed, and uses the errorcode to
> - compose and send an error packet."""
> - log.debug("In sendError, being asked to send error %d", errorcode)
> - errpkt = TftpPacketERR()
> - errpkt.errorcode = errorcode
> - if self.context.tidport == None:
> - log.debug("Error packet received outside session. Discarding")
> - else:
> - self.context.sock.sendto(errpkt.encode().buffer,
> - self.context.last_pkt = errpkt
> - def sendOACK(self):
> - """This method sends an OACK packet with the options from the current
> - context."""
> - log.debug("In sendOACK with options %s", self.context.options)
> - pkt = TftpPacketOACK()
> - pkt.options = self.context.options
> - self.context.sock.sendto(pkt.encode().buffer,
> - self.context.last_pkt = pkt
> - def resendLast(self):
> - "Resend the last sent packet due to a timeout."
> - log.warning("Resending packet %s on sessions %s"
> - % (self.context.last_pkt, self))
> - self.context.metrics.resent_bytes += len(self.context.last_pkt.buffer)
> - self.context.metrics.add_dup(self.context.last_pkt)
> - sendto_port = self.context.tidport
> - if not sendto_port:
> - # If the tidport wasn't set, then the remote end hasn't even
> - # started talking to us yet. That's not good. Maybe it's not
> - # there.
> - sendto_port = self.context.port
> - self.context.sock.sendto(self.context.last_pkt.encode().buffer,
> - (self.context.host, sendto_port))
> - self.context.packethook(self.context.last_pkt)
> - def handleDat(self, pkt):
> - """This method handles a DAT packet during a client download, or a
> - server upload."""
> - log.info("Handling DAT packet - block %d" % pkt.blocknumber)
> - log.debug("Expecting block %s", self.context.next_block)
> - if pkt.blocknumber == self.context.next_block:
> - log.debug("Good, received block %d in sequence", pkt.blocknumber)
> - self.sendACK()
> - self.context.next_block += 1
> - log.debug("Writing %d bytes to output file", len(pkt.data))
> - self.context.fileobj.write(pkt.data)
> - self.context.metrics.bytes += len(pkt.data)
> - # Check for end-of-file, any less than full data packet.
> - if len(pkt.data) < self.context.getBlocksize():
> - log.info("End of file detected")
> - return None
> - elif pkt.blocknumber < self.context.next_block:
> - if pkt.blocknumber == 0:
> - log.warning("There is no block zero!")
> - self.sendError(TftpErrors.IllegalTftpOp)
> - raise TftpException("There is no block zero!")
> - log.warning("Dropping duplicate block %d" % pkt.blocknumber)
> - self.context.metrics.add_dup(pkt)
> - log.debug("ACKing block %d again, just in case", pkt.blocknumber)
> - self.sendACK(pkt.blocknumber)
> - else:
> - # FIXME: should we be more tolerant and just discard instead?
> - msg = "Whoa! Received future block %d but expected %d" \
> - % (pkt.blocknumber, self.context.next_block)
> - log.error(msg)
> - # Default is to ack
> - return TftpStateExpectDAT(self.context)
> -class TftpServerState(TftpState):
> - """The base class for server states."""
> - TftpState.__init__(self, context)
> - # This variable is used to store the absolute path to the file being
> - # managed.
> - self.full_path = None
> - def serverInitial(self, pkt, raddress, rport):
> - """This method performs initial setup for a server context transfer,
> - put here to refactor code out of the TftpStateServerRecvRRQ and
> - TftpStateServerRecvWRQ classes, since their initial setup is
> - identical. The method returns a boolean, sendoack, to indicate whether
> - it is required to send an OACK to the client."""
> - options = pkt.options
> - sendoack = False
> - if not self.context.tidport:
> - self.context.tidport = rport
> - log.info("Setting tidport to %s" % rport)
> - log.debug("Setting default options, blksize")
> - self.context.options = { 'blksize': DEF_BLKSIZE }
> - if options:
> - log.debug("Options requested: %s", options)
> - supported_options = self.returnSupportedOptions(options)
> - self.context.options.update(supported_options)
> - sendoack = True
> - # FIXME - only octet mode is supported at this time.
> - if pkt.mode != 'octet':
> - #self.sendError(TftpErrors.IllegalTftpOp)
> - #raise TftpException("Only octet transfers are supported at this time.")
> - log.warning("Received non-octet mode request. I'll reply with binary data.")
> - # test host/port of client end
> - if self.context.host != raddress or self.context.port != rport:
> - self.sendError(TftpErrors.UnknownTID)
> - log.error("Expected traffic from %s:%s but received it "
> - "from %s:%s instead."
> - % (self.context.host,
> - self.context.port,
> - raddress,
> - rport))
> - # FIXME: increment an error count?
> - # Return same state, we're still waiting for valid traffic.
> - return self
> - log.debug("Requested filename is %s", pkt.filename)
> - # Build the filename on this server and ensure it is contained
> - # in the specified root directory.
> - # Filenames that begin with server root are accepted. It's
> - # assumed the client and server are tightly connected and this
> - # provides backwards compatibility.
> - # Filenames otherwise are relative to the server root. If they
> - # begin with a '/' strip it off as otherwise os.path.join will
> - # treat it as absolute (regardless of whether it is ntpath or
> - # posixpath module
> - if pkt.filename.startswith(self.context.root):
> - full_path = pkt.filename
> - else:
> - full_path = os.path.join(self.context.root, pkt.filename.lstrip('/'))
> - # Use abspath to eliminate any remaining relative elements
> - # (e.g. '..') and ensure that is still within the server's
> - # root directory
> - self.full_path = os.path.abspath(full_path)
> - log.debug("full_path is %s", full_path)
> - if self.full_path.startswith(self.context.root):
> - log.info("requested file is in the server root - good")
> - else:
> - log.warning("requested file is not within the server root - bad")
> - raise TftpException("bad file path")
> - self.context.file_to_transfer = pkt.filename
> - return sendoack
> -class TftpStateServerRecvRRQ(TftpServerState):
> - """This class represents the state of the TFTP server when it has just
> - received an RRQ packet."""
> - "Handle an initial RRQ packet as a server."
> - log.debug("In TftpStateServerRecvRRQ.handle")
> - sendoack = self.serverInitial(pkt, raddress, rport)
> - path = self.full_path
> - log.info("Opening file %s for reading" % path)
> - if os.path.exists(path):
> - # Note: Open in binary mode for win32 portability, since win32
> - # blows.
> - self.context.fileobj = open(path, "rb")
> - elif self.context.dyn_file_func:
> - log.debug("No such file %s but using dyn_file_func", path)
> - self.context.fileobj = \
> - self.context.dyn_file_func(self.context.file_to_transfer, raddress=raddress, rport=rport)
> - if self.context.fileobj is None:
> - log.debug("dyn_file_func returned 'None', treating as "
> - "FileNotFound")
> - self.sendError(TftpErrors.FileNotFound)
> - raise TftpException("File not found: %s" % path)
> - else:
> - log.warn("File not found: %s", path)
> - raise TftpException("File not found: {}".format(path))
> - # Options negotiation.
> - if sendoack and 'tsize' in self.context.options:
> - # getting the file size for the tsize option. As we handle
> - # file-like objects and not only real files, we use this seeking
> - # method instead of asking the OS
> - self.context.fileobj.seek(0, os.SEEK_END)
> - tsize = str(self.context.fileobj.tell())
> - self.context.fileobj.seek(0, 0)
> - self.context.options['tsize'] = tsize
> - if sendoack:
> - # Note, next_block is 0 here since that's the proper
> - # acknowledgement to an OACK.
> - # FIXME: perhaps we do need a TftpStateExpectOACK class...
> - self.sendOACK()
> - # Note, self.context.next_block is already 0.
> - else:
> - self.context.next_block = 1
> - log.debug("No requested options, starting send...")
> - self.context.pending_complete = self.sendDAT()
> - # Note, we expect an ack regardless of whether we sent a DAT or an
> - # OACK.
> - return TftpStateExpectACK(self.context)
> - # Note, we don't have to check any other states in this method, that's
> - # up to the caller.
> -class TftpStateServerRecvWRQ(TftpServerState):
> - received a WRQ packet."""
> - def make_subdirs(self):
> - """The purpose of this method is to, if necessary, create all of the
> - subdirectories leading up to the file to the written."""
> - # Pull off everything below the root.
> - subpath = self.full_path[len(self.context.root):]
> - log.debug("make_subdirs: subpath is %s", subpath)
> - # Split on directory separators, but drop the last one, as it should
> - # be the filename.
> - dirs = subpath.split(os.sep)[:-1]
> - log.debug("dirs is %s", dirs)
> - current = self.context.root
> - for dir in dirs:
> - if dir:
> - current = os.path.join(current, dir)
> - if os.path.isdir(current):
> - log.debug("%s is already an existing directory", current)
> - else:
> - os.mkdir(current, 0o700)
> - "Handle an initial WRQ packet as a server."
> - log.debug("In TftpStateServerRecvWRQ.handle")
> - if self.context.upload_open:
> - f = self.context.upload_open(path, self.context)
> - if f is None:
> - self.sendError(TftpErrors.AccessViolation)
> - raise TftpException("Dynamic path %s not permitted" % path)
> - else:
> - self.context.fileobj = f
> - else:
> - log.info("Opening file %s for writing" % path)
> - # FIXME: correct behavior?
> - log.warning("File %s exists already, overwriting..." % (
> - self.context.file_to_transfer))
> - # FIXME: I think we should upload to a temp file and not overwrite
> - # the existing file until the file is successfully uploaded.
> - self.make_subdirs()
> - self.context.fileobj = open(path, "wb")
> - if sendoack:
> - log.debug("Sending OACK to client")
> - self.sendOACK()
> - else:
> - log.debug("No requested options, expecting transfer to begin...")
> - self.sendACK()
> - # Whether we're sending an oack or not, we're expecting a DAT for
> - # block 1
> - # We may have sent an OACK, but we're expecting a DAT as the response
> - # to either the OACK or an ACK, so lets unconditionally use the
> - # TftpStateExpectDAT state.
> -class TftpStateServerStart(TftpState):
> - """The start state for the server. This is a transitory state since at
> - this point we don't know if we're handling an upload or a download. We
> - will commit to one of them once we interpret the initial packet."""
> - """Handle a packet we just received."""
> - log.debug("In TftpStateServerStart.handle")
> - if isinstance(pkt, TftpPacketRRQ):
> - log.debug("Handling an RRQ packet")
> - return TftpStateServerRecvRRQ(self.context).handle(pkt,
> - raddress,
> - rport)
> - elif isinstance(pkt, TftpPacketWRQ):
> - log.debug("Handling a WRQ packet")
> - return TftpStateServerRecvWRQ(self.context).handle(pkt,
> - raddress,
> - rport)
> - else:
> - raise TftpException("Invalid packet to begin up/download: %s" % pkt)
> -class TftpStateExpectACK(TftpState):
> - """This class represents the state of the transfer when a DAT was just
> - sent, and we are waiting for an ACK from the server. This class is the
> - same one used by the client during the upload, and the server during the
> - download."""
> - "Handle a packet, hopefully an ACK since we just sent a DAT."
> - if isinstance(pkt, TftpPacketACK):
> - log.debug("Received ACK for packet %d" % pkt.blocknumber)
> - # Is this an ack to the one we just sent?
> - if self.context.next_block == pkt.blocknumber:
> - if self.context.pending_complete:
> - log.info("Received ACK to final DAT, we're done.")
> - return None
> - else:
> - log.debug("Good ACK, sending next DAT")
> - log.debug("Incremented next_block to %d",
> - self.context.next_block)
> - log.warning("Received duplicate ACK for block %d"
> - % pkt.blocknumber)
> - else:
> - log.warning("Oooh, time warp. Received ACK to packet we "
> - "didn't send yet. Discarding.")
> - self.context.metrics.errors += 1
> - return self
> - elif isinstance(pkt, TftpPacketERR):
> - log.error("Received ERR packet from peer: %s" % str(pkt))
> - raise TftpException("Received ERR packet from peer: %s" % str(pkt))
> - else:
> - log.warning("Discarding unsupported packet: %s" % str(pkt))
> - return self
> -class TftpStateExpectDAT(TftpState):
> - """Just sent an ACK packet. Waiting for DAT."""
> - """Handle the packet in response to an ACK, which should be a DAT."""
> - if isinstance(pkt, TftpPacketDAT):
> - return self.handleDat(pkt)
> - # Every other packet type is a problem.
> - elif isinstance(pkt, TftpPacketACK):
> - # Umm, we ACK, you don't.
> - raise TftpException("Received ACK from peer when expecting DAT")
> - raise TftpException("Received WRQ from peer when expecting DAT")
> - raise TftpException("Received ERR from peer: " + str(pkt))
> - else:
> - raise TftpException("Received unknown packet type from peer: " + str(pkt))
> -class TftpStateSentWRQ(TftpState):
> - """Just sent an WRQ packet for an upload."""
> - log.debug("Set remote port for session to %s", rport)
> - # If we're going to successfully transfer the file, then we should see
> - # either an OACK for accepted options, or an ACK to ignore options.
> - if isinstance(pkt, TftpPacketOACK):
> - log.info("Received OACK from server")
> - try:
> - self.handleOACK(pkt)
> - except TftpException:
> - self.sendError(TftpErrors.FailedNegotiation)
> - raise
> - else:
> - log.debug("Sending first DAT packet")
> - log.debug("Changing state to TftpStateExpectACK")
> - log.info("Received ACK from server")
> - log.debug("Apparently the server ignored our options")
> - # The block number should be zero.
> - log.debug("Ack blocknumber is zero as expected")
> - else:
> - log.warning("Discarding ACK to block %s" % pkt.blocknumber)
> - log.debug("Still waiting for valid response from server")
> - return self
> - raise TftpException("Received ERR from server: %s" % pkt)
> - elif isinstance(pkt, TftpPacketRRQ):
> - raise TftpException("Received RRQ from server while in upload")
> - elif isinstance(pkt, TftpPacketDAT):
> - raise TftpException("Received DAT from server while in upload")
> - else:
> - raise TftpException("Received unknown packet type from server: %s" % pkt)
> - # By default, no state change.
> - return self
> -class TftpStateSentRRQ(TftpState):
> - """Just sent an RRQ packet."""
> - """Handle the packet in response to an RRQ to the server."""
> - log.info("Set remote port for session to %s" % rport)
> - # Now check the packet type and dispatch it properly.
> - try:
> - log.error("Failed to negotiate options: %s" % str(err))
> - raise
> - else:
> - log.debug("Sending ACK to OACK")
> - self.sendACK(blocknumber=0)
> - log.debug("Changing state to TftpStateExpectDAT")
> - # If there are any options set, then the server didn't honour any
> - # of them.
> - log.info("Received DAT from server")
> - if self.context.options:
> - log.info("Server ignored options, falling back to defaults")
> - # Umm, we ACK, the server doesn't.
> - raise TftpException("Received ACK from server while in download")
> - raise TftpException("Received WRQ from server while in download")
> - log.debug("Received ERR packet: %s", pkt)
> - if pkt.errorcode == TftpErrors.FileNotFound:
> - raise TftpFileNotFoundError("File not found")
> - else:
> - raise TftpException("Received ERR from server: {}".format(pkt))
> - else:
> - return self
> diff --git a/tester/rt/tftpy/__init__.py b/tester/rt/tftpy/__init__.py
> deleted file mode 100644
> index 71b8e3d..0000000
> --- a/tester/rt/tftpy/__init__.py
> +++ /dev/null
> @@ -1,27 +0,0 @@
> -This library implements the tftp protocol, based on rfc 1350.
> -http://www.faqs.org/rfcs/rfc1350.html
> -At the moment it implements only a client class, but will include a server,
> -with support for variable block sizes.
> -As a client of tftpy, this is the only module that you should need to import
> -directly. The TftpClient and TftpServer classes can be reached through it.
> -import sys
> -# Make sure that this is at least Python 2.7
> -required_version = (2, 7)
> -if sys.version_info < required_version:
> - raise ImportError("Requires at least Python 2.7")
> -from . import TftpPacketTypes
> -from . import TftpPacketFactory
> -from .TftpClient import TftpClient
> -from .TftpServer import TftpServer
> -from . import TftpContexts
> -from . import TftpStates
> diff --git a/tester/rtems-tftp-server b/tester/rtems-tftp-server
> new file mode 100755
> index 0000000..e03f183
> --- /dev/null
> +++ b/tester/rtems-tftp-server
> @@ -0,0 +1,46 @@
> +#! /usr/bin/env python
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2020 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +from __future__ import print_function
> +import sys, os
> +base = os.path.dirname(os.path.abspath(sys.argv[0]))
> +rtems = os.path.dirname(base)
> +sys.path = [rtems] + sys.path
> +try:
> + import rt.tftpserver
> + rt.tftpserver.run(sys.argv)
> +except ImportError:
> + print("Incorrect RTEMS Tools installation", file = sys.stderr)
> + sys.exit(1)
> 2.24.1
> devel mailing list
> devel at rtems.org
