[PATCH] tester: Change to a simpler TFTP server
Chris Johns
chrisj at rtems.org
Thu Aug 27 23:25:27 UTC 2020
On 28/8/20 1:44 am, Gedare Bloom wrote:
> On Wed, Aug 26, 2020 at 10:56 PM <chrisj at rtems.org> wrote:
>> From: Chris Johns <chrisj at rtems.org>
>> - Add a simpler TFTP to allow parallel test hardware
>> - Remove the imported tftpy server
>> Closes #4063
>> tester/rt/tftp.py | 37 +-
>> tester/rt/tftpserver.py | 619 +++++++++++++++++++++++++++
>> tester/rt/tftpy/COPYING | 21 -
>> tester/rt/tftpy/README | 115 -----
>> tester/rt/tftpy/TftpClient.py | 107 -----
>> tester/rt/tftpy/TftpContexts.py | 429 -------------------
>> tester/rt/tftpy/TftpPacketFactory.py | 47 --
>> tester/rt/tftpy/TftpPacketTypes.py | 494 ---------------------
>> tester/rt/tftpy/TftpServer.py | 271 ------------
>> tester/rt/tftpy/TftpShared.py | 52 ---
>> tester/rt/tftpy/TftpStates.py | 611 --------------------------
>> tester/rt/tftpy/__init__.py | 27 --
>> tester/rtems-tftp-server | 46 ++
>> 13 files changed, 685 insertions(+), 2191 deletions(-)
>> create mode 100644 tester/rt/tftpserver.py
>> delete mode 100644 tester/rt/tftpy/COPYING
>> delete mode 100644 tester/rt/tftpy/README
>> delete mode 100644 tester/rt/tftpy/TftpClient.py
>> delete mode 100644 tester/rt/tftpy/TftpContexts.py
>> delete mode 100644 tester/rt/tftpy/TftpPacketFactory.py
>> delete mode 100644 tester/rt/tftpy/TftpPacketTypes.py
>> delete mode 100644 tester/rt/tftpy/TftpServer.py
>> delete mode 100644 tester/rt/tftpy/TftpShared.py
>> delete mode 100644 tester/rt/tftpy/TftpStates.py
>> delete mode 100644 tester/rt/tftpy/__init__.py
>> create mode 100755 tester/rtems-tftp-server
>> diff --git a/tester/rt/tftp.py b/tester/rt/tftp.py
>> index d518036..46a1d11 100644
>> --- a/tester/rt/tftp.py
>> +++ b/tester/rt/tftp.py
>> @@ -43,7 +43,7 @@ import sys
>> from rtemstoolkit import error
>> from rtemstoolkit import reraise
>> -import tftpy
>> +import tftpserver
>> class tftp(object):
>> '''RTEMS Testing TFTP base.'''
>> @@ -88,7 +88,7 @@ class tftp(object):
>> def _stop(self):
>> try:
>> if self.server:
>> - self.server.stop(now = True)
>> + self.server.stop()
>> except:
>> pass
>> @@ -101,6 +101,10 @@ class tftp(object):
>> def _timeout(self):
>> self._stop()
>> + while self.running or not self.finished:
>> + self._unlock('_timeout')
>> + time.sleep(0.1)
>> + self._lock('_timeout')
>> if self.timeout is not None:
>> self.timeout()
>> @@ -119,22 +123,21 @@ class tftp(object):
>> return None
>> def _listener(self):
>> - tftpy_log = logging.getLogger('tftpy')
>> - tftpy_log.setLevel(100)
>> + self._lock('_listener')
>> + exe = self.exe
>> + self.exe = None
>> + self._unlock('_listener')
>> + self.server = tftpserver.tftp_server(host = 'all',
>> + port = self.port,
>> + timeout = 1,
>> + forced_file = exe,
>> + sessions = 1)
>> try:
>> - self.server = tftpy.TftpServer(tftproot = '.',
>> - dyn_file_func = self._exe_handle)
>> - except tftpy.TftpException as te:
>> - raise error.general('tftp: %s' % (str(te)))
>> - if self.server is not None:
>> - try:
>> - self.server.listen('0.0.0.0', self.port, 0.5)
>> - except IOError as ie:
>> - if ie.errno == errno.EACCES:
>> - raise error.general('tftp: permissions error: check tftp server port')
>> - raise error.general('tftp: io error: %s' % (str(ie)))
>> + self.server.start()
>> + self.server.run()
>> + except:
>> + raise
>> def _runner(self):
>> self._lock('_runner')
>> diff --git a/tester/rt/tftpserver.py b/tester/rt/tftpserver.py
>> new file mode 100644
>> index 0000000..b307bd2
>> --- /dev/null
>> +++ b/tester/rt/tftpserver.py
>> @@ -0,0 +1,619 @@
>> +# Copyright 2020 Chris Johns (chris at contemporary.software)
> Nice email.
Oh haha I had not noticed this was in the file.
>> +# All rights reserved.
>> +# Permission to use, copy, modify, and/or distribute this software for any
>> +# purpose with or without fee is hereby granted, provided that the above
>> +# copyright notice and this permission notice appear in all copies.
>> +# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
>> +# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
>> +# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
>> +# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
>> +# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
>> +# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
>> +# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
> Not the preferred file block:
> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#python-file-template
> But, we could add an MIT template.
I am fine with having all the code move to the documented template header. Like
the RSB the repo should be checked and moved over.
> I don't really have the context to check python code. Please do a pass
> over the guidelines to see if you think you got to them.
Do you mean section 6.5 in the engineering manual? I have reviewed the guide
lines and I have not passed the code through a formatter or static checker. I
would like to add to waf the ability to run the formatting and static checker
and to migrate all the code. I think it is important but I am not sure how big a
job it is. I would prefer to make the change sooner rather than later so any
stability issues that happen occur now rather than later in the release cycle.
Is the code OK to merge?
