[PATCH] Adding EPICS7 Package to RSB
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Aug 27 18:57:39 UTC 2020
Added commit message and removed Signed off
Please review.
Adding EPICS7 Package to RSB for Building it with RTEMS
rtems/config/epics/epics-7.0-1.cfg | 21 +++++++++
rtems/config/epics/epics-base.bset | 14 ++++++
source-builder/config/epics-7.0-1.cfg | 65 +++++++++++++++++++++++++++
3 files changed, 100 insertions(+)
create mode 100644 rtems/config/epics/epics-7.0-1.cfg
create mode 100644 rtems/config/epics/epics-base.bset
create mode 100644 source-builder/config/epics-7.0-1.cfg
diff --git a/rtems/config/epics/epics-7.0-1.cfg b/rtems/config/epics/epics-7.0-1.cfg
new file mode 100644
index 0000000..34270ee
--- /dev/null
+++ b/rtems/config/epics/epics-7.0-1.cfg
@@ -0,0 +1,21 @@
+# EPICS 7.0
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# EPICS Version
+%define epics_version 7.0
+%hash sha512 epics-base-%{epics_version}.tar.gz 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
+# EPICS Build configuration
+%include %{_configdir}/epics-7.0-1.cfg
diff --git a/rtems/config/epics/epics-base.bset b/rtems/config/epics/epics-base.bset
index 0000000..7ee3815
--- /dev/null
+++ b/rtems/config/epics/epics-base.bset
@@ -0,0 +1,14 @@
+# Build set for EPICS
+%define release 1
+# The RTEMS Package defines
+%include rtems-package.bset
+# Build EPICS.
+epics/epics-7.0-1
diff --git a/source-builder/config/epics-7.0-1.cfg b/source-builder/config/epics-7.0-1.cfg
index 0000000..df75e1d
--- /dev/null
+++ b/source-builder/config/epics-7.0-1.cfg
@@ -0,0 +1,65 @@
+# EPICS 7.x.x Version 1.
+# This configuration file configure's, make's and install's EPICS.
+%define release 1
+%endif
+Name: epics-base-%{epics_version}-%{_host}-%{release}
+Summary: EPICS v%{epics_version} for target %{_target} on host %{_host}
+Version: %{epics_version}
+Release: %{release}
+URL: https://epics-controls.org/
+# Source
+%source set epics-base https://gitlab.fhi.mpg.de/junkes/epics-base/-/archive/%{epics_version}/epics-base-%{epics_version}.tar.gz
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ source_dir_epics="epics-base-%{epics_version}"
+ %source setup epics-base -q -n source_dir_epics
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ cd source_dir_epics
+ %{build_build_flags}
+ # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION using
+ # --with-rtems-bsp
+ %{__make} RTEMS_BASE=%{_prefix} \
+ RTEMS_VERSION=%{rtems_version} \
+ CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
+ cd ${build_top}
+#%install
+ build_top=$(pwd)
+ %{__rmdir} $SB_BUILD_ROOT
+ %{__make} DESTDIR=$SB_BUILD_ROOT \
+ RTEMS_BASE=%{_prefix} \
+ CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp} install
+ cd ${build_top}
2.25.1
