[PATCH] Adding EPICS7 Package to RSB
Mritunjay Sharma mritunjaysharma394 at gmail.com
Thu Aug 27 21:51:34 UTC 2020
[UPDATE]: My humble apologies as that patch had a problem. I forgot to add
$ before the variable {source_dir_epics}
which was causing the build to fail. Please ignore the above patch.
I am sending the new tested patch again. Apologies for this inconvenience.
Thanks
Mritunjay Kumar Sharma
On Fri, Aug 28, 2020 at 12:30 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Added commit message and removed Signed off
> Please review.
> Adding EPICS7 Package to RSB for Building it with RTEMS
>  rtems/config/epics/epics-7.0-1.cfg    | 21 +++++++++
>  rtems/config/epics/epics-base.bset    | 14 ++++++
>  source-builder/config/epics-7.0-1.cfg | 65 +++++++++++++++++++++++++++
>  3 files changed, 100 insertions(+)
>  create mode 100644 rtems/config/epics/epics-7.0-1.cfg
>  create mode 100644 rtems/config/epics/epics-base.bset
>  create mode 100644 source-builder/config/epics-7.0-1.cfg
> diff --git a/rtems/config/epics/epics-7.0-1.cfg
> b/rtems/config/epics/epics-7.0-1.cfg
> new file mode 100644
> index 0000000..34270ee
> --- /dev/null
> +++ b/rtems/config/epics/epics-7.0-1.cfg
> @@ -0,0 +1,21 @@
> +# EPICS 7.0
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%include %{_configdir}/rtems-bsp.cfg
> +# EPICS Version
> +%define epics_version 7.0
> +%hash sha512 epics-base-%{epics_version}.tar.gz
> 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
> +# EPICS Build configuration
> +%include %{_configdir}/epics-7.0-1.cfg
> diff --git a/rtems/config/epics/epics-base.bset
> b/rtems/config/epics/epics-base.bset
> index 0000000..7ee3815
> --- /dev/null
> +++ b/rtems/config/epics/epics-base.bset
> @@ -0,0 +1,14 @@
> +# Build set for EPICS
> +%define release 1
> +# The RTEMS Package defines
> +%include rtems-package.bset
> +# Build EPICS.
> +epics/epics-7.0-1
> diff --git a/source-builder/config/epics-7.0-1.cfg
> b/source-builder/config/epics-7.0-1.cfg
> index 0000000..df75e1d
> --- /dev/null
> +++ b/source-builder/config/epics-7.0-1.cfg
> @@ -0,0 +1,65 @@
> +# EPICS 7.x.x Version 1.
> +# This configuration file configure's, make's and install's EPICS.
> +%define release 1
> +%endif
> +Name:      epics-base-%{epics_version}-%{_host}-%{release}
> +Summary:   EPICS v%{epics_version} for target %{_target} on host %{_host}
> +Version:   %{epics_version}
> +Release:   %{release}
> +URL:     https://epics-controls.org/
> +# Source
> +%source set epics-base
> https://gitlab.fhi.mpg.de/junkes/epics-base/-/archive/%{epics_version}/epics-base-%{epics_version}.tar.gz
> +# Prepare the source code.
> +%prep
> +  build_top=$(pwd)
> +  source_dir_epics="epics-base-%{epics_version}"
> +  %source setup epics-base -q -n source_dir_epics
> +  cd ${build_top}
> +%build
> +  build_top=$(pwd)
> +  cd source_dir_epics
> +  %{build_build_flags}
> +  # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION using
> +  # --with-rtems-bsp
> +  %{__make} RTEMS_BASE=%{_prefix} \
> +      RTEMS_VERSION=%{rtems_version} \
> +      CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
> +  cd ${build_top}
> +#%install
> +  build_top=$(pwd)
> +  %{__rmdir} $SB_BUILD_ROOT
> +  %{__make} DESTDIR=$SB_BUILD_ROOT \
> +      RTEMS_BASE=%{_prefix} \
> +      CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp} install
> +  cd ${build_top}
> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200828/119de84f/attachment-0001.html>
