[PATCH] Adding EPICS7 Package to RSB
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Aug 27 22:05:31 UTC 2020
I have sent the tested patch and it can be found here:
https://lists.rtems.org/pipermail/devel/2020-August/061655.html.
Please do review.
Thank you so much and apologies again for the mistake.
Mritunjay Sharma
On Fri, Aug 28, 2020 at 3:21 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> [UPDATE]: My humble apologies as that patch had a problem. I forgot to add
> $ before the variable {source_dir_epics}
> which was causing the build to fail. Please ignore the above patch.
> I am sending the new tested patch again. Apologies for this inconvenience.
> Thanks
> Mritunjay Kumar Sharma
> On Fri, Aug 28, 2020 at 12:30 AM Mritunjay Sharma <
>> Added commit message and removed Signed off
>> Please review.
>> Adding EPICS7 Package to RSB for Building it with RTEMS
>> rtems/config/epics/epics-7.0-1.cfg | 21 +++++++++
>> rtems/config/epics/epics-base.bset | 14 ++++++
>> source-builder/config/epics-7.0-1.cfg | 65 +++++++++++++++++++++++++++
>> 3 files changed, 100 insertions(+)
>> create mode 100644 rtems/config/epics/epics-7.0-1.cfg
>> create mode 100644 rtems/config/epics/epics-base.bset
>> create mode 100644 source-builder/config/epics-7.0-1.cfg
>> diff --git a/rtems/config/epics/epics-7.0-1.cfg
>> b/rtems/config/epics/epics-7.0-1.cfg
>> new file mode 100644
>> index 0000000..34270ee
>> --- /dev/null
>> +++ b/rtems/config/epics/epics-7.0-1.cfg
>> @@ -0,0 +1,21 @@
>> +# EPICS 7.0
>> +%if %{release} == %{nil}
>> + %define release 1
>> +%endif
>> +%include %{_configdir}/rtems-bsp.cfg
>> +# EPICS Version
>> +%define epics_version 7.0
>> +%hash sha512 epics-base-%{epics_version}.tar.gz
>> 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
>> +# EPICS Build configuration
>> +%include %{_configdir}/epics-7.0-1.cfg
>> diff --git a/rtems/config/epics/epics-base.bset
>> b/rtems/config/epics/epics-base.bset
>> index 0000000..7ee3815
>> --- /dev/null
>> +++ b/rtems/config/epics/epics-base.bset
>> @@ -0,0 +1,14 @@
>> +# Build set for EPICS
>> +%define release 1
>> +# The RTEMS Package defines
>> +%include rtems-package.bset
>> +# Build EPICS.
>> +epics/epics-7.0-1
>> diff --git a/source-builder/config/epics-7.0-1.cfg
>> b/source-builder/config/epics-7.0-1.cfg
>> index 0000000..df75e1d
>> --- /dev/null
>> +++ b/source-builder/config/epics-7.0-1.cfg
>> @@ -0,0 +1,65 @@
>> +# EPICS 7.x.x Version 1.
>> +# This configuration file configure's, make's and install's EPICS.
>> +%define release 1
>> +%endif
>> +Name: epics-base-%{epics_version}-%{_host}-%{release}
>> +Summary: EPICS v%{epics_version} for target %{_target} on host %{_host}
>> +Version: %{epics_version}
>> +Release: %{release}
>> +URL: https://epics-controls.org/
>> +# Source
>> +%source set epics-base
>> https://gitlab.fhi.mpg.de/junkes/epics-base/-/archive/%{epics_version}/epics-base-%{epics_version}.tar.gz
>> +# Prepare the source code.
>> +%prep
>> + build_top=$(pwd)
>> + source_dir_epics="epics-base-%{epics_version}"
>> + %source setup epics-base -q -n source_dir_epics
>> + cd ${build_top}
>> +%build
>> + build_top=$(pwd)
>> + cd source_dir_epics
>> + %{build_build_flags}
>> + # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION
>> using
>> + # --with-rtems-bsp
>> + %{__make} RTEMS_BASE=%{_prefix} \
>> + RTEMS_VERSION=%{rtems_version} \
>> + CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
>> + cd ${build_top}
>> +#%install
>> + build_top=$(pwd)
>> + %{__rmdir} $SB_BUILD_ROOT
>> + %{__make} DESTDIR=$SB_BUILD_ROOT \
>> + RTEMS_BASE=%{_prefix} \
>> + CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp} install
>> + cd ${build_top}
>> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200828/3535a200/attachment.html>
