Introducing the Strong APA Scheduler
Richi Dubey richidubey at gmail.com
Fri Aug 28 14:12:33 UTC 2020
Hi,
I am happy to announce the release of the final version of the Strong APA
scheduler.
The documentation for the scheduler is live at
https://richidubey.github.io/Strong-APA-Documentation/html/
Improvements over the Pre-Release version
<https://lists.rtems.org/pipermail/devel/2020-August/061560.html>:
 - Implemented changes for the reviews received on the 3 patches
 - Does not manipulate/access the variables of the Per CPU Control of any
CPU
The changes from the last patch of pre-release version can be seen here: Github
Link
<https://github.com/richidubey/rtems/pull/7/commits/e542a76befcb0c2a3f638c395eb6404932c00447>
The changes from the current RTEMS state can be seen here: Github Link
<https://github.com/richidubey/rtems/pull/8/files>
Patch for the scheduler: Devel lists link
<https://lists.rtems.org/pipermail/devel/2020-August/061661.html>
The scheduler has only been tested on 1 test
<https://lists.rtems.org/pipermail/devel/2020-August/061474.html> so far
and I plan on adding more tests and testing this version on them in the
next few days.
Please let me know about your views and also if you think anything's still
wrong in the code.
Thanks,
Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200828/9f930f88/attachment.html>
