GSoC 2020: Final Report (Beagle BSP: Add FDT based initialization)
Christian Mauderer oss at c-mauderer.de
Sat Aug 29 09:24:33 UTC 2020
Hello Niteesh
On 29/08/2020 11:22, Niteesh G. S. wrote:
> On Sat, Aug 29, 2020 at 1:02 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     On 29/08/2020 05:57, Niteesh G. S. wrote:
>     > On Sat, Aug 29, 2020 at 4:19 AM Gedare Bloom <gedare at rtems.org
>     <mailto:gedare at rtems.org>
>     > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
>     >     Are "Links to commits" 1-4 all the code you (are claiming you)
>     wrote?
>     >     I just want to make sure. It looks fine to me.
>     > Yes, all the code in the commits is written by me.
>     I think maybe "Links to branches" would be a better title. It is not a
>     single commit each but a few commits. Alternative would be to add links
>     to each commit.
> I have changed the title to "Links to branches". Should I also add links
> to the commits that were made in each phase at the end of the summary of
> each phase?
If you want, you can do that.
The main point of that change was to highlight that it's not 4 commits
but a bit more.
>     It has been quite a bit of back and forth during this GSoC project so I
>     think the result is quite OK.
>     Best regards
>     Christian
>     >     On Fri, Aug 28, 2020 at 12:07 PM Niteesh G. S.
>     <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>
>     >     <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>>
>     wrote:
>     >     > Hello,
>     >     > I have prepared my final report for my project. You can have a
>     >     look at it
>     >     > here https://gs-niteesh.github.io/finalreport/. Please kindly
>     >     review the report.
>     >     > Thanks,
>     >     > Niteesh.
>     > _______________________________________________
>     > devel mailing list
>     > devel at rtems.org <mailto:devel at rtems.org>
>     > http://lists.rtems.org/mailman/listinfo/devel
