GSoC 2020: Final Report (Beagle BSP: Add FDT based initialization)
Niteesh G. S.
niteesh.gs at gmail.com
Sat Aug 29 13:04:12 UTC 2020
Hello,
On Sat, Aug 29, 2020 at 2:54 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello Niteesh
> On 29/08/2020 11:22, Niteesh G. S. wrote:
> > On Sat, Aug 29, 2020 at 1:02 PM Christian Mauderer <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> > On 29/08/2020 05:57, Niteesh G. S. wrote:
> > > On Sat, Aug 29, 2020 at 4:19 AM Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>
> > > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>> wrote:
> > > Are "Links to commits" 1-4 all the code you (are claiming you)
> > wrote?
> > > I just want to make sure. It looks fine to me.
> > > Yes, all the code in the commits is written by me.
> > I think maybe "Links to branches" would be a better title. It is not
> a
> > single commit each but a few commits. Alternative would be to add
> links
> > to each commit.
> > I have changed the title to "Links to branches". Should I also add links
> > to the commits that were made in each phase at the end of the summary of
> > each phase?
> If you want, you can do that.
I did try that but it didn't work out well, especially with the OFW commit.
Since I don't have the old commit I either had to leave that commit out
in the first phase or I had to post the newer commit in the first phase
itself which actually should in the last phase. So I decided to avoid adding
the commits and just leave it out with the branches.
The main point of that change was to highlight that it's not 4 commits
> but a bit more.
> > It has been quite a bit of back and forth during this GSoC project
> so I
> > think the result is quite OK.
> > Best regards
> > Christian
> > > On Fri, Aug 28, 2020 at 12:07 PM Niteesh G. S.
> > <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>
> > > <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>>
> > wrote:
> > > > Hello,
> > > > I have prepared my final report for my project. You can have
> a
> > > look at it
> > > > here https://gs-niteesh.github.io/finalreport/. Please
> kindly
> > > review the report.
> > > > Thanks,
> > > > Niteesh.
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org <mailto:devel at rtems.org>
> > > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200829/5ae96cbb/attachment.html>
