[PATCH] Add Strong APA 2nd test
Richi Dubey
richidubey at gmail.com
Sat Aug 29 09:58:05 UTC 2020
Hi,
The Strong APA scheduler (
https://lists.rtems.org/pipermail/devel/2020-August/061662.html) passes
this test as well. This test is again based on the example from page 6 of
the paper <https://people.mpi-sws.org/~bbb/papers/pdf/rtss14f.pdf>. This
test does not exactly work like the example in the paper does, but I need
your help in figuring out how to make tasks that have a WCET (i.e. that
they die out in some time, using a timer) to make something like that.
Thanks,
Richi.
On Sat, Aug 29, 2020 at 3:23 PM Richi Dubey <richidubey at gmail.com> wrote:
> testsuites/smptests/smpstrongapa01/init.c | 72 ++++++++++++++---------
> 1 file changed, 43 insertions(+), 29 deletions(-)
> diff --git a/testsuites/smptests/smpstrongapa01/init.c
> b/testsuites/smptests/smpstrongapa01/init.c
> index bf8bc05231..0daa768b48 100644
> --- a/testsuites/smptests/smpstrongapa01/init.c
> +++ b/testsuites/smptests/smpstrongapa01/init.c
> @@ -1,4 +1,5 @@
> + * Copyright (c) 2020 Richi Dubey ( richidubey at gmail.com )
> * Copyright (c) 2016, 2017 embedded brains GmbH. All rights reserved.
> * embedded brains GmbH
> @@ -16,23 +17,28 @@
> #include "config.h"
> #endif
> -#include "tmacros.h"
> +#include <tmacros.h>
> #include <rtems.h>
> const char rtems_test_name[] = "SMPSTRONGAPA 1";
> -#define CPU_COUNT 4
> +#define CPU_COUNT 2
> -#define TASK_COUNT (3 * CPU_COUNT)
> +#define TASK_COUNT 3
> #define P(i) (UINT32_C(2) + i)
> #define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
> -#define IDLE UINT8_C(255)
> +#define A(cpu0, cpu1) ( (cpu1 << 1) | cpu0 )
> -#define NAME rtems_build_name('S', 'A', 'P', 'A')
> +typedef enum {
> + T0,
> + T1,
> + T2,
> + IDLE
> +} task_index;
> typedef struct {
> enum {
> @@ -43,7 +49,7 @@ typedef struct {
> KIND_UNBLOCK
> } kind;
> - size_t index;
> + task_index index;
> struct {
> rtems_task_priority priority;
> @@ -65,54 +71,59 @@ typedef struct {
> KIND_RESET, \
> 0, \
> { 0 }, \
> - { IDLE, IDLE, IDLE, IDLE } \
> + { IDLE, IDLE} \
> -#define SET_PRIORITY(index, prio, cpu0, cpu1, cpu2, cpu3) \
> +#define SET_PRIORITY(index, prio, cpu0, cpu1) \
> KIND_SET_PRIORITY, \
> index, \
> { .priority = prio }, \
> - { cpu0, cpu1, cpu2, cpu3 } \
> + { cpu0, cpu1} \
> -#define SET_AFFINITY(index, aff, cpu0, cpu1, cpu2, cpu3) \
> +#define SET_AFFINITY(index, aff, cpu0, cpu1) \
> KIND_SET_AFFINITY, \
> index, \
> { .cpu_set = aff }, \
> + { cpu0, cpu1 } \
> -#define BLOCK(index, cpu0, cpu1, cpu2, cpu3) \
> +#define BLOCK(index, cpu0, cpu1) \
> KIND_BLOCK, \
> index, \
> { 0 }, \
> + { cpu0, cpu1 } \
> -#define UNBLOCK(index, cpu0, cpu1, cpu2, cpu3) \
> +#define UNBLOCK(index, cpu0, cpu1) \
> KIND_UNBLOCK, \
> index, \
> { 0 }, \
> + { cpu0, cpu1} \
> static const test_action test_actions[] = {
> RESET,
> - UNBLOCK( 0, 0, IDLE, IDLE, IDLE),
> - UNBLOCK( 1, 0, 1, IDLE, IDLE),
> - UNBLOCK( 2, 0, 1, 2, IDLE),
> - UNBLOCK( 3, 0, 1, 2, 3),
> - UNBLOCK( 5, 0, 1, 2, 3),
> - SET_PRIORITY( 3, P(4), 0, 1, 2, 3),
> - SET_PRIORITY( 5, P(3), 0, 1, 2, 5),
> - BLOCK( 5, 0, 1, 2, 3),
> - SET_AFFINITY( 5, ALL, 0, 1, 2, 3),
> - RESET,
> + UNBLOCK( T0, T0, IDLE),
> + UNBLOCK( T1, T0, T1),
> + UNBLOCK( T2, T0, T1),
> + SET_PRIORITY( T0, P(0), T0, T1),
> + * Introduce Task 2 intially with lowest priority to imitate late
> arrival
> + SET_PRIORITY( T2, P(4), T0, T1),
> + SET_PRIORITY( T1, P(3), T0, T1),
> + SET_AFFINITY( T0, ALL, T0, T1),
> + SET_AFFINITY( T1, A(0, 1), T0, T1),
> + SET_AFFINITY( T2, A(1, 0), T0, T1),
> + * Show that higher priority task gets dislodged from its processor
> + SET_PRIORITY( T2, P(2), T2, T0),
> RESET
> @@ -182,7 +193,7 @@ static void check_cpu_allocations(test_context *ctx,
> const test_action *action)
> size_t i;
> for (i = 0; i < CPU_COUNT; ++i) {
> - size_t e;
> + task_index e;
> const Per_CPU_Control *c;
> const Thread_Control *h;
> @@ -279,7 +290,7 @@ static void test(void)
> for (i = 0; i < TASK_COUNT; ++i) {
> sc = rtems_task_create(
> - NAME,
> + rtems_build_name(' ', ' ', 'T', '0' + i),
> P(i),
> RTEMS_MINIMUM_STACK_SIZE,
> RTEMS_DEFAULT_MODES,
> @@ -292,7 +303,10 @@ static void test(void)
> rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> - sc = rtems_timer_create(NAME, &ctx->timer_id);
> + sc = rtems_timer_create(
> + rtems_build_name('A', 'C', 'T', 'N'),
> + &ctx->timer_id
> sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200829/b97652aa/attachment-0001.html>
