GSoC 2020: Final Report (Beagle BSP: Add FDT based initialization)
Christian Mauderer
oss at c-mauderer.de
Sun Aug 30 10:42:46 UTC 2020
Hello Niteesh,
On 30/08/2020 08:58, Niteesh G. S. wrote:
> Hello,
> I have updated the blog to contain the links to the commits
> instead of the branches. Please have a look again.
> https://gs-niteesh.github.io/finalreport/
>From my point of view, it looks good now. You missed the commit with the
refactored i2c driver:
https://github.com/gs-niteesh/rtems/commit/be9bd605c40cf7cbcf3f527054fdbab2af39f52a
But if you don't have time left it's not a problem if it isn't there.
The Submission guidelines tell that "It must be easy to identify the
work you have done." From my point of view that was already quite clear
because the commits are all on top of the final branch. But Gedare is of
course right: Linking every commit is a bit more clear.
> And sorry to disturb on the weekend, but we have only about
> a day left before the submission deadline, so I request
> everyone to please take a look and let me know if you would
> like to change anything.
No problem for disturbing in this case. Don't miss your deadline. It's
better to submit something that is not perfect than not submitting
anything. We would have no possibility to fix a missed submission.
Best regards
Christian
> Thanks,
> Niteesh.
> On Sun, Aug 30, 2020 at 2:24 AM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Sat, Aug 29, 2020 at 8:31 AM Christian Mauderer
> <oss at c-mauderer.de <mailto:oss at c-mauderer.de>> wrote:
> > On 29/08/2020 15:04, Niteesh G. S. wrote:
> > > Hello,
> > > On Sat, Aug 29, 2020 at 2:54 PM Christian Mauderer
> > > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>> wrote:
> > > Hello Niteesh
> > > On 29/08/2020 11:22, Niteesh G. S. wrote:
> > > > On Sat, Aug 29, 2020 at 1:02 PM Christian Mauderer
> <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>>> wrote:
> > > > On 29/08/2020 05:57, Niteesh G. S. wrote:
> > > > > On Sat, Aug 29, 2020 at 4:19 AM Gedare Bloom
> > > <gedare at rtems.org <mailto:gedare at rtems.org>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>
> <mailto:gedare at rtems.org <mailto:gedare at rtems.org>>>>> wrote:
> > > > > Are "Links to commits" 1-4 all the code you (are
> > > claiming you)
> > > > wrote?
> > > > > I just want to make sure. It looks fine to me.
> > > > > Yes, all the code in the commits is written by me.
> > > > I think maybe "Links to branches" would be a better
> title. It
> > > is not a
> > > > single commit each but a few commits. Alternative
> would be to
> > > add links
> > > > to each commit.
> > > > I have changed the title to "Links to branches". Should I
> also add
> > > links
> > > > to the commits that were made in each phase at the end of the
> > > summary of
> > > > each phase?
> > > If you want, you can do that.
> > > I did try that but it didn't work out well, especially with the
> OFW commit.
> > > Since I don't have the old commit I either had to leave that
> commit out
> > > in the first phase or I had to post the newer commit in the
> first phase
> > > itself which actually should in the last phase. So I decided to
> avoid adding
> > > the commits and just leave it out with the branches.
> > That's OK too. Like I said: Main target was that it's clear that you
> > don't have four commits but a bit more.
> Oh, I'm sorry I didn't notice this. We actually do want it to be
> distinctly your commits. Since you have commits that are older than
> this GSoC in rtems, you can't use the author filtering feature
> (https://github.com/gs-niteesh/rtems/commits/beagle-rtems6-pinmux-18-aug?author=gs-niteesh)
> so you'll probably need to generate the links to each commit.
> This is something required by Google.
> > > The main point of that change was to highlight that it's not
> 4 commits
> > > but a bit more.
> > > > It has been quite a bit of back and forth during this GSoC
> > > project so I
> > > > think the result is quite OK.
> > > > Best regards
> > > > Christian
> > > > > On Fri, Aug 28, 2020 at 12:07 PM Niteesh G. S.
> > > > <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>
> <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>
> <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>>
> > > <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>>>>
> > > > wrote:
> > > > > > Hello,
> > > > > > I have prepared my final report for my
> project. You
> > > can have a
> > > > > look at it
> > > > > > here
> https://gs-niteesh.github.io/finalreport/. Please
> > > kindly
> > > > > review the report.
> > > > > > Thanks,
> > > > > > Niteesh.
> > > > > _______________________________________________
> > > > > devel mailing list
> > > > > devel at rtems.org <mailto:devel at rtems.org>
> <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
> > > > > http://lists.rtems.org/mailman/listinfo/devel
