[PATCH 00/16] c-user: Split up chapter files
Sun Aug 30 16:15:03 UTC 2020
On Sun, Aug 30, 2020, 11:02 AM Joel Sherrill <joel.sherrill at gmail.com>
wrote:
> On Sun, Aug 30, 2020, 10:22 AM Gedare Bloom <gedare at rtems.org> wrote:
>> this is fairly mechanical. My only question is whether it is better to
>> keep the longer names for the directory. like... timer_manager/
>> instead of timer/  or to avoid abbreviations like rate_monotonic/
>> instead of ratemon/
> Longer names and subdirectories please. It has worked in the Users Guide.
> We are long past 8.3 and 13 character name limits. Just avoid spaces and
> special characters in names and stick to all lower case.
>> There are two decisions here: whether or not to say manager in a
>> directory, and whether or not to abbreviate the subdirectory. There's
>> not really a right answer, and it doesn't matter greatly, so you can
>> just push it how it is if you prefer.
>> -Gedare
>> On Thu, Aug 20, 2020 at 4:19 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > This patch set is a preparation to automatically generate parts of the
>> > documentation (introduction.rst and directives.rst) in the future from
>> > specification items.
>> > Sebastian Huber (16):
>> >   c-user: Split up semaphore manager
>> >   c-user: Split up event manager
>> >   c-user: Split up barrier manager
>> >   c-user: Split up clock manager
>> >   c-user: Split up dual-ported memory manager
>> >   c-user: Split up interrupt manager
>> >   c-user: Split up IO manager
>> >   c-user: Split up message manager
>> >   c-user: Split up partition manager
>> >   c-user: Split up rate-monotonic manager
>> >   c-user: Split up region manager
>> >   c-user: Split up signal manager
>> >   c-user: Split up task manager
>> >   c-user: Split up timer manager
>> >   c-user: Split up user extensions manager
>> >   c-user: Split up scheduling concepts
>> >  c-user/barrier/background.rst                 |   68 +
>> >  .../directives.rst}                           |  169 +--
>> >  c-user/barrier/index.rst                      |   14 +
>> >  c-user/barrier/introduction.rst               |   20 +
>> >  c-user/barrier/operations.rst                 |   60 +
>> >  c-user/clock/background.rst                   |   96 ++
>> >  .../directives.rst}                           |  238 +---
>> >  c-user/clock/index.rst                        |   15 +
>> >  c-user/clock/introduction.rst                 |   36 +
>> >  c-user/clock/operations.rst                   |   78 ++
>> >  c-user/dpmem/background.rst                   |   23 +
>> >  .../directives.rst}                           |   84 --
>> >  c-user/dpmem/index.rst                        |   16 +
>> >  c-user/dpmem/introduction.rst                 |   20 +
>> >  c-user/dpmem/operations.rst                   |   44 +
>> >  c-user/event/background.rst                   |   96 ++
>> >  c-user/event/directives.rst                   |  142 +++
>> >  c-user/event/index.rst                        |   15 +
>> >  c-user/event/introduction.rst                 |   13 +
>> >  c-user/event/operations.rst                   |   63 +
>> >  c-user/event_manager.rst                      |  309 -----
>> >  c-user/index.rst                              |   32 +-
>> >  c-user/intr/background.rst                    |  106 ++
>> >  .../directives.rst}                           |  251 ----
>> >  c-user/intr/index.rst                         |   15 +
>> >  c-user/intr/introduction.rst                  |   37 +
>> >  c-user/intr/operations.rst                    |  112 ++
>> >  c-user/io/background.rst                      |  162 +++
>> >  c-user/{io_manager.rst => io/directives.rst}  |  215 ----
>> >  c-user/io/index.rst                           |   16 +
>> >  c-user/io/introduction.rst                    |   30 +
>> >  c-user/io/operations.rst                      |   26 +
>> >  c-user/message/background.rst                 |   91 ++
>> >  .../directives.rst}                           |  205 ----
>> >  c-user/message/index.rst                      |   16 +
>> >  c-user/message/introduction.rst               |   28 +
>> >  c-user/message/operations.rst                 |   89 ++
>> >  c-user/part/background.rst                    |   50 +
>> >  .../directives.rst}                           |  120 --
>> >  c-user/part/index.rst                         |   15 +
>> >  c-user/part/introduction.rst                  |   19 +
>> >  c-user/part/operations.rst                    |   55 +
>> >  c-user/rate_monotonic_manager.rst             | 1091 -----------------
>> >  c-user/ratemon/background.rst                 |  390 ++++++
>> >  c-user/ratemon/directives.rst                 |  474 +++++++
>> >  c-user/ratemon/index.rst                      |   16 +
>> >  c-user/ratemon/introduction.rst               |   33 +
>> >  c-user/ratemon/operations.rst                 |  200 +++
>> >  c-user/region/background.rst                  |   87 ++
>> >  .../directives.rst}                           |  213 ----
>> >  c-user/region/index.rst                       |   15 +
>> >  c-user/region/introduction.rst                |   29 +
>> >  c-user/region/operations.rst                  |  101 ++
>> >  c-user/sched/background.rst                   |  327 +++++
>> >  c-user/sched/directives.rst                   |  424 +++++++
>> >  c-user/sched/index.rst                        |   19 +
>> >  c-user/sched/introduction.rst                 |   42 +
>> >  c-user/sched/smp-schedulers.rst               |   69 ++
>> >  c-user/sched/uniprocessor-schedulers.rst      |  113 ++
>> >  c-user/scheduling_concepts.rst                |  968 ---------------
>> >  c-user/sem/background.rst                     |  180 +++
>> >  .../directives.rst}                           |  309 -----
>> >  c-user/sem/index.rst                          |   18 +
>> >  c-user/sem/introduction.rst                   |   25 +
>> >  c-user/sem/operations.rst                     |  105 ++
>> >  c-user/signal/background.rst                  |  112 ++
>> >  c-user/signal/directives.rst                  |  126 ++
>> >  c-user/signal/index.rst                       |   15 +
>> >  c-user/signal/introduction.rst                |   13 +
>> >  c-user/signal/operations.rst                  |   75 ++
>> >  c-user/signal_manager.rst                     |  322 -----
>> >  c-user/tasks/background.rst                   |  390 ++++++
>> >  .../directives.rst}                           |  625 ----------
>> >  c-user/tasks/index.rst                        |   15 +
>> >  c-user/tasks/introduction.rst                 |   50 +
>> >  c-user/tasks/operations.rst                   |  192 +++
>> >  c-user/timer/background.rst                   |   71 ++
>> >  .../directives.rst}                           |  180 ---
>> >  c-user/timer/index.rst                        |   15 +
>> >  c-user/timer/introduction.rst                 |   29 +
>> >  c-user/timer/operations.rst                   |   84 ++
>> >  .../background.rst}                           |  161 ---
>> >  c-user/userext/directives.rst                 |  143 +++
>> >  c-user/userext/index.rst                      |   16 +
>> >  c-user/userext/introduction.rst               |   17 +
>> >  85 files changed, 5759 insertions(+), 5449 deletions(-)
>> >  create mode 100644 c-user/barrier/background.rst
>> >  rename c-user/{barrier_manager.rst => barrier/directives.rst} (55%)
>> >  create mode 100644 c-user/barrier/index.rst
>> >  create mode 100644 c-user/barrier/introduction.rst
>> >  create mode 100644 c-user/barrier/operations.rst
>> >  create mode 100644 c-user/clock/background.rst
>> >  rename c-user/{clock_manager.rst => clock/directives.rst} (65%)
>> >  create mode 100644 c-user/clock/index.rst
>> >  create mode 100644 c-user/clock/introduction.rst
>> >  create mode 100644 c-user/clock/operations.rst
>> >  create mode 100644 c-user/dpmem/background.rst
>> >  rename c-user/{dual_ports_memory_manager.rst => dpmem/directives.rst}
>> (64%)
>> >  create mode 100644 c-user/dpmem/index.rst
>> >  create mode 100644 c-user/dpmem/introduction.rst
>> >  create mode 100644 c-user/dpmem/operations.rst
>> >  create mode 100644 c-user/event/background.rst
>> >  create mode 100644 c-user/event/directives.rst
>> >  create mode 100644 c-user/event/index.rst
>> >  create mode 100644 c-user/event/introduction.rst
>> >  create mode 100644 c-user/event/operations.rst
>> >  delete mode 100644 c-user/event_manager.rst
>> >  create mode 100644 c-user/intr/background.rst
>> >  rename c-user/{interrupt_manager.rst => intr/directives.rst} (61%)
>> >  create mode 100644 c-user/intr/index.rst
>> >  create mode 100644 c-user/intr/introduction.rst
>> >  create mode 100644 c-user/intr/operations.rst
>> >  create mode 100644 c-user/io/background.rst
>> >  rename c-user/{io_manager.rst => io/directives.rst} (61%)
>> >  create mode 100644 c-user/io/index.rst
>> >  create mode 100644 c-user/io/introduction.rst
>> >  create mode 100644 c-user/io/operations.rst
>> >  create mode 100644 c-user/message/background.rst
>> >  rename c-user/{message_manager.rst => message/directives.rst} (69%)
>> >  create mode 100644 c-user/message/index.rst
>> >  create mode 100644 c-user/message/introduction.rst
>> >  create mode 100644 c-user/message/operations.rst
>> >  create mode 100644 c-user/part/background.rst
>> >  rename c-user/{partition_manager.rst => part/directives.rst} (70%)
>> >  create mode 100644 c-user/part/index.rst
>> >  create mode 100644 c-user/part/introduction.rst
>> >  create mode 100644 c-user/part/operations.rst
>> >  delete mode 100644 c-user/rate_monotonic_manager.rst
>> >  create mode 100644 c-user/ratemon/background.rst
>> >  create mode 100644 c-user/ratemon/directives.rst
>> >  create mode 100644 c-user/ratemon/index.rst
>> >  create mode 100644 c-user/ratemon/introduction.rst
>> >  create mode 100644 c-user/ratemon/operations.rst
>> >  create mode 100644 c-user/region/background.rst
>> >  rename c-user/{region_manager.rst => region/directives.rst} (66%)
>> >  create mode 100644 c-user/region/index.rst
>> >  create mode 100644 c-user/region/introduction.rst
>> >  create mode 100644 c-user/region/operations.rst
>> >  create mode 100644 c-user/sched/background.rst
>> >  create mode 100644 c-user/sched/directives.rst
>> >  create mode 100644 c-user/sched/index.rst
>> >  create mode 100644 c-user/sched/introduction.rst
>> >  create mode 100644 c-user/sched/smp-schedulers.rst
>> >  create mode 100644 c-user/sched/uniprocessor-schedulers.rst
>> >  delete mode 100644 c-user/scheduling_concepts.rst
>> >  create mode 100644 c-user/sem/background.rst
>> >  rename c-user/{semaphore_manager.rst => sem/directives.rst} (64%)
>> >  create mode 100644 c-user/sem/index.rst
>> >  create mode 100644 c-user/sem/introduction.rst
>> >  create mode 100644 c-user/sem/operations.rst
>> >  create mode 100644 c-user/signal/background.rst
>> >  create mode 100644 c-user/signal/directives.rst
>> >  create mode 100644 c-user/signal/index.rst
>> >  create mode 100644 c-user/signal/introduction.rst
>> >  create mode 100644 c-user/signal/operations.rst
>> >  delete mode 100644 c-user/signal_manager.rst
>> >  create mode 100644 c-user/tasks/background.rst
>> >  rename c-user/{task_manager.rst => tasks/directives.rst} (63%)
>> >  create mode 100644 c-user/tasks/index.rst
>> >  create mode 100644 c-user/tasks/introduction.rst
>> >  create mode 100644 c-user/tasks/operations.rst
>> >  create mode 100644 c-user/timer/background.rst
>> >  rename c-user/{timer_manager.rst => timer/directives.rst} (64%)
>> >  create mode 100644 c-user/timer/index.rst
>> >  create mode 100644 c-user/timer/introduction.rst
>> >  create mode 100644 c-user/timer/operations.rst
>> >  rename c-user/{user_extensions.rst => userext/background.rst} (77%)
>> >  create mode 100644 c-user/userext/directives.rst
>> >  create mode 100644 c-user/userext/index.rst
>> >  create mode 100644 c-user/userext/introduction.rst
>> > 2.26.2
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200830/ded3768f/attachment-0001.html>
