[PATCH 00/16] c-user: Split up chapter files
Gedare Bloom
gedare at rtems.org
Sun Aug 30 16:41:04 UTC 2020
On Sun, Aug 30, 2020 at 10:15 AM Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Aug 30, 2020, 11:02 AM Joel Sherrill <joel.sherrill at gmail.com> wrote:
>> On Sun, Aug 30, 2020, 10:22 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> this is fairly mechanical. My only question is whether it is better to
>>> keep the longer names for the directory. like... timer_manager/
>>> instead of timer/ or to avoid abbreviations like rate_monotonic/
>>> instead of ratemon/
>> Longer names and subdirectories please. It has worked in the Users Guide.
>> We are long past 8.3 and 13 character name limits. Just avoid spaces and special characters in names and stick to all lower case.
Should we explicitly say _manager on each of them though? Or it is ok
to say timer/ clock/ rate_monotonic/ and so on?
>>> There are two decisions here: whether or not to say manager in a
>>> directory, and whether or not to abbreviate the subdirectory. There's
>>> not really a right answer, and it doesn't matter greatly, so you can
>>> just push it how it is if you prefer.
>>> -Gedare
>>> On Thu, Aug 20, 2020 at 4:19 AM Sebastian Huber
>>> <sebastian.huber at embedded-brains.de> wrote:
>>> > This patch set is a preparation to automatically generate parts of the
>>> > documentation (introduction.rst and directives.rst) in the future from
>>> > specification items.
>>> > Sebastian Huber (16):
>>> > c-user: Split up semaphore manager
>>> > c-user: Split up event manager
>>> > c-user: Split up barrier manager
>>> > c-user: Split up clock manager
>>> > c-user: Split up dual-ported memory manager
>>> > c-user: Split up interrupt manager
>>> > c-user: Split up IO manager
>>> > c-user: Split up message manager
>>> > c-user: Split up partition manager
>>> > c-user: Split up rate-monotonic manager
>>> > c-user: Split up region manager
>>> > c-user: Split up signal manager
>>> > c-user: Split up task manager
>>> > c-user: Split up timer manager
>>> > c-user: Split up user extensions manager
>>> > c-user: Split up scheduling concepts
>>> > c-user/barrier/background.rst | 68 +
>>> > .../directives.rst} | 169 +--
>>> > c-user/barrier/index.rst | 14 +
>>> > c-user/barrier/introduction.rst | 20 +
>>> > c-user/barrier/operations.rst | 60 +
>>> > c-user/clock/background.rst | 96 ++
>>> > .../directives.rst} | 238 +---
>>> > c-user/clock/index.rst | 15 +
>>> > c-user/clock/introduction.rst | 36 +
>>> > c-user/clock/operations.rst | 78 ++
>>> > c-user/dpmem/background.rst | 23 +
>>> > .../directives.rst} | 84 --
>>> > c-user/dpmem/index.rst | 16 +
>>> > c-user/dpmem/introduction.rst | 20 +
>>> > c-user/dpmem/operations.rst | 44 +
>>> > c-user/event/background.rst | 96 ++
>>> > c-user/event/directives.rst | 142 +++
>>> > c-user/event/index.rst | 15 +
>>> > c-user/event/introduction.rst | 13 +
>>> > c-user/event/operations.rst | 63 +
>>> > c-user/event_manager.rst | 309 -----
>>> > c-user/index.rst | 32 +-
>>> > c-user/intr/background.rst | 106 ++
>>> > .../directives.rst} | 251 ----
>>> > c-user/intr/index.rst | 15 +
>>> > c-user/intr/introduction.rst | 37 +
>>> > c-user/intr/operations.rst | 112 ++
>>> > c-user/io/background.rst | 162 +++
>>> > c-user/{io_manager.rst => io/directives.rst} | 215 ----
>>> > c-user/io/index.rst | 16 +
>>> > c-user/io/introduction.rst | 30 +
>>> > c-user/io/operations.rst | 26 +
>>> > c-user/message/background.rst | 91 ++
>>> > .../directives.rst} | 205 ----
>>> > c-user/message/index.rst | 16 +
>>> > c-user/message/introduction.rst | 28 +
>>> > c-user/message/operations.rst | 89 ++
>>> > c-user/part/background.rst | 50 +
>>> > .../directives.rst} | 120 --
>>> > c-user/part/index.rst | 15 +
>>> > c-user/part/introduction.rst | 19 +
>>> > c-user/part/operations.rst | 55 +
>>> > c-user/rate_monotonic_manager.rst | 1091 -----------------
>>> > c-user/ratemon/background.rst | 390 ++++++
>>> > c-user/ratemon/directives.rst | 474 +++++++
>>> > c-user/ratemon/index.rst | 16 +
>>> > c-user/ratemon/introduction.rst | 33 +
>>> > c-user/ratemon/operations.rst | 200 +++
>>> > c-user/region/background.rst | 87 ++
>>> > .../directives.rst} | 213 ----
>>> > c-user/region/index.rst | 15 +
>>> > c-user/region/introduction.rst | 29 +
>>> > c-user/region/operations.rst | 101 ++
>>> > c-user/sched/background.rst | 327 +++++
>>> > c-user/sched/directives.rst | 424 +++++++
>>> > c-user/sched/index.rst | 19 +
>>> > c-user/sched/introduction.rst | 42 +
>>> > c-user/sched/smp-schedulers.rst | 69 ++
>>> > c-user/sched/uniprocessor-schedulers.rst | 113 ++
>>> > c-user/scheduling_concepts.rst | 968 ---------------
>>> > c-user/sem/background.rst | 180 +++
>>> > .../directives.rst} | 309 -----
>>> > c-user/sem/index.rst | 18 +
>>> > c-user/sem/introduction.rst | 25 +
>>> > c-user/sem/operations.rst | 105 ++
>>> > c-user/signal/background.rst | 112 ++
>>> > c-user/signal/directives.rst | 126 ++
>>> > c-user/signal/index.rst | 15 +
>>> > c-user/signal/introduction.rst | 13 +
>>> > c-user/signal/operations.rst | 75 ++
>>> > c-user/signal_manager.rst | 322 -----
>>> > c-user/tasks/background.rst | 390 ++++++
>>> > .../directives.rst} | 625 ----------
>>> > c-user/tasks/index.rst | 15 +
>>> > c-user/tasks/introduction.rst | 50 +
>>> > c-user/tasks/operations.rst | 192 +++
>>> > c-user/timer/background.rst | 71 ++
>>> > .../directives.rst} | 180 ---
>>> > c-user/timer/index.rst | 15 +
>>> > c-user/timer/introduction.rst | 29 +
>>> > c-user/timer/operations.rst | 84 ++
>>> > .../background.rst} | 161 ---
>>> > c-user/userext/directives.rst | 143 +++
>>> > c-user/userext/index.rst | 16 +
>>> > c-user/userext/introduction.rst | 17 +
>>> > 85 files changed, 5759 insertions(+), 5449 deletions(-)
>>> > create mode 100644 c-user/barrier/background.rst
>>> > rename c-user/{barrier_manager.rst => barrier/directives.rst} (55%)
>>> > create mode 100644 c-user/barrier/index.rst
>>> > create mode 100644 c-user/barrier/introduction.rst
>>> > create mode 100644 c-user/barrier/operations.rst
>>> > create mode 100644 c-user/clock/background.rst
>>> > rename c-user/{clock_manager.rst => clock/directives.rst} (65%)
>>> > create mode 100644 c-user/clock/index.rst
>>> > create mode 100644 c-user/clock/introduction.rst
>>> > create mode 100644 c-user/clock/operations.rst
>>> > create mode 100644 c-user/dpmem/background.rst
>>> > rename c-user/{dual_ports_memory_manager.rst => dpmem/directives.rst} (64%)
>>> > create mode 100644 c-user/dpmem/index.rst
>>> > create mode 100644 c-user/dpmem/introduction.rst
>>> > create mode 100644 c-user/dpmem/operations.rst
>>> > create mode 100644 c-user/event/background.rst
>>> > create mode 100644 c-user/event/directives.rst
>>> > create mode 100644 c-user/event/index.rst
>>> > create mode 100644 c-user/event/introduction.rst
>>> > create mode 100644 c-user/event/operations.rst
>>> > delete mode 100644 c-user/event_manager.rst
>>> > create mode 100644 c-user/intr/background.rst
>>> > rename c-user/{interrupt_manager.rst => intr/directives.rst} (61%)
>>> > create mode 100644 c-user/intr/index.rst
>>> > create mode 100644 c-user/intr/introduction.rst
>>> > create mode 100644 c-user/intr/operations.rst
>>> > create mode 100644 c-user/io/background.rst
>>> > rename c-user/{io_manager.rst => io/directives.rst} (61%)
>>> > create mode 100644 c-user/io/index.rst
>>> > create mode 100644 c-user/io/introduction.rst
>>> > create mode 100644 c-user/io/operations.rst
>>> > create mode 100644 c-user/message/background.rst
>>> > rename c-user/{message_manager.rst => message/directives.rst} (69%)
>>> > create mode 100644 c-user/message/index.rst
>>> > create mode 100644 c-user/message/introduction.rst
>>> > create mode 100644 c-user/message/operations.rst
>>> > create mode 100644 c-user/part/background.rst
>>> > rename c-user/{partition_manager.rst => part/directives.rst} (70%)
>>> > create mode 100644 c-user/part/index.rst
>>> > create mode 100644 c-user/part/introduction.rst
>>> > create mode 100644 c-user/part/operations.rst
>>> > delete mode 100644 c-user/rate_monotonic_manager.rst
>>> > create mode 100644 c-user/ratemon/background.rst
>>> > create mode 100644 c-user/ratemon/directives.rst
>>> > create mode 100644 c-user/ratemon/index.rst
>>> > create mode 100644 c-user/ratemon/introduction.rst
>>> > create mode 100644 c-user/ratemon/operations.rst
>>> > create mode 100644 c-user/region/background.rst
>>> > rename c-user/{region_manager.rst => region/directives.rst} (66%)
>>> > create mode 100644 c-user/region/index.rst
>>> > create mode 100644 c-user/region/introduction.rst
>>> > create mode 100644 c-user/region/operations.rst
>>> > create mode 100644 c-user/sched/background.rst
>>> > create mode 100644 c-user/sched/directives.rst
>>> > create mode 100644 c-user/sched/index.rst
>>> > create mode 100644 c-user/sched/introduction.rst
>>> > create mode 100644 c-user/sched/smp-schedulers.rst
>>> > create mode 100644 c-user/sched/uniprocessor-schedulers.rst
>>> > delete mode 100644 c-user/scheduling_concepts.rst
>>> > create mode 100644 c-user/sem/background.rst
>>> > rename c-user/{semaphore_manager.rst => sem/directives.rst} (64%)
>>> > create mode 100644 c-user/sem/index.rst
>>> > create mode 100644 c-user/sem/introduction.rst
>>> > create mode 100644 c-user/sem/operations.rst
>>> > create mode 100644 c-user/signal/background.rst
>>> > create mode 100644 c-user/signal/directives.rst
>>> > create mode 100644 c-user/signal/index.rst
>>> > create mode 100644 c-user/signal/introduction.rst
>>> > create mode 100644 c-user/signal/operations.rst
>>> > delete mode 100644 c-user/signal_manager.rst
>>> > create mode 100644 c-user/tasks/background.rst
>>> > rename c-user/{task_manager.rst => tasks/directives.rst} (63%)
>>> > create mode 100644 c-user/tasks/index.rst
>>> > create mode 100644 c-user/tasks/introduction.rst
>>> > create mode 100644 c-user/tasks/operations.rst
>>> > create mode 100644 c-user/timer/background.rst
>>> > rename c-user/{timer_manager.rst => timer/directives.rst} (64%)
>>> > create mode 100644 c-user/timer/index.rst
>>> > create mode 100644 c-user/timer/introduction.rst
>>> > create mode 100644 c-user/timer/operations.rst
>>> > rename c-user/{user_extensions.rst => userext/background.rst} (77%)
>>> > create mode 100644 c-user/userext/directives.rst
>>> > create mode 100644 c-user/userext/index.rst
>>> > create mode 100644 c-user/userext/introduction.rst
>>> > 2.26.2
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
