Error in RISC-V Dynamic loading code
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Mon Aug 31 09:13:21 UTC 2020
Hello Eshan,
What rtems-tools version are you using? I remember I fixed that (or
something similar) in this commit [1]
[1] https://github.com/RTEMS/rtems-tools/commit/e6e610d262940b7651157597b6b1406aa806b4d1
On Sun, 30 Aug 2020 at 18:33, Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> Hello everyone,
> While testing my confstr patch on RISCV i received this error.
> Error Log :
> make[5]: Entering directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac/testsuites/libtests'
> rtems-ld -r /home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac \
> -C riscv-rtems6-gcc -c "-march=rv32imac -mabi=ilp32" \
> -O rap -b dl06.pre -e rtems_main -s \
> -o dl06.rap dl06-o1.o dl06-o2.o -lm
> error: rap::object: Section index '0' not found: dl06-o1.o
> Makefile:8528: recipe for target 'dl06.rap' failed
> make[5]: *** [dl06.rap] Error 10
> make[5]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac/testsuites/libtests'
> Makefile:663: recipe for target 'libtests' failed
> make[4]: *** [libtests] Error 2
> make[4]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac/testsuites'
> Makefile:1222: recipe for target 'testsuites' failed
> make[3]: *** [testsuites] Error 2
> make[3]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac'
> Makefile:716: recipe for target 'all-recursive' failed
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac'
> Makefile:289: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c'
> Makefile:410: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
> Thanks
> - Eshan
> devel mailing list
> devel at rtems.org
