Error in RISC-V Dynamic loading code
Eshan Dhawan
eshandhawan51 at gmail.com
Mon Aug 31 14:05:16 UTC 2020
>> On 31-Aug-2020, at 3:44 PM, Hesham Almatary <hesham.almatary at cl.cam.ac.uk> wrote:
> Hello Eshan,
> What rtems-tools version are you using? I remember I fixed that (or
> something similar) in this commit [1]
The error comes while Building RTEMS
> [1] https://github.com/RTEMS/rtems-tools/commit/e6e610d262940b7651157597b6b1406aa806b4d1
>> On Sun, 30 Aug 2020 at 18:33, Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> Hello everyone,
>> While testing my confstr patch on RISCV i received this error.
>> Error Log :
>> make[5]: Entering directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac/testsuites/libtests'
>> rtems-ld -r /home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac \
>> -C riscv-rtems6-gcc -c "-march=rv32imac -mabi=ilp32" \
>> -O rap -b dl06.pre -e rtems_main -s \
>> -o dl06.rap dl06-o1.o dl06-o2.o -lm
>> error: rap::object: Section index '0' not found: dl06-o1.o
>> Makefile:8528: recipe for target 'dl06.rap' failed
>> make[5]: *** [dl06.rap] Error 10
>> make[5]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac/testsuites/libtests'
>> Makefile:663: recipe for target 'libtests' failed
>> make[4]: *** [libtests] Error 2
>> make[4]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac/testsuites'
>> Makefile:1222: recipe for target 'testsuites' failed
>> make[3]: *** [testsuites] Error 2
>> make[3]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac'
>> Makefile:716: recipe for target 'all-recursive' failed
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c/rv32imac'
>> Makefile:289: recipe for target 'all-recursive' failed
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory '/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems6/c'
>> Makefile:410: recipe for target 'all-recursive' failed
>> make: *** [all-recursive] Error 1
>> Thanks
>> - Eshan
>> devel mailing list
>> devel at rtems.org
