[PATCH 04/12] shell: Rename "IO" typedef for better Doxygen
Sebastian Huber
Tue Dec 1 08:10:05 UTC 2020
An automatic link from every place in the documentation which mentions
"IO" to this dd command internal "IO" typedef is not really nice.
cpukit/libmisc/shell/dd.h | 4 ++--
cpukit/libmisc/shell/extern-dd.h | 4 ++--
cpukit/libmisc/shell/main_dd.c | 4 ++--
3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/cpukit/libmisc/shell/dd.h b/cpukit/libmisc/shell/dd.h
index dc80765d48..75012e707e 100644
--- a/cpukit/libmisc/shell/dd.h
+++ b/cpukit/libmisc/shell/dd.h
@@ -61,7 +61,7 @@ typedef struct {
const char *name; /* name */
int fd; /* file descriptor */
off_t offset; /* # of blocks to skip */
-} IO;
+} rtems_shell_dd_IO;
typedef struct {
uintmax_t in_full; /* # of full input blocks */
@@ -72,7 +72,7 @@ typedef struct {
uintmax_t swab; /* # of odd-length swab blocks */
uintmax_t bytes; /* # of bytes written */
double start; /* start time of dd */
-} STAT;
+} rtems_shell_dd_STAT;
/* Flags (in ddflags). */
#define C_ASCII 0x00001
diff --git a/cpukit/libmisc/shell/extern-dd.h b/cpukit/libmisc/shell/extern-dd.h
index 405d460ef3..6dc2db0180 100644
--- a/cpukit/libmisc/shell/extern-dd.h
+++ b/cpukit/libmisc/shell/extern-dd.h
@@ -40,8 +40,8 @@
#include <setjmp.h>
typedef struct rtems_shell_dd_globals_t {
- IO in, out; /* input/output state */
- STAT st; /* statistics */
+ rtems_shell_dd_IO in, out; /* input/output state */
+ rtems_shell_dd_STAT st; /* statistics */
void (*cfunc)(struct rtems_shell_dd_globals_t* globals); /* conversion function */
uintmax_t cpy_cnt; /* # of blocks to copy */
u_int ddflags; /* conversion options */
diff --git a/cpukit/libmisc/shell/main_dd.c b/cpukit/libmisc/shell/main_dd.c
index 35cd826711..93cd4cc8f5 100644
--- a/cpukit/libmisc/shell/main_dd.c
+++ b/cpukit/libmisc/shell/main_dd.c
@@ -86,7 +86,7 @@ __FBSDID("$FreeBSD: src/bin/dd/dd.c,v 1.43 2004/08/15 19:10:05 rwatson Exp $");
static void dd_close(rtems_shell_dd_globals* globals);
static void dd_in(rtems_shell_dd_globals* globals);
-static void getfdtype(rtems_shell_dd_globals* globals, IO *);
+static void getfdtype(rtems_shell_dd_globals* globals, rtems_shell_dd_IO *);
static void setup(rtems_shell_dd_globals* globals);
#if RTEMS_REMOVED
@@ -299,7 +299,7 @@ setup(rtems_shell_dd_globals* globals)
static void
-getfdtype(rtems_shell_dd_globals* globals, IO *io)
+getfdtype(rtems_shell_dd_globals* globals, rtems_shell_dd_IO *io)
struct stat sb;
#if RTEMS_REMOVED
2.26.2
