[PATCH 05/12] rtems: Add <rtems/rtems/clockimpl.h>
Sebastian Huber
Tue Dec 1 08:10:06 UTC 2020
bsps/arm/altera-cyclone-v/rtc/rtc.c | 1 +
bsps/arm/lpc32xx/rtc/rtc-config.c | 1 +
bsps/bfin/shared/dev/rtc.c | 1 +
bsps/shared/dev/rtc/ds1375.c | 1 +
bsps/shared/dev/rtc/rtc-support.c | 1 +
cpukit/include/rtems/rtems/clock.h | 30 -----------
cpukit/include/rtems/rtems/clockimpl.h | 73 ++++++++++++++++++++++++++
cpukit/rtems/src/clockset.c | 2 +-
cpukit/rtems/src/clocktodtoseconds.c | 2 +-
cpukit/rtems/src/clocktodvalidate.c | 2 +-
cpukit/rtems/src/taskwakewhen.c | 2 +-
cpukit/rtems/src/timercreate.c | 2 +-
testsuites/sptests/sp2038/init.c | 1 +
13 files changed, 84 insertions(+), 35 deletions(-)
create mode 100644 cpukit/include/rtems/rtems/clockimpl.h
diff --git a/bsps/arm/altera-cyclone-v/rtc/rtc.c b/bsps/arm/altera-cyclone-v/rtc/rtc.c
index d30bfec2df..3e8c68e789 100644
--- a/bsps/arm/altera-cyclone-v/rtc/rtc.c
+++ b/bsps/arm/altera-cyclone-v/rtc/rtc.c
@@ -33,6 +33,7 @@
#include <libchip/rtc.h>
#include <assert.h>
+#include <rtems/rtems/clockimpl.h>
#include <sys/filio.h>
#include <fcntl.h>
diff --git a/bsps/arm/lpc32xx/rtc/rtc-config.c b/bsps/arm/lpc32xx/rtc/rtc-config.c
index 52e2daf4c2..268c2b66bd 100644
--- a/bsps/arm/lpc32xx/rtc/rtc-config.c
+++ b/bsps/arm/lpc32xx/rtc/rtc-config.c
@@ -24,6 +24,7 @@
#include <bsp.h>
#include <bsp/lpc32xx.h>
#include <time.h>
diff --git a/bsps/bfin/shared/dev/rtc.c b/bsps/bfin/shared/dev/rtc.c
index fa340a3c45..cb15ca0607 100644
--- a/bsps/bfin/shared/dev/rtc.c
+++ b/bsps/bfin/shared/dev/rtc.c
@@ -20,6 +20,7 @@
#include <bsp.h>
#include <libcpu/rtcRegs.h>
/* The following are inside RTEMS -- we are violating visibility!!!
* Perhaps an API could be defined to get days since 1 Jan.
diff --git a/bsps/shared/dev/rtc/ds1375.c b/bsps/shared/dev/rtc/ds1375.c
index 4a23a0044b..e51744355f 100644
--- a/bsps/shared/dev/rtc/ds1375.c
+++ b/bsps/shared/dev/rtc/ds1375.c
@@ -54,6 +54,7 @@
#include <rtems/bspIo.h>
#include <rtems/rtc.h>
#include <rtems/score/sysstate.h>
#include <libchip/ds1375-rtc.h>
diff --git a/bsps/shared/dev/rtc/rtc-support.c b/bsps/shared/dev/rtc/rtc-support.c
index 560d2ea33f..765bfe1d6b 100644
--- a/bsps/shared/dev/rtc/rtc-support.c
+++ b/bsps/shared/dev/rtc/rtc-support.c
@@ -12,6 +12,7 @@
#include <rtems/tod.h>
#include <rtems/libio.h>
diff --git a/cpukit/include/rtems/rtems/clock.h b/cpukit/include/rtems/rtems/clock.h
index 7f2887fb03..c3eea7d254 100644
--- a/cpukit/include/rtems/rtems/clock.h
+++ b/cpukit/include/rtems/rtems/clock.h
@@ -267,36 +267,6 @@ time_t rtems_clock_get_uptime_seconds( void );
uint64_t rtems_clock_get_uptime_nanoseconds( void );
- * @brief TOD Validate
- * This support function returns true if @a the_tod contains
- * a valid time of day, and false otherwise.
- * @param[in] the_tod is the TOD structure to validate
- * @retval This method returns true if the TOD is valid and false otherwise.
- * @note This routine only works for leap-years through 2099.
-bool _TOD_Validate(
- const rtems_time_of_day *the_tod
- * @brief TOD to Seconds
- * This function returns the number seconds between the epoch and @a the_tod.
- * @param[in] the_tod is the TOD structure to convert to seconds
- * @retval This method returns the number of seconds since epoch represented
- * by @a the_tod
-Watchdog_Interval _TOD_To_seconds(
#ifdef __cplusplus
#endif
diff --git a/cpukit/include/rtems/rtems/clockimpl.h b/cpukit/include/rtems/rtems/clockimpl.h
new file mode 100644
index 0000000000..eff1231fb2
--- /dev/null
+++ b/cpukit/include/rtems/rtems/clockimpl.h
@@ -0,0 +1,73 @@
+ * @file
+ * @ingroup RTEMSImplClassicClock
+ * @brief This header file provides interfaces used by the Clock Manager
+ * implementation.
+/* COPYRIGHT (c) 1989-2013.
+ * On-Line Applications Research Corporation (OAR).
+#ifndef _RTEMS_RTEMS_CLOCKIMPL_H
+#define _RTEMS_RTEMS_CLOCKIMPL_H
+#include <rtems/rtems/clock.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMSImplClassicClock Clock Manager
+ * @brief This group contains the Clock Manager implementation.
+ * @brief TOD Validate
+ * This support function returns true if @a the_tod contains
+ * a valid time of day, and false otherwise.
+ * @param[in] the_tod is the TOD structure to validate
+ * @retval This method returns true if the TOD is valid and false otherwise.
+ * @note This routine only works for leap-years through 2099.
+bool _TOD_Validate(
+ const rtems_time_of_day *the_tod
+ * @brief TOD to Seconds
+ * This function returns the number seconds between the epoch and @a the_tod.
+ * @param[in] the_tod is the TOD structure to convert to seconds
+ * @retval This method returns the number of seconds since epoch represented
+ * by @a the_tod
+Watchdog_Interval _TOD_To_seconds(
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_RTEMS_CLOCKIMPL_H */
diff --git a/cpukit/rtems/src/clockset.c b/cpukit/rtems/src/clockset.c
index a42cde7d90..58503394fd 100644
--- a/cpukit/rtems/src/clockset.c
+++ b/cpukit/rtems/src/clockset.c
@@ -18,7 +18,7 @@
#include "config.h"
#endif
-#include <rtems/rtems/clock.h>
#include <rtems/config.h>
diff --git a/cpukit/rtems/src/clocktodtoseconds.c b/cpukit/rtems/src/clocktodtoseconds.c
index 30bfba8cbc..d1a80170b2 100644
--- a/cpukit/rtems/src/clocktodtoseconds.c
+++ b/cpukit/rtems/src/clocktodtoseconds.c
@@ -18,7 +18,7 @@
#include "config.h"
#endif
#define TOD_SECONDS_AT_2100_03_01_00_00 4107538800UL
diff --git a/cpukit/rtems/src/clocktodvalidate.c b/cpukit/rtems/src/clocktodvalidate.c
index 55cff448b2..a0f841686c 100644
--- a/cpukit/rtems/src/clocktodvalidate.c
+++ b/cpukit/rtems/src/clocktodvalidate.c
@@ -18,7 +18,7 @@
#include "config.h"
#endif
diff --git a/cpukit/rtems/src/taskwakewhen.c b/cpukit/rtems/src/taskwakewhen.c
index 23789e1a14..39467754ce 100644
--- a/cpukit/rtems/src/taskwakewhen.c
+++ b/cpukit/rtems/src/taskwakewhen.c
@@ -19,7 +19,7 @@
#endif
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index db929417d5..cadcecb057 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -19,7 +19,7 @@
#endif
#include <rtems/rtems/timerimpl.h>
diff --git a/testsuites/sptests/sp2038/init.c b/testsuites/sptests/sp2038/init.c
index 8d81cb1049..a3f09d4156 100644
--- a/testsuites/sptests/sp2038/init.c
+++ b/testsuites/sptests/sp2038/init.c
@@ -22,6 +22,7 @@
const char rtems_test_name[] = "SP 2038";
2.26.2
