[PATCH rtems-docs] shell: Document i2c and spi commands.
Peter Dufault
dufault at hda.com
Tue Dec 1 12:45:58 UTC 2020
> On Nov 30, 2020, at 18:07 , Gedare Bloom <gedare at rtems.org> wrote:
> Aren't nearly all shell commands at least a bit unsafe? And we don't
> have a lot of commands that have to be explicitly turned on if
> CONFIGURE_SHELL_COMMANDS_ALL is already set. I found only networking
> commands.
> That seems accurate, you can go ahead with the approach you took then. It seems to be mostly consistent with the state of practice.
I was surprised at the need to enable each command instead of adding all I2C commands with a single enable. I don't think code overhead is an issue. If you're testing I2C from the shell I'm not sure when it's important to have only e.g. i2cget but not i2cset.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201201/a42e3454/attachment.bin>
