[PATCH rtems-docs] shell: Document i2c and spi commands.
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Dec 1 12:52:30 UTC 2020
Am 01.12.20 um 13:45 schrieb Peter Dufault:
>> On Nov 30, 2020, at 18:07 , Gedare Bloom <gedare at rtems.org> wrote:
>> Aren't nearly all shell commands at least a bit unsafe? And we don't
>> have a lot of commands that have to be explicitly turned on if
>> CONFIGURE_SHELL_COMMANDS_ALL is already set. I found only networking
>> commands.
>> That seems accurate, you can go ahead with the approach you took then. It seems to be mostly consistent with the state of practice.
> I was surprised at the need to enable each command instead of adding all I2C commands with a single enable.  I don't think code overhead is an issue.  If you're testing I2C from the shell I'm not sure when it's important to have only e.g. i2cget but not i2cset.
It's like with a lot of other commands in RTEMS. You can have all or you
enable them one by one. I had a look and we have (for example) also no
group for file commands like rm, mv, cp, ls.
The only group I found (beneath CONFIGURE_SHELL_COMMANDS_ALL) is the
CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING. I'm not sure whether it would
be a good idea to start a new group now.
Best regards
Christian
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> This email is delivered through the public internet using protocols subject to interception and tampering.
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
