[PATCH v1 1/3] bsps: Move zynq-uart to bsps/shared
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Dec 1 20:57:53 UTC 2020
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
bsps/arm/headers.am | 2 --
bsps/arm/xilinx-zynq/console/console-config.c | 2 +-
bsps/arm/xilinx-zynq/console/console-init.c | 2 +-
bsps/arm/xilinx-zynq/console/debug-console.c | 2 +-
bsps/arm/xilinx-zynq/include/bsp.h | 2 +-
bsps/arm/xilinx-zynq/start/bspreset.c | 2 +-
bsps/arm/xilinx-zynqmp/console/console-config.c | 2 +-
bsps/headers.am | 2 ++
.../include/bsp => include/dev/serial}/zynq-uart-regs.h | 0
bsps/{arm/include/bsp => include/dev/serial}/zynq-uart.h | 7 +++++++
bsps/{arm/shared => shared/dev}/serial/zynq-uart-polled.c | 4 ++--
bsps/{arm/shared => shared/dev}/serial/zynq-uart.c | 4 ++--
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 4 ++--
c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am | 4 ++--
spec/build/bsps/arm/grp.yml | 2 --
spec/build/bsps/arm/xilinx-zynq/obj.yml | 2 --
spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml | 2 --
spec/build/bsps/obj.yml | 4 ++++
18 files changed, 27 insertions(+), 22 deletions(-)
rename bsps/{arm/include/bsp => include/dev/serial}/zynq-uart-regs.h (100%)
rename bsps/{arm/include/bsp => include/dev/serial}/zynq-uart.h (93%)
rename bsps/{arm/shared => shared/dev}/serial/zynq-uart-polled.c (98%)
rename bsps/{arm/shared => shared/dev}/serial/zynq-uart.c (98%)
diff --git a/bsps/arm/headers.am b/bsps/arm/headers.am
index bff9a16fc8..a4d6dfa09e 100644
--- a/bsps/arm/headers.am
+++ b/bsps/arm/headers.am
@@ -31,8 +31,6 @@ include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/lpc-i2s.h
include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/lpc-lcd.h
include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/lpc-timer.h
include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/start.h
-include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/zynq-uart-regs.h
-include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/zynq-uart.h
include_libcpudir = $(includedir)/libcpu
include_libcpu_HEADERS =
diff --git a/bsps/arm/xilinx-zynq/console/console-config.c b/bsps/arm/xilinx-zynq/console/console-config.c
index 7e28716bbe..0581247a2d 100644
--- a/bsps/arm/xilinx-zynq/console/console-config.c
+++ b/bsps/arm/xilinx-zynq/console/console-config.c
@@ -26,7 +26,7 @@
#include <bsp/irq.h>
-#include <bsp/zynq-uart.h>
+#include <dev/serial/zynq-uart.h>
zynq_uart_context zynq_uart_instances[2] = {
diff --git a/bsps/arm/xilinx-zynq/console/console-init.c b/bsps/arm/xilinx-zynq/console/console-init.c
index 72ba27006c..a3659e3906 100644
--- a/bsps/arm/xilinx-zynq/console/console-init.c
+++ b/bsps/arm/xilinx-zynq/console/console-init.c
@@ -28,7 +28,7 @@
#include <rtems/console.h>
#include <bsp.h>
rtems_status_code console_initialize(
rtems_device_major_number major,
diff --git a/bsps/arm/xilinx-zynq/console/debug-console.c b/bsps/arm/xilinx-zynq/console/debug-console.c
index 809fd6830d..0e9b756f30 100644
--- a/bsps/arm/xilinx-zynq/console/debug-console.c
+++ b/bsps/arm/xilinx-zynq/console/debug-console.c
@@ -29,7 +29,7 @@
#include <rtems/sysinit.h>
#include <bsp.h>
#include <bspopts.h>
diff --git a/bsps/arm/xilinx-zynq/include/bsp.h b/bsps/arm/xilinx-zynq/include/bsp.h
index 6c2759ce50..fde8d03130 100644
--- a/bsps/arm/xilinx-zynq/include/bsp.h
+++ b/bsps/arm/xilinx-zynq/include/bsp.h
@@ -54,7 +54,7 @@
#include <bsp/default-initial-extension.h>
#include <bsp/start.h>
#ifdef __cplusplus
extern "C" {
diff --git a/bsps/arm/xilinx-zynq/start/bspreset.c b/bsps/arm/xilinx-zynq/start/bspreset.c
index e0c81ca2ef..3e797a137e 100644
--- a/bsps/arm/xilinx-zynq/start/bspreset.c
+++ b/bsps/arm/xilinx-zynq/start/bspreset.c
@@ -27,7 +27,7 @@
#include <bsp.h>
#include <bsp/bootcard.h>
void bsp_reset(void)
diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c b/bsps/arm/xilinx-zynqmp/console/console-config.c
index a525f9c565..fb0b003c83 100644
--- a/bsps/arm/xilinx-zynqmp/console/console-config.c
+++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
@@ -35,7 +35,7 @@
diff --git a/bsps/headers.am b/bsps/headers.am
index b433c2d8d4..8147745711 100644
--- a/bsps/headers.am
+++ b/bsps/headers.am
@@ -32,6 +32,8 @@ include_dev_serialdir = $(includedir)/dev/serial
include_dev_serial_HEADERS =
include_dev_serial_HEADERS += ../../bsps/include/dev/serial/arm-pl011-regs.h
include_dev_serial_HEADERS += ../../bsps/include/dev/serial/arm-pl011.h
+include_dev_serial_HEADERS += ../../bsps/include/dev/serial/zynq-uart-regs.h
+include_dev_serial_HEADERS += ../../bsps/include/dev/serial/zynq-uart.h
include_grlibdir = $(includedir)/grlib
include_grlib_HEADERS =
diff --git a/bsps/arm/include/bsp/zynq-uart-regs.h b/bsps/include/dev/serial/zynq-uart-regs.h
similarity index 100%
rename from bsps/arm/include/bsp/zynq-uart-regs.h
rename to bsps/include/dev/serial/zynq-uart-regs.h
diff --git a/bsps/arm/include/bsp/zynq-uart.h b/bsps/include/dev/serial/zynq-uart.h
similarity index 93%
rename from bsps/arm/include/bsp/zynq-uart.h
rename to bsps/include/dev/serial/zynq-uart.h
index 20c3c9b653..2c0f250a3a 100644
--- a/bsps/arm/include/bsp/zynq-uart.h
+++ b/bsps/include/dev/serial/zynq-uart.h
@@ -44,6 +44,9 @@ extern "C" {
* @defgroup zynq_uart UART Support
* @ingroup RTEMSBSPsARMZynq
* @brief UART Support
+ * This driver operates an instance of the Cadence UART present in the
+ * family of Xilinx Zynq SoCs.
typedef struct {
@@ -57,6 +60,10 @@ extern const rtems_termios_device_handler zynq_uart_handler;
#define ZYNQ_UART_DEFAULT_BAUD 115200
+#ifndef ZYNQ_CLOCK_UART
+#define ZYNQ_CLOCK_UART 100000000
+#endif
void zynq_uart_initialize(rtems_termios_device_context *base);
int zynq_uart_read_polled(rtems_termios_device_context *base);
diff --git a/bsps/arm/shared/serial/zynq-uart-polled.c b/bsps/shared/dev/serial/zynq-uart-polled.c
similarity index 98%
rename from bsps/arm/shared/serial/zynq-uart-polled.c
rename to bsps/shared/dev/serial/zynq-uart-polled.c
index e6f478ee07..a1b51ea521 100644
--- a/bsps/arm/shared/serial/zynq-uart-polled.c
+++ b/bsps/shared/dev/serial/zynq-uart-polled.c
@@ -25,8 +25,8 @@
* POSSIBILITY OF SUCH DAMAGE.
-#include <bsp/zynq-uart-regs.h>
+#include <dev/serial/zynq-uart-regs.h>
diff --git a/bsps/arm/shared/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
rename from bsps/arm/shared/serial/zynq-uart.c
rename to bsps/shared/dev/serial/zynq-uart.c
index fc670441b8..41adb196ab 100644
--- a/bsps/arm/shared/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -25,8 +25,8 @@
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index cfd59475c2..299e69c128 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -62,8 +62,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termio
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/console/console-config.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/console/console-init.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/console/debug-console.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/zynq-uart.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/zynq-uart-polled.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/zynq-uart.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/zynq-uart-polled.c
# Clock
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-a9mpcore.c
diff --git a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
index ac67c60e93..f689c2e294 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
@@ -60,8 +60,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-gic.c
# Console
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynqmp/console/console-config.c
# Clock
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/clock/arm-generic-timer.c
diff --git a/spec/build/bsps/arm/grp.yml b/spec/build/bsps/arm/grp.yml
index dd7694be83..8d2aba12ca 100644
--- a/spec/build/bsps/arm/grp.yml
+++ b/spec/build/bsps/arm/grp.yml
@@ -36,8 +36,6 @@ install:
- bsps/arm/include/bsp/lpc-lcd.h
- bsps/arm/include/bsp/lpc-timer.h
- bsps/arm/include/bsp/start.h
- - bsps/arm/include/bsp/zynq-uart-regs.h
- - bsps/arm/include/bsp/zynq-uart.h
- destination: ${BSP_INCLUDEDIR}/dev/irq
source:
- bsps/include/dev/irq/arm-gic-irq.h
diff --git a/spec/build/bsps/arm/xilinx-zynq/obj.yml b/spec/build/bsps/arm/xilinx-zynq/obj.yml
index 6f7f8ab39a..06e13e4ea1 100644
--- a/spec/build/bsps/arm/xilinx-zynq/obj.yml
+++ b/spec/build/bsps/arm/xilinx-zynq/obj.yml
@@ -25,8 +25,6 @@ source:
- bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
- bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
- bsps/arm/shared/irq/irq-gic.c
-- bsps/arm/shared/serial/zynq-uart.c
-- bsps/arm/shared/serial/zynq-uart-polled.c
- bsps/arm/shared/start/bsp-start-memcpy.S
- bsps/arm/xilinx-zynq/console/console-config.c
- bsps/arm/xilinx-zynq/console/console-init.c
diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
index ea3895ab99..8c8013db24 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
@@ -80,8 +80,6 @@ source:
- bsps/arm/xilinx-zynqmp/console/console-config.c
- bsps/arm/xilinx-zynqmp/start/bspreset.c
diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
index a454783d51..7ea560b47d 100644
--- a/spec/build/bsps/obj.yml
+++ b/spec/build/bsps/obj.yml
@@ -52,6 +52,8 @@ install:
source:
- bsps/include/dev/serial/arm-pl011-regs.h
- bsps/include/dev/serial/arm-pl011.h
+ - bsps/include/dev/serial/zynq-uart-regs.h
+ - bsps/include/dev/serial/zynq-uart.h
- destination: ${BSP_INCLUDEDIR}/rtems/zilog
source:
- bsps/include/rtems/zilog/z8036.h
@@ -94,6 +96,8 @@ source:
- bsps/shared/dev/serial/ns16550.c
- bsps/shared/dev/serial/ns16550-context.c
- bsps/shared/dev/serial/serprobe.c
+- bsps/shared/dev/serial/zynq-uart.c
+- bsps/shared/dev/serial/zynq-uart-polled.c
- bsps/shared/start/bootcard.c
- bsps/shared/rtems-version.c
type: build
2.20.1
