[PATCH v1 2/3] bsps: Move ARM GICv2 driver to bsps/shared
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Dec 1 20:57:54 UTC 2020
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
...-gicv3-aarch64.c => irq-arm-gicvx-aarch64.c} | 2 +-
...-gicv3-aarch32.c => irq-arm-gicvx-aarch32.c} | 2 +-
bsps/include/dev/irq/arm-gic-irq.h | 4 ++--
.../irq-gic.c => shared/dev/irq/arm-gicv2.c} | 17 +++--------------
bsps/shared/dev/irq/arm-gicv3.c | 2 +-
.../lib/libbsp/arm/altera-cyclone-v/Makefile.am | 3 ++-
c/src/lib/libbsp/arm/imx/Makefile.am | 3 ++-
.../lib/libbsp/arm/realview-pbx-a9/Makefile.am | 3 ++-
c/src/lib/libbsp/arm/xen/Makefile.am | 3 ++-
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 3 ++-
c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am | 3 ++-
spec/build/bsps/aarch64/a53/obj.yml | 2 +-
.../arm/altera-cyclone-v/bspalteracyclonev.yml | 3 ++-
spec/build/bsps/arm/imx/bspimx.yml | 3 ++-
.../arm/realview-pbx-a9/bsprealviewpbxa9.yml | 3 ++-
spec/build/bsps/arm/xen/bspxen.yml | 3 ++-
spec/build/bsps/arm/xilinx-zynq/obj.yml | 3 ++-
.../bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml | 3 ++-
18 files changed, 33 insertions(+), 32 deletions(-)
rename bsps/aarch64/shared/irq/{irq-arm-gicv3-aarch64.c => irq-arm-gicvx-aarch64.c} (98%)
rename bsps/arm/shared/irq/{irq-arm-gicv3-aarch32.c => irq-arm-gicvx-aarch32.c} (98%)
rename bsps/{arm/shared/irq/irq-gic.c => shared/dev/irq/arm-gicv2.c} (95%)
diff --git a/bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c b/bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
similarity index 98%
rename from bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
rename to bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
index fe74bf46bd..67839118e1 100644
--- a/bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
+++ b/bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
@@ -60,5 +60,5 @@ void arm_interrupt_facility_set_exception_handler(void)
void bsp_interrupt_dispatch(void)
- gicv3_interrupt_dispatch();
+ gicvx_interrupt_dispatch();
diff --git a/bsps/arm/shared/irq/irq-arm-gicv3-aarch32.c b/bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
rename from bsps/arm/shared/irq/irq-arm-gicv3-aarch32.c
rename to bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
index b805199ba9..b9267aecba 100644
--- a/bsps/arm/shared/irq/irq-arm-gicv3-aarch32.c
+++ b/bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
@@ -57,5 +57,5 @@ void arm_interrupt_facility_set_exception_handler(void)
diff --git a/bsps/include/dev/irq/arm-gic-irq.h b/bsps/include/dev/irq/arm-gic-irq.h
index a97191faca..d63fce32d1 100644
--- a/bsps/include/dev/irq/arm-gic-irq.h
+++ b/bsps/include/dev/irq/arm-gic-irq.h
@@ -122,10 +122,10 @@ void arm_interrupt_facility_set_exception_handler(void);
void arm_interrupt_handler_dispatch(rtems_vector_number vector);
- * This is the GICv3 interrupt dispatcher that is to be called from the
+ * This is the GICv1/GICv2/GICv3 interrupt dispatcher that is to be called from the
* architecture-specific implementation of the IRQ handler.
-void gicv3_interrupt_dispatch(void);
+void gicvx_interrupt_dispatch(void);
static inline uint32_t arm_gic_irq_processor_count(void)
diff --git a/bsps/arm/shared/irq/irq-gic.c b/bsps/shared/dev/irq/arm-gicv2.c
similarity index 95%
rename from bsps/arm/shared/irq/irq-gic.c
rename to bsps/shared/dev/irq/arm-gicv2.c
index 1a401b67b6..cba8982764 100644
--- a/bsps/arm/shared/irq/irq-gic.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -14,10 +14,6 @@
#include <dev/irq/arm-gic.h>
-#include <rtems/score/armv4.h>
-#include <libcpu/arm-cp15.h>
#include <bsp/irq.h>
#include <bsp/irq-generic.h>
#include <bsp/start.h>
@@ -53,7 +49,7 @@
#define CPUIF_ICCICR GIC_CPUIF_ICCICR_ENABLE
#endif
-void bsp_interrupt_dispatch(void)
volatile gic_cpuif *cpuif = GIC_CPUIF;
uint32_t icciar = cpuif->icciar;
@@ -61,11 +57,7 @@ void bsp_interrupt_dispatch(void)
rtems_vector_number spurious = 1023;
if (vector != spurious) {
- uint32_t psr = _ARMV4_Status_irq_enable();
- bsp_interrupt_handler_dispatch(vector);
- _ARMV4_Status_restore(psr);
+ arm_interrupt_handler_dispatch(vector);
cpuif->icceoir = icciar;
@@ -117,10 +109,7 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
uint32_t id_count = get_id_count(dist);
uint32_t id;
- arm_cp15_set_exception_handler(
- ARM_EXCEPTION_IRQ,
- _ARMV4_Exception_interrupt
+ arm_interrupt_facility_set_exception_handler();
for (id = 0; id < id_count; id += 32) {
#ifdef BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index ad39872eb0..da19300b15 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -134,7 +134,7 @@
#define ARM_GIC_REDIST ((volatile gic_redist *) BSP_ARM_GIC_REDIST_BASE)
#define ARM_GIC_SGI_PPI (((volatile gic_sgi_ppi *) ((char*)BSP_ARM_GIC_REDIST_BASE + (1 << 16))))
uint32_t icciar = READ_SR(ICC_IAR1);
rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index b2785988e0..22be647261 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -62,7 +62,8 @@ endif
# IRQ
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-gic.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/irq/arm-gicv2.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
# Console
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios-init.c
diff --git a/c/src/lib/libbsp/arm/imx/Makefile.am b/c/src/lib/libbsp/arm/imx/Makefile.am
index c9537a773d..caef3c6170 100644
--- a/c/src/lib/libbsp/arm/imx/Makefile.am
+++ b/c/src/lib/libbsp/arm/imx/Makefile.am
@@ -51,7 +51,8 @@ endif
# IRQ
# Console
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
index 77b7db4cca..d1597068ef 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
@@ -56,7 +56,8 @@ endif
# IRQ
# Console
diff --git a/c/src/lib/libbsp/arm/xen/Makefile.am b/c/src/lib/libbsp/arm/xen/Makefile.am
index c8f7eb4f20..e01c33deb5 100644
--- a/c/src/lib/libbsp/arm/xen/Makefile.am
+++ b/c/src/lib/libbsp/arm/xen/Makefile.am
@@ -35,7 +35,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/arm-generic-tim
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
# irq
# console
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xen/console/console.c
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index 299e69c128..a4b9496630 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -55,7 +55,8 @@ endif
# IRQ
# Console
diff --git a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
index f689c2e294..11d6ab8039 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
# IRQ
# Console
diff --git a/spec/build/bsps/aarch64/a53/obj.yml b/spec/build/bsps/aarch64/a53/obj.yml
index b584a2413c..0d69b59416 100644
--- a/spec/build/bsps/aarch64/a53/obj.yml
+++ b/spec/build/bsps/aarch64/a53/obj.yml
@@ -30,7 +30,7 @@ source:
- bsps/shared/start/sbrk.c
- bsps/shared/dev/irq/arm-gicv3.c
- bsps/shared/irq/irq-default-handler.c
-- bsps/aarch64/shared/irq/irq-arm-gicv3-aarch64.c
+- bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
- bsps/shared/dev/btimer/btimer-cpucounter.c
- bsps/shared/dev/clock/arm-generic-timer.c
- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
index abe3d7f490..c6732c4d47 100644
--- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
+++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
@@ -128,7 +128,8 @@ source:
- bsps/arm/shared/clock/clock-a9mpcore.c
- bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
- bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
-- bsps/arm/shared/irq/irq-gic.c
+- bsps/shared/dev/irq/arm-gicv2.c
+- bsps/arm/shared/irq/irq-arm-gicvx-aarch32.c
- bsps/arm/shared/start/bsp-start-memcpy.S
- bsps/shared/dev/btimer/btimer-stub.c
- bsps/shared/dev/getentropy/getentropy-cpucounter.c
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index 6b3cfdbb2e..5f448682ed 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -97,7 +97,8 @@ source:
- bsps/arm/shared/clock/arm-generic-timer-aarch32.c
diff --git a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
index 8e4dd318f2..6233aae2f0 100644
--- a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
+++ b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
@@ -67,7 +67,8 @@ source:
- bsps/arm/shared/fb/arm-pl111.c
- bsps/arm/shared/serial/arm-pl050.c
diff --git a/spec/build/bsps/arm/xen/bspxen.yml b/spec/build/bsps/arm/xen/bspxen.yml
index 59d3f8581e..3784315acd 100644
--- a/spec/build/bsps/arm/xen/bspxen.yml
+++ b/spec/build/bsps/arm/xen/bspxen.yml
@@ -63,7 +63,8 @@ source:
- bsps/arm/xen/console/console.c
- bsps/arm/xen/start/bspstart.c
diff --git a/spec/build/bsps/arm/xilinx-zynq/obj.yml b/spec/build/bsps/arm/xilinx-zynq/obj.yml
index 06e13e4ea1..c2dde615b8 100644
--- a/spec/build/bsps/arm/xilinx-zynq/obj.yml
+++ b/spec/build/bsps/arm/xilinx-zynq/obj.yml
@@ -24,7 +24,8 @@ source:
- bsps/arm/xilinx-zynq/console/console-config.c
- bsps/arm/xilinx-zynq/console/console-init.c
diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
index 8c8013db24..92da7904c9 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
@@ -79,7 +79,8 @@ source:
- bsps/arm/xilinx-zynqmp/console/console-config.c
- bsps/arm/xilinx-zynqmp/start/bspreset.c
2.20.1
