[PATCH] doc improvements
Robin Müller robin.mueller.m at gmail.com
Wed Dec 2 13:19:21 UTC 2020
Actually, I just saw that when switching to the 5 branch for the RTEMS
sources, there is no waf tool (at least I can't run it) so later parts of
the QuickStart guide won't work..
I could just leave it like that, but then RTEMS 6 is built and all version
numbers would have to be corrected..
KInd Regards
Robin
On Wed, 2 Dec 2020 at 13:59, Sebastian Huber <
> Hello Robin,
> On 02/12/2020 13:46, Robin Mueller wrote:
> >   user/start/sources.rst | 9 +++++++++
> >   user/start/tools.rst   | 9 ++++++++-
> >   2 files changed, 17 insertions(+), 1 deletion(-)
> > diff --git a/user/start/sources.rst b/user/start/sources.rst
> > index 8c40aa0..fddc439 100644
> > --- a/user/start/sources.rst
> > +++ b/user/start/sources.rst
> > @@ -86,12 +86,21 @@ You can clone the Git repository to get all versions
> of RTEMS including the
> >   development head.  Release branches in Git are kept stable however
> they may
> >   differ from a release's source archive.
> > +For this Quick Start guide, we will switch to the RTEMS 5 branches
> because the
> > +master branch does not contain the version 5 `rtems-sparc` build set.
> > +If you wich to build with the master branch instead, it is recommended
> to
> > +replace the version number 5 with version 6 everywhere it is used in
> the Quick Start guide.
> the documentation for the master branch should not refer to the RTEMS 5
> release. So, the right fix is to replace '5' with '6' if needed.
> >   .. code-block:: none
> >       mkdir -p $HOME/quick-start/src
> >       cd $HOME/quick-start/src
> >       git clone git://git.rtems.org/rtems-source-builder.git rsb
> > +    git checkout origin/5
> > +    git checkout -b 5
> >       git clone git://git.rtems.org/rtems.git
> > +    git checkout -b 5
> >   The :file:`rsb` repository clone contains the :ref:`RTEMS Source
> Builder (RSB)
> >   <RSB>`.  We clone it into :file:`rsb` to get shorter paths during the
> tool
> > diff --git a/user/start/tools.rst b/user/start/tools.rst
> > index baa2387..e0fe10d 100644
> > --- a/user/start/tools.rst
> > +++ b/user/start/tools.rst
> > @@ -20,7 +20,14 @@ The tool suite for RTEMS and the RTEMS sources are
> tightly coupled.  For
> >   example, do not use a RTEMS version 5 tool suite with RTEMS version
> 4.11
> >   sources and vice versa.
> > -Build and install the tool suite:
> > +The available build sets can be displayed with:
> > +.. code-block:: none
> > +    cd $HOME/quick-start/src/rsb/rtems
> > +    ../source-builder/sb-set-builder --list-bsets
> > +Build and install the version 5 tool suite for the SPARC architecture:
> This part looks good to me.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.hubere at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201202/2a368b28/attachment-0001.html>
