[PATCH] doc improvements
Robin Müller
robin.mueller.m at gmail.com
Wed Dec 2 13:23:34 UTC 2020
I will provide another patch with version numbers corrected.
Kind Regards
Robin
On Wed, 2 Dec 2020 at 14:19, Robin Müller <robin.mueller.m at gmail.com> wrote:
> Actually, I just saw that when switching to the 5 branch for the RTEMS
> sources, there is no waf tool (at least I can't run it) so later parts of
> the QuickStart guide won't work..
> I could just leave it like that, but then RTEMS 6 is built and all version
> numbers would have to be corrected..
> KInd Regards
> Robin
> On Wed, 2 Dec 2020 at 13:59, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Robin,
>> On 02/12/2020 13:46, Robin Mueller wrote:
>> > user/start/sources.rst | 9 +++++++++
>> > user/start/tools.rst | 9 ++++++++-
>> > 2 files changed, 17 insertions(+), 1 deletion(-)
>> > diff --git a/user/start/sources.rst b/user/start/sources.rst
>> > index 8c40aa0..fddc439 100644
>> > --- a/user/start/sources.rst
>> > +++ b/user/start/sources.rst
>> > @@ -86,12 +86,21 @@ You can clone the Git repository to get all
>> versions of RTEMS including the
>> > development head. Release branches in Git are kept stable however
>> they may
>> > differ from a release's source archive.
>> > +For this Quick Start guide, we will switch to the RTEMS 5 branches
>> because the
>> > +master branch does not contain the version 5 `rtems-sparc` build set.
>> > +If you wich to build with the master branch instead, it is recommended
>> to
>> > +replace the version number 5 with version 6 everywhere it is used in
>> the Quick Start guide.
>> the documentation for the master branch should not refer to the RTEMS 5
>> release. So, the right fix is to replace '5' with '6' if needed.
>> > .. code-block:: none
>> > mkdir -p $HOME/quick-start/src
>> > cd $HOME/quick-start/src
>> > git clone git://git.rtems.org/rtems-source-builder.git rsb
>> > + git checkout origin/5
>> > + git checkout -b 5
>> > git clone git://git.rtems.org/rtems.git
>> > + git checkout -b 5
>> > The :file:`rsb` repository clone contains the :ref:`RTEMS Source
>> Builder (RSB)
>> > <RSB>`. We clone it into :file:`rsb` to get shorter paths during the
>> tool
>> > diff --git a/user/start/tools.rst b/user/start/tools.rst
>> > index baa2387..e0fe10d 100644
>> > --- a/user/start/tools.rst
>> > +++ b/user/start/tools.rst
>> > @@ -20,7 +20,14 @@ The tool suite for RTEMS and the RTEMS sources are
>> tightly coupled. For
>> > example, do not use a RTEMS version 5 tool suite with RTEMS version
>> 4.11
>> > sources and vice versa.
>> > -Build and install the tool suite:
>> > +The available build sets can be displayed with:
>> > +.. code-block:: none
>> > + cd $HOME/quick-start/src/rsb/rtems
>> > + ../source-builder/sb-set-builder --list-bsets
>> > +Build and install the version 5 tool suite for the SPARC architecture:
>> This part looks good to me.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.hubere at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201202/0161c02c/attachment.html>
