"invalid %if operator" in RTEMS source builder .cfg file
Peter Dufault
dufault at hda.com
Wed Dec 2 14:48:50 UTC 2020
I'm building "Simple Open EtherCAT Master" with rtems-6. I built it earlier with rtems-5. I get the following error when I try to build it:
[dufault at build scripts]$ /home/dufault/development/rtems/rtems-source-builder/source-builder/sb-set-builder \
--log=log_arm_soem \
--prefix=/opt/flatland/opt/rtems-6 \
--with-tools=/opt/flatland/opt/rtems-6 \
--host=arm-rtems6 \
--with-rtems-bsp=xilinx_zynq_zedboard \
net/soem
RTEMS Source Builder - Set Builder, 6 (f8d1f3c00db9)
Build Set: net/soem
config: net/soem-master.cfg
error: rtems-bsp.cfg:169: invalid %if operator: -B/opt/flatland/opt/rtems-6/arm-rtems6/xilinx_zynq_a9_qemu/lib -qrtems ==
Build FAILED
Build Set: Time 0:00:00.055627
Build FAILED
It fails at the following "%if" directive:
# If there are no LDFLAGS create a path to RTEMS.
%if %{rtems_bsp_ldflags} == %{nil}
%define rtems_bsp_ldflags -L%{rtems_bsp_prefix}/lib
%endif
Not being sure how to proceed I commented the three lines out and then it built. Any suggestions?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201202/74fd26d4/attachment.bin>
