"invalid %if operator" in RTEMS source builder .cfg file
Chris Johns
chrisj at rtems.org
Wed Dec 2 20:35:17 UTC 2020
On 3/12/20 1:48 am, Peter Dufault wrote:
> I'm building "Simple Open EtherCAT Master" with rtems-6. I built it earlier with rtems-5. I get the following error when I try to build it:
> [dufault at build scripts]$ /home/dufault/development/rtems/rtems-source-builder/source-builder/sb-set-builder \
> --log=log_arm_soem \
> --prefix=/opt/flatland/opt/rtems-6 \
> --with-tools=/opt/flatland/opt/rtems-6 \
> --host=arm-rtems6 \
> --with-rtems-bsp=xilinx_zynq_zedboard \
> net/soem
> RTEMS Source Builder - Set Builder, 6 (f8d1f3c00db9)
> Build Set: net/soem
> config: net/soem-master.cfg
> error: rtems-bsp.cfg:169: invalid %if operator: -B/opt/flatland/opt/rtems-6/arm-rtems6/xilinx_zynq_a9_qemu/lib -qrtems ==
> Build FAILED
> Build Set: Time 0:00:00.055627
> Build FAILED
> It fails at the following "%if" directive:
> # If there are no LDFLAGS create a path to RTEMS.
> %if %{rtems_bsp_ldflags} == %{nil}
> %define rtems_bsp_ldflags -L%{rtems_bsp_prefix}/lib
> %endif
> Not being sure how to proceed I commented the three lines out and then it built. Any suggestions?
Was RTEMS built with the waf build system?
I wonder if the pkgconfig set of flags have changes between the build systems?
