[PATCH] doc improvements
Gedare Bloom
gedare at rtems.org
Wed Dec 2 17:09:10 UTC 2020
A significant challenge with the version numbers arises during the release
process. I will leave all these doc patches for Chris to review/feedback,
but the concern is that when a release is cut all the version numbers need
to be injected to the release and then updated for the main branch.
On Wed, Dec 2, 2020 at 6:23 AM Robin Müller <robin.mueller.m at gmail.com>
wrote:
> I will provide another patch with version numbers corrected.
> Kind Regards
> Robin
> On Wed, 2 Dec 2020 at 14:19, Robin Müller <robin.mueller.m at gmail.com>
> wrote:
>> Actually, I just saw that when switching to the 5 branch for the RTEMS
>> sources, there is no waf tool (at least I can't run it) so later parts of
>> the QuickStart guide won't work..
>> I could just leave it like that, but then RTEMS 6 is built and all
>> version numbers would have to be corrected..
>> KInd Regards
>> Robin
>> On Wed, 2 Dec 2020 at 13:59, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Hello Robin,
>>> On 02/12/2020 13:46, Robin Mueller wrote:
>>> > user/start/sources.rst | 9 +++++++++
>>> > user/start/tools.rst | 9 ++++++++-
>>> > 2 files changed, 17 insertions(+), 1 deletion(-)
>>> > diff --git a/user/start/sources.rst b/user/start/sources.rst
>>> > index 8c40aa0..fddc439 100644
>>> > --- a/user/start/sources.rst
>>> > +++ b/user/start/sources.rst
>>> > @@ -86,12 +86,21 @@ You can clone the Git repository to get all
>>> versions of RTEMS including the
>>> > development head. Release branches in Git are kept stable however
>>> they may
>>> > differ from a release's source archive.
>>> > +For this Quick Start guide, we will switch to the RTEMS 5 branches
>>> because the
>>> > +master branch does not contain the version 5 `rtems-sparc` build set.
>>> > +If you wich to build with the master branch instead, it is
>>> recommended to
>>> > +replace the version number 5 with version 6 everywhere it is used in
>>> the Quick Start guide.
>>> the documentation for the master branch should not refer to the RTEMS 5
>>> release. So, the right fix is to replace '5' with '6' if needed.
>>> > .. code-block:: none
>>> > mkdir -p $HOME/quick-start/src
>>> > cd $HOME/quick-start/src
>>> > git clone git://git.rtems.org/rtems-source-builder.git rsb
>>> > + git checkout origin/5
>>> > + git checkout -b 5
>>> > git clone git://git.rtems.org/rtems.git
>>> > + git checkout -b 5
>>> > The :file:`rsb` repository clone contains the :ref:`RTEMS Source
>>> Builder (RSB)
>>> > <RSB>`. We clone it into :file:`rsb` to get shorter paths during
>>> the tool
>>> > diff --git a/user/start/tools.rst b/user/start/tools.rst
>>> > index baa2387..e0fe10d 100644
>>> > --- a/user/start/tools.rst
>>> > +++ b/user/start/tools.rst
>>> > @@ -20,7 +20,14 @@ The tool suite for RTEMS and the RTEMS sources are
>>> tightly coupled. For
>>> > example, do not use a RTEMS version 5 tool suite with RTEMS version
>>> 4.11
>>> > sources and vice versa.
>>> > -Build and install the tool suite:
>>> > +The available build sets can be displayed with:
>>> > +.. code-block:: none
>>> > + cd $HOME/quick-start/src/rsb/rtems
>>> > + ../source-builder/sb-set-builder --list-bsets
>>> > +Build and install the version 5 tool suite for the SPARC architecture:
>>> This part looks good to me.
>>> embedded brains GmbH
>>> Herr Sebastian HUBER
>>> Dornierstr. 4
>>> 82178 Puchheim
>>> Germany
>>> email: sebastian.hubere at embedded-brains.de
>>> phone: +49-89-18 94 741 - 16
>>> fax: +49-89-18 94 741 - 08
>>> Registergericht: Amtsgericht München
>>> Registernummer: HRB 157899
>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>> Unsere Datenschutzerklärung finden Sie hier:
>>> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201202/471785dc/attachment.html>
