[PATCH 1/1] Add yaml format to the supported report formats
Wed Dec 2 20:41:06 UTC 2020
On 3/12/20 3:05 am, clrrm at isep.ipp.pt wrote:
> From: Cláudio Maia <clrrm at isep.ipp.pt>
Thanks. Does this work on python2?
>  tester/rt/test.py | 104 +++++++++++++++++++++++++++++++++++++++++++++-
>  1 file changed, 102 insertions(+), 2 deletions(-)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index 9b157e9..0178a8d 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -339,9 +339,109 @@ def generate_junit_report(args, reports, start_time, end_time,
>      with open(junit_file, 'w') as f:
>          TestSuite.to_file(f, [ts], prettyprint = True)
> +def generate_yaml_report(args, reports, start_time, end_time,
> +                         total, yaml_file):
> +    import yaml
I would catch an import error and generate a nice error message for the user
suggesting installing YAML from pip or where ever we recommend.
> +    def format_output(output_list):
> +        return "\n".join(output_list).replace("] ", '').replace('=>  ', '')
> +    yaml_log = {}
> +    yaml_log['command-line'] = args
> +    yaml_log['host'] = host.label(mode='all')
> +    yaml_log['python'] = sys.version.replace('\n', '')
> +    yaml_log['summary'] = {}
> +    yaml_log['summary']['passed-count'] = reports.passed
> +    yaml_log['summary']['failed-count'] = reports.failed
> +    yaml_log['summary']['user-input-count'] = reports.user_input
> +    yaml_log['summary']['expected-fail-count'] = reports.expected_fail
> +    yaml_log['summary']['indeterminate-count'] = reports.indeterminate
> +    yaml_log['summary']['benchmark-count'] = reports.benchmark
> +    yaml_log['summary']['timeout-count'] = reports.timeouts
> +    yaml_log['summary']['test-too-long_count'] = reports.test_too_long
> +    yaml_log['summary']['invalid-count'] = reports.invalids
> +    yaml_log['summary']['wrong-version-count'] = reports.wrong_version
> +    yaml_log['summary']['wrong-build-count'] = reports.wrong_build
> +    yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
> +    yaml_log['summary']['total-count'] = reports.total
> +    time_delta = end_time - start_time
> +    yaml_log['summary']['average-test-time'] = str(time_delta / total)
> +    yaml_log['summary']['testing-time'] = str(time_delta)
> +    result_types = [
> +            'failed', 'user-input', 'expected-fail', 'indeterminate',
> +            'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
> +            'wrong-build', 'wrong-tools'
> +    for result_type in result_types:
> +        yaml_log['summary'][result_type] = []
> +    result_element = {}
> +    yaml_log['outputs'] = []
> +    # process output of each test
> +    for exe_name in reports.results:
> +        result_element['executable-name'] = path.basename(exe_name)
> +        result_element['executable-sha512'] = get_hash512(exe_name)
> +        result_element['execution-start'] = reports.results[exe_name]['start'].isoformat()
> +        result_element['execution-end'] = reports.results[exe_name]['end'].isoformat()
> +        date_diff = reports.results[exe_name]['end'] - reports.results[exe_name]['start']
> +        result_element['execution-duration'] = str(date_diff)
> +        result_element['execution-result'] = reports.results[exe_name]['result']
> +        result_element['bsp'] = reports.results[exe_name]['bsp']
> +        result_element['bsp-arch'] = reports.results[exe_name]['bsp_arch']
> +        result_output = reports.results[exe_name]['output']
> +        dbg_output = []
> +        test_output = []
> +        idxs_output = []  # store indices of given substrings
> +        for elem in result_output:
> +            if '=> ' in elem:
> +                idxs_output.append(result_output.index(elem))
> +            if '*** END' in elem:
> +        if len(idxs_output) == 3:  # test executed and has result
> +            dbg_output = result_output[idxs_output[0]:idxs_output[1]]
> +            dbg_output.append("=== Executed Test ===")
> +            dbg_output = dbg_output + result_output[idxs_output[2]+1:len(result_output)]
> +            test_output = result_output[idxs_output[1]:idxs_output[2]+1]
> +        else:
> +        result_element['debugger-output'] = format_output(dbg_output)
> +        result_element['console-output'] = format_output(test_output)
> +        yaml_log['outputs'].append(result_element)
> +        result_type = reports.results[exe_name]['result']
> +        # map "fatal-error" on to "failed"
> +        if result_type == "fatal-error":
> +            result_type = "failed"
> +        if result_type != 'passed':
> +            yaml_log['summary'][result_type].append(path.basename(exe_name))
> +    with open(yaml_file, 'w') as outfile:
> +        yaml.dump(yaml_log, outfile, default_flow_style=False, allow_unicode=True)
> +def get_hash512(exe):
> +    """ returns SHA512 hash string of a given binary file passed as argument """
> +    import hashlib
> +    hash = hashlib.sha512()
> +    with open(exe, "rb") as f:
> +        for byte_block in iter(lambda: f.read(4096), b""):
> +            hash.update(byte_block)
> +    return hash.hexdigest()
>  report_formatters = {
>          'json': generate_json_report,
> -        'junit': generate_junit_report
> +        'junit': generate_junit_report,
> +        'yaml': generate_yaml_report
> @@ -365,7 +465,7 @@ def run(args):
>                      '--rtems-bsp':      'The RTEMS BSP to run the test on',
>                      '--user-config':    'Path to your local user configuration INI file',
>                      '--report-path':    'Report output base path (file extension will be added)',
> -                    '--report-format':  'Formats in which to report test results in addition to txt: json',
> +                    '--report-format':  'Formats in which to report test results in addition to txt: json, yaml',
>                      '--log-mode':       'Reporting modes, failures (default),all,none',
>                      '--list-bsps':      'List the supported BSPs',
>                      '--debug-trace':    'Debug trace based on specific flags (console,gdb,output,cov)',
