[PATCH 1/1] Add yaml format to the supported report formats
Cláudio Maia
clrrm at isep.ipp.pt
Thu Dec 3 16:47:56 UTC 2020
On 02/12/20 20:41, Chris Johns wrote:
> On 3/12/20 3:05 am, clrrm at isep.ipp.pt wrote:
>> From: Cláudio Maia <clrrm at isep.ipp.pt>
> Thanks. Does this work on python2?
I had to do a small change in v2 due to the unicode string returned by path.basename() which was not being handled correctly by PyYAML.
After that change, I tested with Python 2.7 and 3.6.9 and it works as expected.
>> tester/rt/test.py | 104 +++++++++++++++++++++++++++++++++++++++++++++-
>> 1 file changed, 102 insertions(+), 2 deletions(-)
>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>> index 9b157e9..0178a8d 100644
>> --- a/tester/rt/test.py
>> +++ b/tester/rt/test.py
>> @@ -339,9 +339,109 @@ def generate_junit_report(args, reports, start_time, end_time,
>> with open(junit_file, 'w') as f:
>> TestSuite.to_file(f, [ts], prettyprint = True)
>> +def generate_yaml_report(args, reports, start_time, end_time,
>> + total, yaml_file):
>> + import yaml
> I would catch an import error and generate a nice error message for the user
> suggesting installing YAML from pip or where ever we recommend.
Added your suggestion to version 2 of the patch.
Cláudio
> Chris
>> + def format_output(output_list):
>> + return "\n".join(output_list).replace("] ", '').replace('=> ', '')
>> + yaml_log = {}
>> + yaml_log['command-line'] = args
>> + yaml_log['host'] = host.label(mode='all')
>> + yaml_log['python'] = sys.version.replace('\n', '')
>> + yaml_log['summary'] = {}
>> + yaml_log['summary']['passed-count'] = reports.passed
>> + yaml_log['summary']['failed-count'] = reports.failed
>> + yaml_log['summary']['user-input-count'] = reports.user_input
>> + yaml_log['summary']['expected-fail-count'] = reports.expected_fail
>> + yaml_log['summary']['indeterminate-count'] = reports.indeterminate
>> + yaml_log['summary']['benchmark-count'] = reports.benchmark
>> + yaml_log['summary']['timeout-count'] = reports.timeouts
>> + yaml_log['summary']['test-too-long_count'] = reports.test_too_long
>> + yaml_log['summary']['invalid-count'] = reports.invalids
>> + yaml_log['summary']['wrong-version-count'] = reports.wrong_version
>> + yaml_log['summary']['wrong-build-count'] = reports.wrong_build
>> + yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
>> + yaml_log['summary']['total-count'] = reports.total
>> + time_delta = end_time - start_time
>> + yaml_log['summary']['average-test-time'] = str(time_delta / total)
>> + yaml_log['summary']['testing-time'] = str(time_delta)
>> + result_types = [
>> + 'failed', 'user-input', 'expected-fail', 'indeterminate',
>> + 'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
>> + 'wrong-build', 'wrong-tools'
>> + for result_type in result_types:
>> + yaml_log['summary'][result_type] = []
>> + result_element = {}
>> + yaml_log['outputs'] = []
>> + # process output of each test
>> + for exe_name in reports.results:
>> + result_element['executable-name'] = path.basename(exe_name)
>> + result_element['executable-sha512'] = get_hash512(exe_name)
>> + result_element['execution-start'] = reports.results[exe_name]['start'].isoformat()
>> + result_element['execution-end'] = reports.results[exe_name]['end'].isoformat()
>> + date_diff = reports.results[exe_name]['end'] - reports.results[exe_name]['start']
>> + result_element['execution-duration'] = str(date_diff)
>> + result_element['execution-result'] = reports.results[exe_name]['result']
>> + result_element['bsp'] = reports.results[exe_name]['bsp']
>> + result_element['bsp-arch'] = reports.results[exe_name]['bsp_arch']
>> + result_output = reports.results[exe_name]['output']
>> + dbg_output = []
>> + test_output = []
>> + idxs_output = [] # store indices of given substrings
>> + for elem in result_output:
>> + if '=> ' in elem:
>> + idxs_output.append(result_output.index(elem))
>> + if '*** END' in elem:
>> + if len(idxs_output) == 3: # test executed and has result
>> + dbg_output = result_output[idxs_output[0]:idxs_output[1]]
>> + dbg_output.append("=== Executed Test ===")
>> + dbg_output = dbg_output + result_output[idxs_output[2]+1:len(result_output)]
>> + test_output = result_output[idxs_output[1]:idxs_output[2]+1]
>> + else:
>> + result_element['debugger-output'] = format_output(dbg_output)
>> + result_element['console-output'] = format_output(test_output)
>> + yaml_log['outputs'].append(result_element)
>> + result_type = reports.results[exe_name]['result']
>> + # map "fatal-error" on to "failed"
>> + if result_type == "fatal-error":
>> + result_type = "failed"
>> + if result_type != 'passed':
>> + yaml_log['summary'][result_type].append(path.basename(exe_name))
>> + with open(yaml_file, 'w') as outfile:
>> + yaml.dump(yaml_log, outfile, default_flow_style=False, allow_unicode=True)
>> +def get_hash512(exe):
>> + """ returns SHA512 hash string of a given binary file passed as argument """
>> + import hashlib
>> + hash = hashlib.sha512()
>> + with open(exe, "rb") as f:
>> + for byte_block in iter(lambda: f.read(4096), b""):
>> + hash.update(byte_block)
>> + return hash.hexdigest()
>> report_formatters = {
>> 'json': generate_json_report,
>> - 'junit': generate_junit_report
>> + 'junit': generate_junit_report,
>> + 'yaml': generate_yaml_report
>> @@ -365,7 +465,7 @@ def run(args):
>> '--rtems-bsp': 'The RTEMS BSP to run the test on',
>> '--user-config': 'Path to your local user configuration INI file',
>> '--report-path': 'Report output base path (file extension will be added)',
>> - '--report-format': 'Formats in which to report test results in addition to txt: json',
>> + '--report-format': 'Formats in which to report test results in addition to txt: json, yaml',
>> '--log-mode': 'Reporting modes, failures (default),all,none',
>> '--list-bsps': 'List the supported BSPs',
>> '--debug-trace': 'Debug trace based on specific flags (console,gdb,output,cov)',
