[PATCH v2 1/1] tester: Add yaml format to the supported report formats
clrrm at isep.ipp.pt clrrm at isep.ipp.pt
Thu Dec 3 16:41:38 UTC 2020
 tester/rt/test.py | 115 +++++++++++++++++++++++++++++++++++++++++++++-
 1 file changed, 113 insertions(+), 2 deletions(-)
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 9b157e9..e0cfdff 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -339,9 +339,120 @@ def generate_junit_report(args, reports, start_time, end_time,
     with open(junit_file, 'w') as f:
         TestSuite.to_file(f, [ts], prettyprint = True)
+def generate_yaml_report(args, reports, start_time, end_time,
+                         total, yaml_file):
+    """ Generates a YAML file containing information about the test run,
+    including all test outputs """
+    try:
+        import yaml
+    except ImportError:
+        print("\nWARNING: To generate the yaml report, the PyYAML module "
+              "should be installed. HINT: You can use pip to install it!")
+        return
+    def format_output(output_list):
+        return "\n".join(output_list).replace("] ", '').replace('=>  ', '')
+    yaml_log = {}
+    yaml_log['command-line'] = args
+    yaml_log['host'] = host.label(mode='all')
+    yaml_log['python'] = sys.version.replace('\n', '')
+    yaml_log['summary'] = {}
+    yaml_log['summary']['passed-count'] = reports.passed
+    yaml_log['summary']['failed-count'] = reports.failed
+    yaml_log['summary']['user-input-count'] = reports.user_input
+    yaml_log['summary']['expected-fail-count'] = reports.expected_fail
+    yaml_log['summary']['indeterminate-count'] = reports.indeterminate
+    yaml_log['summary']['benchmark-count'] = reports.benchmark
+    yaml_log['summary']['timeout-count'] = reports.timeouts
+    yaml_log['summary']['test-too-long_count'] = reports.test_too_long
+    yaml_log['summary']['invalid-count'] = reports.invalids
+    yaml_log['summary']['wrong-version-count'] = reports.wrong_version
+    yaml_log['summary']['wrong-build-count'] = reports.wrong_build
+    yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
+    yaml_log['summary']['total-count'] = reports.total
+    time_delta = end_time - start_time
+    yaml_log['summary']['average-test-time'] = str(time_delta / total)
+    yaml_log['summary']['testing-time'] = str(time_delta)
+    result_types = [
+            'failed', 'user-input', 'expected-fail', 'indeterminate',
+            'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
+            'wrong-build', 'wrong-tools'
+    for result_type in result_types:
+        yaml_log['summary'][result_type] = []
+    result_element = {}
+    yaml_log['outputs'] = []
+    # process output of each test
+    for exe_name in reports.results:
+        test_parts = exe_name.split("/")
+        test_name = test_parts[-1]
+        result_element['executable-name'] = test_name
+        result_element['executable-sha512'] = get_hash512(exe_name)
+        result_element['execution-start'] = reports.results[exe_name]['start'].isoformat()
+        result_element['execution-end'] = reports.results[exe_name]['end'].isoformat()
+        date_diff = reports.results[exe_name]['end'] - reports.results[exe_name]['start']
+        result_element['execution-duration'] = str(date_diff)
+        result_element['execution-result'] = reports.results[exe_name]['result']
+        result_element['bsp'] = reports.results[exe_name]['bsp']
+        result_element['bsp-arch'] = reports.results[exe_name]['bsp_arch']
+        result_output = reports.results[exe_name]['output']
+        dbg_output = []
+        test_output = []
+        idxs_output = []  # store indices of given substrings
+        for elem in result_output:
+            if '=> ' in elem:
+                idxs_output.append(result_output.index(elem))
+            if '*** END' in elem:
+        if len(idxs_output) == 3:  # test executed and has result
+            dbg_output = result_output[idxs_output[0]:idxs_output[1]]
+            dbg_output.append("=== Executed Test ===")
+            dbg_output = dbg_output + result_output[idxs_output[2]+1:len(result_output)]
+            test_output = result_output[idxs_output[1]:idxs_output[2]+1]
+        else:
+        result_element['debugger-output'] = format_output(dbg_output)
+        result_element['console-output'] = format_output(test_output)
+        yaml_log['outputs'].append(result_element)
+        result_type = reports.results[exe_name]['result']
+        # map "fatal-error" on to "failed"
+        if result_type == "fatal-error":
+            result_type = "failed"
+        if result_type != 'passed':
+            yaml_log['summary'][result_type].append(test_name)
+    with open(yaml_file, 'w') as outfile:
+        yaml.dump(yaml_log, outfile, default_flow_style=False, allow_unicode=True)
+def get_hash512(exe):
+    """ returns SHA512 hash string of a given binary file passed as argument """
+    import hashlib
+    hash = hashlib.sha512()
+    with open(exe, "rb") as f:
+        for byte_block in iter(lambda: f.read(4096), b""):
+            hash.update(byte_block)
+    return hash.hexdigest()
 report_formatters = {
         'json': generate_json_report,
-        'junit': generate_junit_report
+        'junit': generate_junit_report,
+        'yaml': generate_yaml_report
@@ -365,7 +476,7 @@ def run(args):
                     '--rtems-bsp':      'The RTEMS BSP to run the test on',
                     '--user-config':    'Path to your local user configuration INI file',
                     '--report-path':    'Report output base path (file extension will be added)',
-                    '--report-format':  'Formats in which to report test results in addition to txt: json',
+                    '--report-format':  'Formats in which to report test results in addition to txt: json, yaml',
                     '--log-mode':       'Reporting modes, failures (default),all,none',
                     '--list-bsps':      'List the supported BSPs',
                     '--debug-trace':    'Debug trace based on specific flags (console,gdb,output,cov)',
2.17.1
