[PATCH v2 0/1] Add yaml format to the supported report formats
clrrm at isep.ipp.pt clrrm at isep.ipp.pt
Thu Dec 3 16:41:37 UTC 2020
Two output formats were supported by RTEMS Tester: json and junit.
This patch adds yaml to the list of supported formats.
The information being stored in the ouput file is the same as the one being
stored for the other formats, with the addition of adding a few more execution
details, such as the output of each test and the "debugger" output.
The feature can be used in the same manner as the other report formats, by
using "--report-format=yaml --report-path=name-of-report".
The patch was tested using leon3 bsp and SIS, either for Python 2.7 and
Python 3.6.9.
v2 adds code for handling the exception when yaml module is not found by Python
runtime environment.
Cláudio Maia (1):
  tester: Add yaml format to the supported report formats
 tester/rt/test.py | 115 +++++++++++++++++++++++++++++++++++++++++++++-
 1 file changed, 113 insertions(+), 2 deletions(-)
2.17.1
