[PATCH v4] zynq-uart: Fix set_attributes implementation
Kinsey Moore kinsey.moore at oarcorp.com
Thu Dec 3 19:10:24 UTC 2020
The zynq-uart set_attributes implementation was configured to always
return false which causes spconsole01 to fail. This restores the
disabled implementation which sets the baud rate registers
appropriately and allows spconsole01 to pass. This also expands the
set_attributes functionality to allow setting of the stop bits,
character width, and parity.
 bsps/include/dev/serial/zynq-uart.h       |  7 +++
 bsps/shared/dev/serial/zynq-uart-polled.c |  2 +-
 bsps/shared/dev/serial/zynq-uart.c        | 56 +++++++++++++++++++++--
 3 files changed, 59 insertions(+), 6 deletions(-)
diff --git a/bsps/include/dev/serial/zynq-uart.h b/bsps/include/dev/serial/zynq-uart.h
index 2c0f250a3a..0eb1dd5f29 100644
--- a/bsps/include/dev/serial/zynq-uart.h
+++ b/bsps/include/dev/serial/zynq-uart.h
@@ -78,6 +78,13 @@ void zynq_uart_write_polled(
 void zynq_uart_reset_tx_flush(zynq_uart_context *ctx);
+int zynq_cal_baud_rate(
+  uint32_t  baudrate,
+  uint32_t* brgr,
+  uint32_t* bauddiv,
+  uint32_t  modereg
 #ifdef __cplusplus
 #endif /* __cplusplus */
diff --git a/bsps/shared/dev/serial/zynq-uart-polled.c b/bsps/shared/dev/serial/zynq-uart-polled.c
index a1b51ea521..442431d502 100644
--- a/bsps/shared/dev/serial/zynq-uart-polled.c
+++ b/bsps/shared/dev/serial/zynq-uart-polled.c
@@ -40,7 +40,7 @@ uint32_t zynq_uart_input_clock(void)
   return ZYNQ_CLOCK_UART;
-static int zynq_cal_baud_rate(uint32_t  baudrate,
+int zynq_cal_baud_rate(uint32_t  baudrate,
                               uint32_t* brgr,
                               uint32_t* bauddiv,
                               uint32_t  modereg)
diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
index 41adb196ab..8f17d3ca65 100644
--- a/bsps/shared/dev/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -142,25 +142,71 @@ static bool zynq_uart_set_attributes(
   const struct termios *term
-#if 0
-  volatile zynq_uart *regs = zynq_uart_get_regs(minor);
+  zynq_uart_context *ctx = (zynq_uart_context *) context;
+  volatile zynq_uart *regs = ctx->regs;
   uint32_t brgr = 0;
   uint32_t bauddiv = 0;
+  uint32_t mode = 0;
   int rc;
   rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
   if (rc != 0)
     return rc;
+   * Configure the mode register
+  mode |= ZYNQ_UART_MODE_CHMODE(ZYNQ_UART_MODE_CHMODE_NORMAL);
+   * Parity
+  mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_NONE);
+  if (term->c_cflag & PARENB) {
+    if (!(term->c_cflag & PARODD)) {
+      mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_ODD);
+    } else {
+      mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_EVEN);
+   * Character Size
+  switch (term->c_cflag & CSIZE)
+  case CS5:
+    return false;
+  case CS6:
+    mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_6);
+    break;
+  case CS7:
+    mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_7);
+    break;
+  case CS8:
+  default:
+    mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_8);
+    break;
+   * Stop Bits
+  if (term->c_cflag & CSTOPB) {
+    /* 2 stop bits */
+    mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_2);
+  } else {
+    /* 1 stop bit */
+    mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_1);
   regs->control &= ~(ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN);
+  regs->mode = mode;
   regs->baud_rate_gen = ZYNQ_UART_BAUD_RATE_GEN_CD(brgr);
   regs->baud_rate_div = ZYNQ_UART_BAUD_RATE_DIV_BDIV(bauddiv);
   regs->control |= ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
   return true;
-#else
-  return false;
-#endif
 const rtems_termios_device_handler zynq_uart_handler = {
2.20.1
