[PATCH v4] zynq-uart: Fix set_attributes implementation
Gedare Bloom
gedare at rtems.org
Thu Dec 3 19:21:17 UTC 2020
looks good to me
On Thu, Dec 3, 2020 at 12:10 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> The zynq-uart set_attributes implementation was configured to always
> return false which causes spconsole01 to fail. This restores the
> disabled implementation which sets the baud rate registers
> appropriately and allows spconsole01 to pass. This also expands the
> set_attributes functionality to allow setting of the stop bits,
> character width, and parity.
> bsps/include/dev/serial/zynq-uart.h | 7 +++
> bsps/shared/dev/serial/zynq-uart-polled.c | 2 +-
> bsps/shared/dev/serial/zynq-uart.c | 56 +++++++++++++++++++++--
> 3 files changed, 59 insertions(+), 6 deletions(-)
> diff --git a/bsps/include/dev/serial/zynq-uart.h
> b/bsps/include/dev/serial/zynq-uart.h
> index 2c0f250a3a..0eb1dd5f29 100644
> --- a/bsps/include/dev/serial/zynq-uart.h
> +++ b/bsps/include/dev/serial/zynq-uart.h
> @@ -78,6 +78,13 @@ void zynq_uart_write_polled(
> void zynq_uart_reset_tx_flush(zynq_uart_context *ctx);
> +int zynq_cal_baud_rate(
> + uint32_t baudrate,
> + uint32_t* brgr,
> + uint32_t* bauddiv,
> + uint32_t modereg
> #ifdef __cplusplus
> #endif /* __cplusplus */
> diff --git a/bsps/shared/dev/serial/zynq-uart-polled.c
> b/bsps/shared/dev/serial/zynq-uart-polled.c
> index a1b51ea521..442431d502 100644
> --- a/bsps/shared/dev/serial/zynq-uart-polled.c
> +++ b/bsps/shared/dev/serial/zynq-uart-polled.c
> @@ -40,7 +40,7 @@ uint32_t zynq_uart_input_clock(void)
> return ZYNQ_CLOCK_UART;
> -static int zynq_cal_baud_rate(uint32_t baudrate,
> +int zynq_cal_baud_rate(uint32_t baudrate,
> uint32_t* brgr,
> uint32_t* bauddiv,
> uint32_t modereg)
> diff --git a/bsps/shared/dev/serial/zynq-uart.c
> b/bsps/shared/dev/serial/zynq-uart.c
> index 41adb196ab..8f17d3ca65 100644
> --- a/bsps/shared/dev/serial/zynq-uart.c
> +++ b/bsps/shared/dev/serial/zynq-uart.c
> @@ -142,25 +142,71 @@ static bool zynq_uart_set_attributes(
> const struct termios *term
> -#if 0
> - volatile zynq_uart *regs = zynq_uart_get_regs(minor);
> + zynq_uart_context *ctx = (zynq_uart_context *) context;
> + volatile zynq_uart *regs = ctx->regs;
> uint32_t brgr = 0;
> uint32_t bauddiv = 0;
> + uint32_t mode = 0;
> int rc;
> rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
> if (rc != 0)
> return rc;
> + * Configure the mode register
> + mode |= ZYNQ_UART_MODE_CHMODE(ZYNQ_UART_MODE_CHMODE_NORMAL);
> + * Parity
> + mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_NONE);
> + if (term->c_cflag & PARENB) {
> + if (!(term->c_cflag & PARODD)) {
> + mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_ODD);
> + } else {
> + mode |= ZYNQ_UART_MODE_PAR(ZYNQ_UART_MODE_PAR_EVEN);
> + * Character Size
> + switch (term->c_cflag & CSIZE)
> + case CS5:
> + return false;
> + case CS6:
> + mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_6);
> + break;
> + case CS7:
> + mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_7);
> + break;
> + case CS8:
> + default:
> + mode |= ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_8);
> + break;
> + * Stop Bits
> + if (term->c_cflag & CSTOPB) {
> + /* 2 stop bits */
> + mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_2);
> + } else {
> + /* 1 stop bit */
> + mode |= ZYNQ_UART_MODE_NBSTOP(ZYNQ_UART_MODE_NBSTOP_STOP_1);
> regs->control &= ~(ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN);
> + regs->mode = mode;
> regs->baud_rate_gen = ZYNQ_UART_BAUD_RATE_GEN_CD(brgr);
> regs->baud_rate_div = ZYNQ_UART_BAUD_RATE_DIV_BDIV(bauddiv);
> regs->control |= ZYNQ_UART_CONTROL_RXEN | ZYNQ_UART_CONTROL_TXEN;
> return true;
> -#else
> - return false;
> -#endif
> const rtems_termios_device_handler zynq_uart_handler = {
> 2.20.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201203/77f813de/attachment.html>
