Building llvm/clang for RTEMS
Fri Dec 4 01:28:18 UTC 2020
On Thu, Dec 3, 2020 at 4:19 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hello,
> I am thinking about building an LLVM toolchain for RISC-V  and AArch64
> from RSB. I am looking for some suggestions or references if someone has
> worked on clang/llvm support for RTEMS.
There is an RSB bset for clang-llvm so it should be easy. Double check it
is at the right version for you. :)
rtems/config/6/rtems-llvm.bset
> Best regards,
> Vijay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201203/eddcb44e/attachment.html>
