Building llvm/clang for RTEMS
Vijay Kumar Banerjee vijay at rtems.org
Fri Dec 4 19:39:29 UTC 2020
On Sat, Dec 5, 2020 at 1:09 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Fri, Dec 4, 2020 at 6:58 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Dec 3, 2020 at 4:19 PM Vijay Kumar Banerjee <vijay at rtems.org>
>> wrote:
>>> Hello,
>>> I am thinking about building an LLVM toolchain for RISC-V  and AArch64
>>> from RSB. I am looking for some suggestions or references if someone has
>>> worked on clang/llvm support for RTEMS.
>> There is an RSB bset for clang-llvm so it should be easy. Double check it
>> is at the right version for you. :)
>> rtems/config/6/rtems-llvm.bset
> Thanks for the reference. I'll check it out. :)
>>> Best regards,
>>> Vijay
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201205/485e85a3/attachment.html>
