Which threads execute _Thread_Handler ?
Richi Dubey richidubey at gmail.com
Sat Dec 5 05:35:07 UTC 2020
> I have currently no time to help you debugging this issue.
Okay, even a hint would be helpful.
returns to _Thread_Do_dispatch() or jumps to _Thread_Handler().
When does it return to  _Thread_Do_dispatch() and when does it jump to
_Thread_Handler() ? Is there a condition? How does it choose between what
to do?
On Fri, Dec 4, 2020 at 1:35 PM Sebastian Huber <
> On 04/12/2020 08:56, Richi Dubey wrote:
> > When I am trying to debug tm24 running on the Strong APA scheduler
> > code, I can see that the thread which comes after the call
> > to _CPU_Context_switch, resumes execution from the same code (next
> > line in the _Thread_Do_dispatch function after _CPU_Context_switch),
> > whereas when the same code is run on a different scheduler (the
> > default sp scheduler) the heir thread that executes after the call
> > to _CPU_Context_switch starts executing from  _Thread_Handler and does
> > not resume its execution from the _Thread_Do_dispatch (which has the
> > context_switch function call).
> > Why is this happening? Is the scheduler responsible for this?
> Each thread starts the execution in _Thread_Handler(). A context switch
> returns to _Thread_Do_dispatch() or jumps to _Thread_Handler(). The
> _Thread_Handler() completes the context switch, does some general calls
> to begin the thread execution and then calls the thread entry function.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201205/cb29a08b/attachment.html>
