Which threads execute _Thread_Handler ?
Richi Dubey
richidubey at gmail.com
Sat Dec 5 06:13:38 UTC 2020
Also,
The stack trace for the thread looks like this:
Tasks (entry function) -> rtems_task_wake_after ->_Thread_Dispatch_direct
-> _Thread_Do_dispatch (where the _Context_switch function call lies), how
can then the heir thread start executing from the _Thread_Handler? I do not
see it in the trace at all.
On Sat, Dec 5, 2020 at 11:05 AM Richi Dubey <richidubey at gmail.com> wrote:
> I have currently no time to help you debugging this issue.
> Okay, even a hint would be helpful.
> returns to _Thread_Do_dispatch() or jumps to _Thread_Handler().
> When does it return to _Thread_Do_dispatch() and when does it jump to
> _Thread_Handler() ? Is there a condition? How does it choose between what
> to do?
> On Fri, Dec 4, 2020 at 1:35 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 04/12/2020 08:56, Richi Dubey wrote:
>> > When I am trying to debug tm24 running on the Strong APA scheduler
>> > code, I can see that the thread which comes after the call
>> > to _CPU_Context_switch, resumes execution from the same code (next
>> > line in the _Thread_Do_dispatch function after _CPU_Context_switch),
>> > whereas when the same code is run on a different scheduler (the
>> > default sp scheduler) the heir thread that executes after the call
>> > to _CPU_Context_switch starts executing from _Thread_Handler and does
>> > not resume its execution from the _Thread_Do_dispatch (which has the
>> > context_switch function call).
>> > Why is this happening? Is the scheduler responsible for this?
>> Each thread starts the execution in _Thread_Handler(). A context switch
>> returns to _Thread_Do_dispatch() or jumps to _Thread_Handler(). The
>> _Thread_Handler() completes the context switch, does some general calls
>> to begin the thread execution and then calls the thread entry function.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201205/34ce3f9b/attachment.html>
