[PATCH] tester: Add configs for AArch64 ZynqMP BSPs
Kinsey Moore kinsey.moore at oarcorp.com
Mon Dec 7 15:01:24 UTC 2020
 .../testing/bsps/xilinx_zynqmp_ilp32.ini      | 38 +++++++++++++++++++
 .../rtems/testing/bsps/xilinx_zynqmp_lp64.ini | 38 +++++++++++++++++++
 2 files changed, 76 insertions(+)
 create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
 create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
new file mode 100644
index 0000000..5ff0e86
--- /dev/null
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
@@ -0,0 +1,38 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2020 Kinsey Moore(kinsey.moore at oarcorp.com)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) ILP32 BSP.
+[xilinx_zynqmp_ilp32]
+bsp           = xilinx_zynqmp_ilp32
+arch          = aarch64
+tester        = %{_rtscripts}/qemu.cfg
+bsp_qemu_opts = %{qemu_opts_base} -serial null -serial mon:stdio -machine xlnx-zcu102 -m 4096
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
index 0000000..8db82b6
--- /dev/null
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
@@ -0,0 +1,38 @@
+# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) LP64 BSP.
+[xilinx_zynqmp_lp64]
+bsp           = xilinx_zynqmp_lp64
+arch          = aarch64
2.20.1
