[PATCH] tester: Add configs for AArch64 ZynqMP BSPs
Fri Dec 11 13:42:31 UTC 2020
looks ok to push assuming it works :)
On Tue, Dec 8, 2020 at 11:03 AM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
>  .../testing/bsps/xilinx_zynqmp_ilp32.ini      | 38 +++++++++++++++++++
>  .../rtems/testing/bsps/xilinx_zynqmp_lp64.ini | 38 +++++++++++++++++++
>  2 files changed, 76 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
>  create mode 100644 tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
> b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
> new file mode 100644
> index 0000000..5ff0e86
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_ilp32.ini
> @@ -0,0 +1,38 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2020 Kinsey Moore(kinsey.moore at oarcorp.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) ILP32 BSP.
> +[xilinx_zynqmp_ilp32]
> +bsp           = xilinx_zynqmp_ilp32
> +arch          = aarch64
> +tester        = %{_rtscripts}/qemu.cfg
> +bsp_qemu_opts = %{qemu_opts_base} -serial null -serial mon:stdio -machine
> xlnx-zcu102 -m 4096
> diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
> b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
> index 0000000..8db82b6
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64.ini
> @@ -0,0 +1,38 @@
> met:
> notice,
> notice,
> documentation
> IS"
> THE
> PURPOSE
> BE
> THE
> +# The AArch64 Xilinx ZynqMP (Ultrascale+ MPSOC) LP64 BSP.
> +[xilinx_zynqmp_lp64]
> +bsp           = xilinx_zynqmp_lp64
> +arch          = aarch64
> xlnx-zcu102 -m 4096
> 2.20.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201211/741f2dff/attachment.html>
