[PATCH 2/2] cpukit/aarch64: Add explanation of exception flow
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Dec 8 16:11:22 UTC 2020
.../cpu/aarch64/aarch64-exception-default.S | 17 ++++++++++++++++-
.../cpu/aarch64/aarch64-exception-interrupt.S | 4 ++--
2 files changed, 18 insertions(+), 3 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
index 81aa82558e..970ccf735f 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
@@ -54,7 +54,22 @@
* This is the exception vector table and the pointers to the default
- * exceptions handlers.
+ * exceptions handlers. Each vector in the table has space for up to 32
+ * instructions. The space of the last two instructions in each vector is used
+ * for the exception handler pointer.
+ * The operation of all exceptions is as follows:
+ * * An exception occurs
+ * * A vector is chosen based on the exception type and machine state
+ * * Execution begins at the chosen vector
+ * * X0 and LR are pushed onto the current stack
+ * * An unconditional branch and link is taken to the next instruction to get
+ * the PC
+ * * The exception handler pointer (EHP) is retrieved from the current vector using
+ * the PC
+ * * Branch and link to the EHP
+ * * X0 and LR are popped from the current stack after returning from the EHP
+ * * The exception returns to the previous execution state
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
index f534a526b3..cb0954a29b 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
@@ -255,7 +255,7 @@ _AArch64_Exception_interrupt_nest:
Save volatile regs on interrupt stack
Execute irq handler
Restore volatile regs from interrupt stack
-Exception return
+Return to embedded exception vector code
/* Push interrupt context */
@@ -281,7 +281,7 @@ Execute interrupt handler
Switch to thread stack
Call thread dispatch
Restore volatile registers from thread stack
-Return to dispatch
2.20.1
