[PATCH 1/2] cpukit/aarch64: Use hex consistently for offsets
Kinsey Moore kinsey.moore at oarcorp.com
Tue Dec 8 16:11:21 UTC 2020
 .../cpu/aarch64/aarch64-context-validate.S    |  40 +++---
 .../cpu/aarch64/aarch64-exception-default.S   |  38 +++---
 .../cpu/aarch64/aarch64-exception-interrupt.S | 116 +++++++++---------
 cpukit/score/cpu/aarch64/cpu_asm.S            |  12 +-
 .../cpu/aarch64/include/rtems/score/cpu.h     |  26 ++--
 5 files changed, 116 insertions(+), 116 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-context-validate.S b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
index 31c8d5571c..57f634934b 100644
--- a/cpukit/score/cpu/aarch64/aarch64-context-validate.S
+++ b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
@@ -43,29 +43,29 @@
 #include <rtems/asm.h>
 #include <rtems/score/cpu.h>
-#define FRAME_OFFSET_X4 0
-#define FRAME_OFFSET_X5 8
-#define FRAME_OFFSET_X6 16
-#define FRAME_OFFSET_X7 24
-#define FRAME_OFFSET_X8 32
-#define FRAME_OFFSET_X9 40
-#define FRAME_OFFSET_X10 48
-#define FRAME_OFFSET_X11 56
-#define FRAME_OFFSET_LR 64
+#define FRAME_OFFSET_X4  0x00
+#define FRAME_OFFSET_X5  0x08
+#define FRAME_OFFSET_X6  0x10
+#define FRAME_OFFSET_X7  0x18
+#define FRAME_OFFSET_X8  0x20
+#define FRAME_OFFSET_X9  0x28
+#define FRAME_OFFSET_X10 0x30
+#define FRAME_OFFSET_X11 0x38
+#define FRAME_OFFSET_LR  0x40
 #ifdef AARCH64_MULTILIB_VFP
-  #define FRAME_OFFSET_V8 72
-  #define FRAME_OFFSET_V9 88
-  #define FRAME_OFFSET_V10 104
-  #define FRAME_OFFSET_V11 120
-  #define FRAME_OFFSET_V12 136
-  #define FRAME_OFFSET_V13 152
-  #define FRAME_OFFSET_V14 168
-  #define FRAME_OFFSET_V15 184
-  #define FRAME_SIZE (FRAME_OFFSET_V15 + 16)
+  #define FRAME_OFFSET_V8  0x48
+  #define FRAME_OFFSET_V9  0x58
+  #define FRAME_OFFSET_V10 0x68
+  #define FRAME_OFFSET_V11 0x78
+  #define FRAME_OFFSET_V12 0x88
+  #define FRAME_OFFSET_V13 0x98
+  #define FRAME_OFFSET_V14 0xA8
+  #define FRAME_OFFSET_V15 0xB8
+  #define FRAME_SIZE (FRAME_OFFSET_V15 + 0x10)
 #else
-  #define FRAME_SIZE (FRAME_OFFSET_LR + 8)
+  #define FRAME_SIZE (FRAME_OFFSET_LR + 0x08)
 #endif
 	.section	.text
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
index 3d311df280..81aa82558e 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
@@ -74,7 +74,7 @@
 	blr x0
 /* Pop x0,lr from stack */
-	ldp x0,	lr,	[sp],	#16
+	ldp x0,	lr,	[sp],	#0x10
 /* Return from exception */
 	eret
 	nop
@@ -129,7 +129,7 @@ Vector_table_el3:
  * using SP0.
 curr_el_sp0_sync:
-	stp x0,	lr,	[sp, #-16]!	/* Push x0,lr on to the stack */
+	stp x0,	lr,	[sp, #-0x10]!	/* Push x0,lr on to the stack */
 	bl curr_el_sp0_sync_get_pc	/* Get current execution address */
 curr_el_sp0_sync_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -137,7 +137,7 @@ curr_el_sp0_sync_get_pc:		/* The current PC is now in LR */
 .balign 0x80
 /* The exception handler for IRQ exceptions from the current EL using SP0. */
 curr_el_sp0_irq:
 	bl curr_el_sp0_irq_get_pc	/* Get current execution address */
 curr_el_sp0_irq_get_pc:			/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -145,7 +145,7 @@ curr_el_sp0_irq_get_pc:			/* The current PC is now in LR */
 .balign 0x80
 /* The exception handler for FIQ exceptions from the current EL using SP0. */
 curr_el_sp0_fiq:
 	bl curr_el_sp0_fiq_get_pc	/* Get current execution address */
 curr_el_sp0_fiq_get_pc:			/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -156,7 +156,7 @@ curr_el_sp0_fiq_get_pc:			/* The current PC is now in LR */
  * SP0.
 curr_el_sp0_serror:
 	bl curr_el_sp0_serror_get_pc	/* Get current execution address */
 curr_el_sp0_serror_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -167,7 +167,7 @@ curr_el_sp0_serror_get_pc:		/* The current PC is now in LR */
  * the current SP.
 curr_el_spx_sync:
 	bl curr_el_spx_sync_get_pc	/* Get current execution address */
 curr_el_spx_sync_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -178,7 +178,7 @@ curr_el_spx_sync_get_pc:		/* The current PC is now in LR */
  * current SP.
 curr_el_spx_irq:
 	bl curr_el_spx_irq_get_pc	/* Get current execution address */
 curr_el_spx_irq_get_pc:			/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -189,7 +189,7 @@ curr_el_spx_irq_get_pc:			/* The current PC is now in LR */
  * current SP.
 curr_el_spx_fiq:
 	bl curr_el_spx_fiq_get_pc	/* Get current execution address */
 curr_el_spx_fiq_get_pc:			/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -200,7 +200,7 @@ curr_el_spx_fiq_get_pc:			/* The current PC is now in LR */
  * the current SP.
 curr_el_spx_serror:
 	bl curr_el_spx_serror_get_pc	/* Get current execution address */
 curr_el_spx_serror_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -210,7 +210,7 @@ curr_el_spx_serror_get_pc:		/* The current PC is now in LR */
  * The exception handler for synchronous exceptions from a lower EL (AArch64).
 lower_el_aarch64_sync:
 	bl lower_el_aarch64_sync_get_pc	/* Get current execution address */
 lower_el_aarch64_sync_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -218,7 +218,7 @@ lower_el_aarch64_sync_get_pc:		/* The current PC is now in LR */
 .balign 0x80
 /* The exception handler for IRQ exceptions from a lower EL (AArch64). */
 lower_el_aarch64_irq:
 	bl lower_el_aarch64_irq_get_pc	/* Get current execution address */
 lower_el_aarch64_irq_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -226,7 +226,7 @@ lower_el_aarch64_irq_get_pc:		/* The current PC is now in LR */
 .balign 0x80
 /* The exception handler for FIQ exceptions from a lower EL (AArch64). */
 lower_el_aarch64_fiq:
 	bl lower_el_aarch64_fiq_get_pc	/* Get current execution address */
 lower_el_aarch64_fiq_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -237,7 +237,7 @@ lower_el_aarch64_fiq_get_pc:		/* The current PC is now in LR */
 lower_el_aarch64_serror:
 	bl lower_el_aarch64_serror_get_pc
 lower_el_aarch64_serror_get_pc:		/* The current PC is now in LR */
@@ -248,7 +248,7 @@ lower_el_aarch64_serror_get_pc:		/* The current PC is now in LR */
  * The exception handler for the synchronous exception from a lower EL(AArch32).
 lower_el_aarch32_sync:
 	bl lower_el_aarch32_sync_get_pc	/* Get current execution address */
 lower_el_aarch32_sync_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -256,7 +256,7 @@ lower_el_aarch32_sync_get_pc:		/* The current PC is now in LR */
 .balign 0x80
 /* The exception handler for the IRQ exception from a lower EL (AArch32). */
 lower_el_aarch32_irq:
 	bl lower_el_aarch32_irq_get_pc	/* Get current execution address */
 lower_el_aarch32_irq_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -264,7 +264,7 @@ lower_el_aarch32_irq_get_pc:		/* The current PC is now in LR */
 .balign 0x80
 /* The exception handler for the FIQ exception from a lower EL (AArch32). */
 lower_el_aarch32_fiq:
 	bl lower_el_aarch32_fiq_get_pc	/* Get current execution address */
 lower_el_aarch32_fiq_get_pc:		/* The current PC is now in LR */
 	JUMP_HANDLER
@@ -276,7 +276,7 @@ lower_el_aarch32_fiq_get_pc:		/* The current PC is now in LR */
 lower_el_aarch32_serror:
 	bl lower_el_aarch32_serror_get_pc
 lower_el_aarch32_serror_get_pc	:		/* The current PC is now in LR */
@@ -311,7 +311,7 @@ bsp_start_vector_table_end:
  * safe because this will never return
 	msr spsel, #1
 	msr spsel, #0
 /* Save LR */
 	str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
@@ -349,7 +349,7 @@ bsp_start_vector_table_end:
 /* Push the start of the context */
 	bl .push_exception_context_start
 /* Save original sp in x0 for .push_exception_context_finish */
-	add x0, sp, #(AARCH64_EXCEPTION_FRAME_SIZE + 16)
+	add x0, sp, #(AARCH64_EXCEPTION_FRAME_SIZE + 0x10)
 /* Push the remainder of the context */
 	bl .push_exception_context_finish
 /* Save sp (exception frame) into x0 for handler */
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
index fc04af6987..f534a526b3 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
@@ -161,90 +161,90 @@
  * Push x1-x21 on to the stack, need 19-21 because they're modified without
  * obeying PCS
-	stp lr,		x1,	[sp, #-16]!
-	stp x2,		x3,	[sp, #-16]!
-	stp x4,		x5,	[sp, #-16]!
-	stp x6,		x7,	[sp, #-16]!
-	stp x8,		x9,	[sp, #-16]!
-	stp x10,	x11,	[sp, #-16]!
-	stp x12,	x13,	[sp, #-16]!
-	stp x14,	x15,	[sp, #-16]!
-	stp x16,	x17,	[sp, #-16]!
-	stp x18,	x19,	[sp, #-16]!
-	stp x20,	x21,	[sp, #-16]!
+	stp lr,		x1,	[sp, #-0x10]!
+	stp x2,		x3,	[sp, #-0x10]!
+	stp x4,		x5,	[sp, #-0x10]!
+	stp x6,		x7,	[sp, #-0x10]!
+	stp x8,		x9,	[sp, #-0x10]!
+	stp x10,	x11,	[sp, #-0x10]!
+	stp x12,	x13,	[sp, #-0x10]!
+	stp x14,	x15,	[sp, #-0x10]!
+	stp x16,	x17,	[sp, #-0x10]!
+	stp x18,	x19,	[sp, #-0x10]!
+	stp x20,	x21,	[sp, #-0x10]!
  * Push q0-q31 on to the stack, need everything because parts of every register
  * are volatile/corruptible
-	stp q0,		q1,	[sp, #-32]!
-	stp q2,		q3,	[sp, #-32]!
-	stp q4,		q5,	[sp, #-32]!
-	stp q6,		q7,	[sp, #-32]!
-	stp q8,		q9,	[sp, #-32]!
-	stp q10,	q11,	[sp, #-32]!
-	stp q12,	q13,	[sp, #-32]!
-	stp q14,	q15,	[sp, #-32]!
-	stp q16,	q17,	[sp, #-32]!
-	stp q18,	q19,	[sp, #-32]!
-	stp q20,	q21,	[sp, #-32]!
-	stp q22,	q23,	[sp, #-32]!
-	stp q24,	q25,	[sp, #-32]!
-	stp q26,	q27,	[sp, #-32]!
-	stp q28,	q29,	[sp, #-32]!
-	stp q30,	q31,	[sp, #-32]!
+	stp q0,		q1,	[sp, #-0x20]!
+	stp q2,		q3,	[sp, #-0x20]!
+	stp q4,		q5,	[sp, #-0x20]!
+	stp q6,		q7,	[sp, #-0x20]!
+	stp q8,		q9,	[sp, #-0x20]!
+	stp q10,	q11,	[sp, #-0x20]!
+	stp q12,	q13,	[sp, #-0x20]!
+	stp q14,	q15,	[sp, #-0x20]!
+	stp q16,	q17,	[sp, #-0x20]!
+	stp q18,	q19,	[sp, #-0x20]!
+	stp q20,	q21,	[sp, #-0x20]!
+	stp q22,	q23,	[sp, #-0x20]!
+	stp q24,	q25,	[sp, #-0x20]!
+	stp q26,	q27,	[sp, #-0x20]!
+	stp q28,	q29,	[sp, #-0x20]!
+	stp q30,	q31,	[sp, #-0x20]!
 /* Get exception LR for PC and spsr */
 	mrs x0, ELR_EL1
 	mrs x1, SPSR_EL1
 /* Push pc and spsr */
-	stp x0,		x1,	[sp, #-16]!
+	stp x0,		x1,	[sp, #-0x10]!
 /* Get fpcr and fpsr */
 	mrs x0, FPSR
 	mrs x1, FPCR
 /* Push fpcr and fpsr */
 .endm
 /* Must match inverse order of .push_interrupt_context */
 .macro pop_interrupt_context
 /* Pop fpcr and fpsr */
-	ldp x0,		x1,	[sp], #16
+	ldp x0,		x1,	[sp], #0x10
 /* Restore fpcr and fpsr */
 	msr FPCR, x1
 	msr FPSR, x0
 /* Pop pc and spsr */
 /* Restore exception LR for PC and spsr */
 	msr SPSR_EL1, x1
 	msr ELR_EL1, x0
 /* Pop q0-q31 */
-	ldp q30,	q31,	[sp], #32
-	ldp q28,	q29,	[sp], #32
-	ldp q26,	q27,	[sp], #32
-	ldp q24,	q25,	[sp], #32
-	ldp q22,	q23,	[sp], #32
-	ldp q20,	q21,	[sp], #32
-	ldp q18,	q19,	[sp], #32
-	ldp q16,	q17,	[sp], #32
-	ldp q14,	q15,	[sp], #32
-	ldp q12,	q13,	[sp], #32
-	ldp q10,	q11,	[sp], #32
-	ldp q8,		q9,	[sp], #32
-	ldp q6,		q7,	[sp], #32
-	ldp q4,		q5,	[sp], #32
-	ldp q2,		q3,	[sp], #32
-	ldp q0,		q1,	[sp], #32
+	ldp q30,	q31,	[sp], #0x20
+	ldp q28,	q29,	[sp], #0x20
+	ldp q26,	q27,	[sp], #0x20
+	ldp q24,	q25,	[sp], #0x20
+	ldp q22,	q23,	[sp], #0x20
+	ldp q20,	q21,	[sp], #0x20
+	ldp q18,	q19,	[sp], #0x20
+	ldp q16,	q17,	[sp], #0x20
+	ldp q14,	q15,	[sp], #0x20
+	ldp q12,	q13,	[sp], #0x20
+	ldp q10,	q11,	[sp], #0x20
+	ldp q8,		q9,	[sp], #0x20
+	ldp q6,		q7,	[sp], #0x20
+	ldp q4,		q5,	[sp], #0x20
+	ldp q2,		q3,	[sp], #0x20
+	ldp q0,		q1,	[sp], #0x20
 /* Pop x1-x21 */
-	ldp x20,	x21,	[sp], #16
-	ldp x18,	x19,	[sp], #16
-	ldp x16,	x17,	[sp], #16
-	ldp x14,	x15,	[sp], #16
-	ldp x12,	x13,	[sp], #16
-	ldp x10,	x11,	[sp], #16
-	ldp x8,		x9,	[sp], #16
-	ldp x6,		x7,	[sp], #16
-	ldp x4,		x5,	[sp], #16
-	ldp x2,		x3,	[sp], #16
-	ldp lr,		x1,	[sp], #16
+	ldp x20,	x21,	[sp], #0x10
+	ldp x18,	x19,	[sp], #0x10
+	ldp x16,	x17,	[sp], #0x10
+	ldp x14,	x15,	[sp], #0x10
+	ldp x12,	x13,	[sp], #0x10
+	ldp x10,	x11,	[sp], #0x10
+	ldp x8,		x9,	[sp], #0x10
+	ldp x6,		x7,	[sp], #0x10
+	ldp x4,		x5,	[sp], #0x10
+	ldp x2,		x3,	[sp], #0x10
+	ldp lr,		x1,	[sp], #0x10
 /* Must clear reservations here to ensure consistency with atomic operations */
 	clrex
 .endm
diff --git a/cpukit/score/cpu/aarch64/cpu_asm.S b/cpukit/score/cpu/aarch64/cpu_asm.S
index 0e1b803610..6c4da04628 100644
--- a/cpukit/score/cpu/aarch64/cpu_asm.S
+++ b/cpukit/score/cpu/aarch64/cpu_asm.S
@@ -78,9 +78,9 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
 	add	x5, x0, #AARCH64_CONTEXT_CONTROL_D8_OFFSET
 	stp d8,  d9,  [x5]
-	stp d10, d11, [x5, #16]
-	stp d12, d13, [x5, #32]
-	stp d14, d15, [x5, #48]
+	stp d10, d11, [x5, #0x10]
+	stp d12, d13, [x5, #0x20]
+	stp d14, d15, [x5, #0x30]
 #endif
 	str	x3, [x0, #AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
@@ -102,9 +102,9 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
 	add	x5, x1, #AARCH64_CONTEXT_CONTROL_D8_OFFSET
 	ldp d8,  d9,  [x5]
-	ldp d10, d11, [x5, #16]
-	ldp d12, d13, [x5, #32]
-	ldp d14, d15, [x5, #48]
+	ldp d10, d11, [x5, #0x10]
+	ldp d12, d13, [x5, #0x20]
+	ldp d14, d15, [x5, #0x30]
 #endif
 	msr	TPIDR_EL0, x3
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index d86543b12a..380d1380fb 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -124,31 +124,31 @@
 #define CPU_MAXIMUM_PROCESSORS 32
-#define AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET 112
+#define AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET 0x70
-  #define AARCH64_CONTEXT_CONTROL_D8_OFFSET 120
+  #define AARCH64_CONTEXT_CONTROL_D8_OFFSET 0x78
 #endif
-#define AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 104
+#define AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 0x68
 #ifdef RTEMS_SMP
   #if defined(AARCH64_MULTILIB_VFP)
-    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
+    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x70
   #else
-    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
+    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x30
   #endif
 #endif
-#define AARCH64_EXCEPTION_FRAME_SIZE 848
+#define AARCH64_EXCEPTION_FRAME_SIZE 0x350
-#define AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET 248
-#define AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET 240
-#define AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET 264
-#define AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET 280
-#define AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET 296
-#define AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET 312
-#define AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET 336
+#define AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET 0xF8
+#define AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET 0xF0
+#define AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET 0x108
+#define AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET 0x118
+#define AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET 0x128
+#define AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET 0x138
+#define AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET 0x150
 #ifndef ASM
2.20.1
