Fwd: New Defects reported by Coverity Scan for RTEMS
    Sebastian Huber
    Wed Dec  9 09:11:51 UTC 2020
On 08/12/2020 19:10, Gedare Bloom wrote:
> Hi all,
> I get a text report on new defects from Coverity. I don't know how I
> managed to sign up for it, and I'm not sure I can get it sent to any
> list automatically, but here is the current updated new defects. Just
> looks like two new ones related to static assertions.
> ---------- Forwarded message ---------
> From: <scan-admin at coverity.com <mailto:scan-admin at coverity.com>>
> Date: Mon, Dec 7, 2020 at 7:38 AM
> Subject: New Defects reported by Coverity Scan for RTEMS
> To: <gedare at gwmail.gwu.edu <mailto:gedare at gwmail.gwu.edu>>
> Hi,
> Please find the latest report on new defect(s) introduced to RTEMS
> found with Coverity Scan.
> 1 new defect(s) introduced to RTEMS found with Coverity Scan.
> 10 defect(s), reported by Coverity Scan earlier, were marked fixed in
> the recent build analyzed by Coverity Scan.
> New defect(s) Reported-by: Coverity Scan
> Showing 1 of 1 defect(s)
> ** CID 1470570:    (PARSE_ERROR)
> /cpukit/include/rtems/confdefs/inittask.h: 110 in ()
> ________________________________________________________________________________________________________
> *** CID 1470570:    (PARSE_ERROR)
> 104      */
> 105     #pragma GCC diagnostic push
> 106     #pragma GCC diagnostic ignored "-Waddress"
> 107     #pragma GCC diagnostic ignored "-Wpragmas"
> 108     #pragma GCC diagnostic ignored "-Wtautological-pointer-compare"
> 109
> >>>     type of cast must be integral
> 110     RTEMS_STATIC_ASSERT(
> 111       CONFIGURE_INIT_TASK_ENTRY_POINT != NULL,
> 112       CONFIGURE_INIT_TASK_ENTRY_POINT_MUST_NOT_BE_NULL
> 113     );
> 114
> 115     #pragma GCC diagnostic pop
> 104      */
> 109
> >>>     expression must be an integral constant expression
> 113     );
> 114
I checked an example code with three compilers and noticed no standard
related warnings. I can ask on a C/C++ mailing list if the code is
standard compliant. It could be Coverity bug.
#include <cstddef>
void f(void);
static_assert(f != NULL, "f");
constexpr bool g()
   return f != NULL;
extern const bool b;
const bool b = g();
arm-rtems6-g++ -Wall -Wextra -pedantic -std=c++11 -S -o - test.cc
         .cpu arm7tdmi
         .eabi_attribute 20, 1
         .eabi_attribute 21, 1
         .eabi_attribute 23, 3
         .eabi_attribute 24, 1
         .eabi_attribute 25, 1
         .eabi_attribute 26, 2
         .eabi_attribute 30, 6
         .eabi_attribute 34, 0
         .eabi_attribute 18, 4
         .file   "test.cc"
test.cc:5:17: warning: the address of 'void f()' will never be NULL
[-Waddress]
     5 | static_assert(f != NULL, "f");
test.cc: In function 'constexpr bool g()':
test.cc:9:12: warning: the address of 'void f()' will never be NULL
[-Waddress]
     9 |   return f != NULL;
         .text
         .global b
         .section        .rodata
         .type   b, %object
         .size   b, 1
b:
         .byte   1
         .ident  "GCC: (GNU) 10.2.1 20201203 (RTEMS 6, RSB
ff6b2320ed34abab48751022085912217f42590d, Newlib 7fa8405)"
         .file   "test.cc"
test.cc:5:17: warning: the address of ‘void f()’ will never be NULL
[-Waddress]
test.cc: In function ‘constexpr bool g()’:
test.cc:9:12: warning: the address of ‘void f()’ will never be NULL
[-Waddress]
    return f != NULL;
         .text
         .globl  b
         .section        .rodata
         .type   b, @object
         .size   b, 1
b:
         .byte   1
         .ident  "GCC: (SUSE Linux) 7.5.0"
         .section        .note.GNU-stack,"", at progbits
clang -Wall -Wextra -pedantic -std=c++11 -S -o - test.cc
test.cc:5:15: warning: comparison of function 'f' not equal to a null
pointer is always true [-Wtautological-pointer-compare]
test.cc:5:15: note: prefix with the address-of operator to silence this
warning
test.cc:9:10: warning: comparison of function 'f' not equal to a null
   return f != NULL;
test.cc:9:10: note: prefix with the address-of operator to silence this
warning
   return f != NULL;
         .text
         .file   "test.cc"
         .type   b, at object               # @b
         .section        .rodata,"a", at progbits
         .globl  b
b:
         .byte   1                       # 0x1
         .size   b, 1
         .ident  "clang version 7.0.1 (tags/RELEASE_701/final 349238)"
         .section        ".note.GNU-stack","", at progbits
         .addrsig
         .addrsig_sym b
2 warnings generated.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
